Old Nov 16, 2010, 03:22 AM
balesse is offline
Find More Posts by balesse
balesse's Avatar
USA, WA, Seattle
Joined Oct 2005
Micro Pitts and Mini Cassutt out of Voltek Volara foam
My brother gave me some Voltek Volara foam to try out. The stuff I have is dark grey and about 1/8 in thick. From my understanding the type I have is Polypropylene (like EPP), but is extruded like Depron rather then expanded beads like EPP. It is much tougher than EPP or Depron, which is great, but is much heavier (I think it might be about twice as heavy as the same thickness EPP.
Anyway I have two planes now using the foam. A scaled up Micro Pitts and scaled up Mini Cassutt These are both great designs that are a lot of fun to build.
What is great about this foam is its ability to bend into nice shapes and both of these planes take advantage of that.
The Pitts is pretty standard, just scaled up, and added ailerons. The Cassutt deviates from the plans a bit. It is scaled up, I left off the engine cowling, the wing is airfoiled, and the control surfaces are enlarges, which give it more of squat look.
The both fly great. The Pitts could sometimes us some more power, but flies remarkably like the 12 balsa Micro Pitts that I have seen. The Cassutt is quick and much more manuverable (do to the larger control surfaces) and the regular Cassutt. Plus I just added lights to it this evening, so it will be a new night flier!
balesse is offline Find More Posts by balesse
Old Nov 16, 2010, 05:44 PM
den bach is offline
Find More Posts by den bach
den bach
den bach's Avatar
USA, WA, Moses Lake
Joined Sep 2008
nice lights
way cool
den bach is offline Find More Posts by den bach
Old Nov 16, 2010, 05:48 PM
Meshuggah is offline
Find More Posts by Meshuggah
Nothing flies like a Pitts
Meshuggah's Avatar
Stockholm, Sweden
Joined Aug 2006
Nice! How much do they whey? The pitts is pretty tricky to setup right, i usually have more angle on the top wing. Creates more drag but gets really stable.
Meshuggah is offline Find More Posts by Meshuggah
Old Nov 17, 2010, 12:13 AM
balesse is offline
balesse's Avatar
USA, WA, Seattle
Joined Oct 2005
The Pitts is 168g AUW and the Cassutt is 240g AUW. I think my mini Cassutt that is all EPP is around 110g AUW, so the larger one is a lot heavier, but the wingloading is probably similar. It flies completely different because of the large control surfaces and because it has a lot more power than my small one.
When I first built the Pitts I never put the former between the fuselage and the top wing. I just taped the wing to the fuse. The flight characteristics definitely improved once I put that former in.
Build Log 1/10 Semi-Scale EPP Mini Cassutt Free Plans, Build Guide & Video firetrappe Foamies (Scratchbuilt) 775 Jun 25, 2014 06:04 AM
For Sale Pitts S-2 3d flat out biplanes from Hobby Lobby NIB modlflr Aircraft - Electric - Airplanes (FS/W) 17 Nov 09, 2010 04:41 AM
Sold RTF EPP Mini Cassutt 4 CH 1/10th scale, $125 shipped spbalaj Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Mar 14, 2009 09:26 PM
Video 1/10 Semi-Scale EPP Mini Cassutt Bill Bergman Electric Plane Talk 2 May 17, 2008 12:21 PM
Discussion Chiqui-mini-micro Pitts :D Alfredo Rubio Mexico 7 Jun 05, 2007 10:47 PM
