Old Jul 15, 2003, 07:11 AM
stephenzagy is offline
Find More Posts by stephenzagy
kent, england
Joined Oct 2002
F22 Raptor
Hi there you all. Just fishing for info. I recently purchased an A10 and will be fitting two Wemotec Micros and Roacket 300 brushed motors. That leaves me with 2 GWS fans spare.........o what joy. Thinking of a home for them, has anbody any ideas about altering a Wattage F22 Raptor to take 2 GWS fans? A good bit of hacking out to do and probably a cheater hole as well. I noted some good threads on brushless setups and this is another option.
Look forward to hearing from you
Steve
stephenzagy is offline Find More Posts by stephenzagy
Old Jul 15, 2003, 09:51 AM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
I converted a Wattage F-22 to use a single 2.5" fan with a brushless motor. I had to use CP1300 cells at the time so it was heavy. Performance was ok, I could loop from level flight but it would have been nice if it weighed less...I had 4 ounces on the tail for balance, didn't put the fan far enough back so I couldn't slide the cells very far back. I was flying this plane at about 230 watts and performance was so so. Flying it on two GWS fans at less than 100 watts wouldn't be too much fun. Those two fans barely fly the A-10 and it has a straight wing. A draggy delta wing like on the F-22 would be more difficult. It could be done, but you're talking flying in circles with no aerobatics probably. You'd have to lighten up the airframe significantly. I believe AERC has an all wood F-22 kit in the works for twin EDF-50 fans if that's your thing. Me I like to mix it up, flying on the edge of a stall doesnt' float my boat. I like POWER! Use the EDF 50s as battery coolers with a cardboard tube
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Jul 16, 2003, 10:29 AM
kent, england
Joined Oct 2002
Ed. Your the man. Not much into flying on the edge of a stall myself. Will keep it the way it is for now and maybe make it brushless at some point. Battery coolers. Now there is an idea.
Cheers for that
F22 Raptor videos outthere? with BL setup dgoderich Electric Ducted Fan Jet Talk 1 Jul 27, 2008 04:49 PM
Gallery Wattage F22 Raptor JIMinKENTUCKY Pusher Prop Jet Models 589 Jul 17, 2008 01:38 AM
F22 Raptor stabilator tips? Basketcase Foamies (Kits) 4 May 28, 2003 06:14 PM
Wattage F22 Raptor Sale/Trade b0gh0s Aircraft - Electric - Airplanes (FS/W) 1 Nov 04, 2002 03:54 PM
F22 Raptor Flys Inverted, into trees... rtucker Foamies (Kits) 4 Oct 23, 2002 10:15 AM
