This thread is privately moderated by WAGliderGuy, who may elect to delete unwanted replies.
Old Nov 15, 2010, 07:35 PM
WAGliderGuy is online now
Find More Posts by WAGliderGuy
Airliner Builder
WAGliderGuy's Avatar
United States, WA, Seattle
Joined Feb 2010
Sig Four-Star 20EP Build!
What a fun and easy sport build!
Here is my setup:
Motor: HeadsUpRC Power-Up 15 sport (1000kv).
ESC: Hobbyking Mystery 40amp.
Batteries: Zippy/Lightmax 3S 2100mah 35Cs (JUST fit!)
Props: 10X7, 10X8, 11X7, 11X8 e-wood and a 11X8.5. Maiden will be with a 11X7 and I don't think I will try the 10'' props.
Servos: HS-81s for the rudder/elevator and HS-65HBs for the ailerons.
RX: Spektrum AR6200.
Mods:
Du-Bro 40 size tailwheel bracket (broke the stock wire)
Du-Bro 1'' 60 size tailwheel
2oz. of lead velcroed behind the exit cooling hole for balancing
Quick and Simple 808 E-bay Keychain Cam Mount inside the cockpit
Building Notes:
Check and keep checking that your wing is straight!
I covered the cowling instead of going through the hassle of find a Cub Yellow paint.
Black/White Checkerboard UltraCote on the bottom of the wings for some VERY nice contrast!
Use at least 2.5'' wheels (I use Du-Bro lightweight) for grass. Also glue those securing nuts on so the wheel dosan't fly off!
Covering Used:
Cub Yellow Solarfilm (Aerofilm) from StevensAero
Black/White Checkerboard Ultracote
Pictures:
WAGliderGuy is online now Find More Posts by WAGliderGuy
Old Jan 27, 2011, 07:11 AM
big bird is offline
Find More Posts by big bird
Belfast / Dublin
Joined May 2004
nice work - and a very good build video - really well done!
any flight vid?
bb
big bird is offline Find More Posts by big bird
Old Jan 29, 2011, 03:12 PM
Airliner Builder
Joined Feb 2010
Hi, thanks!
Look at the post above for the maiden flight and this aerobatic video I made:
Sig Four-Star 20 Sport Aerobatic Flight (HD Ground, Onboard and Altimeter) (2 min 49 sec)
Question Sig Four Star 20ep Eflite Motor? JBAZ4 Electric Plane Talk 6 Jan 23, 2012 08:58 PM
For Sale Sig Four Star 40 built from Kit Plug and play/RTF dieter88 Aircraft - Fuel - Airplanes (FS/W) 1 Jan 11, 2011 05:52 PM
Off Site delete smileyz Aircraft - Fuel - Airplanes (FS/W) 0 Nov 12, 2010 12:49 AM
Sold Sig Four Star 60 NIB Kit on EBAY JBAZ4 Aircraft - Fuel - Airplanes (FS/W) 2 Nov 05, 2010 09:33 PM
Sold Sig Four Star 60 KIT NIB noveldoc Aircraft - Fuel - Airplanes (FS/W) 6 Sep 21, 2010 12:22 PM
