Old Nov 15, 2010, 03:30 PM
Foskje is offline
Find More Posts by Foskje
Norway
Joined Dec 2009
Build Log
My design and my first build from scratch
I thought that making a build log might be better than writing a build blog...
-and there is more to come soon!
copied from my blog:
-----------------------------1.------------------------------------
My project
Well this is my project, building my first plane from skratch, my drawings, my opinions and for now, all my ideas.
I have buildt one plane ever, a FF-supernova from rcfoamfighters and after that plane was totaled, I decided to build a plane from skratch.
Name: Jager.jpg Views: 20 Size: 41.5 KB Description:
I designed my plane using google sketchup.
Description:
Description:
From the computer to pen and paper... then cutting
Description:
Description:
After cutting the foam
Description:
Description:
A bit more hot wire cutting
Description:
Description:
sanding and add vertical stabilisators and motor mount with hot glue
Description:
Description:
Adding electronics, this plane would not fly, the torque from the engine made it hard to take off. I did also add bigger flaps.
Description:
Description:
Finally a plane that was able to takeoff!
Description:
Description:
The plane DID FLY (!!!) on first try!
In the near future I will find a CG I like, and then try to move the wings a bit more forward, cause the flaps have to be a bit trimmed up to conteract the nose to go down... moving the CG further back will make the plane unstable and it goes up and down to easy! (if i made the flaps smaller that problem might be gone??!?)
I might begin 2. layout tomorrow (23.oct) - I will build the plane with edfs this time!
-----------------------------2.------------------------------------
Update 23. october.
I have edited my design, layout number 2 will look quite like this:
Description:
It's a bit longer (160cm vs. 130cm), a bit larger wingspan (140cm vs. 120cm) - mostly because it will be heavier (1470grams vs. 720grams). I will cut it in pieces and then glue all parts together to make the build as easy as possible. I hope to start building next weekend
-----------------------------3.------------------------------------
Update 29 oct. 2010
Discussion / Posted by Foskje / Oct 29, 2010 @ 11:11 PM / 905 Views / 2 Comments / Reply
Well, there has been a lot of hours, detailwork...
I hope to start building this weekend. I just have to modify my wirecutter first...
Name: Før bygging av 2.jpg
Description:
- This is how I the shape will be when #2 is finished.
Name: Før bygging deler 2.jpg
Description:
- This plane is so large that I have to make the parts separate before assembling in the end... (it makes the cutting easier to...)
Description:
My wirecutter - I will modify it a bit tomorrow... make the arm longer and more accurancy at the angle of the wire
-----------------------------4.------------------------------------
31 oct 2010
Started building #2 plane.
It was hard to print pictures in scale from sketchup, I used "print prewiew" to see if the figure was on a single page or not....
Description:
Todays work
Description:
2 pieces, 43 cm long.
Description:
I will mount the motors where the diameter is smaller
They are not sanded yet, but are still quite smooth. Perfect accuracy, down to a millimeter
-----------------------------5.------------------------------------
4. nov 2010
Well, yesterday i cut out some more parts:
1.
Description:
2.
Description:
3.
Description:
4.
Description:
5.
Description:
the "yardstick" is 1 meter.
Foskje is offline Find More Posts by Foskje
Old Nov 15, 2010, 11:47 PM
Dark Angel is offline
Find More Posts by Dark Angel
skunkworks
Dark Angel's Avatar
United States, CA, Clovis
Joined Apr 2008
Wow intense you are doing a great job keep it up and keep it coming!
Dark Angel is offline Find More Posts by Dark Angel
Old Nov 16, 2010, 12:01 PM
Foskje is offline
Norway
Joined Dec 2009
made some wings, organizing wires... and sanded the foam.
Pictures:
Before sanding:
Description:
Wires and setup:
Description:
Description:
Description:
Now it's time to add wings to the body.. tape canards, more glue add wheels and so on....
Old Nov 18, 2010, 03:48 PM
Foskje is offline
Norway
Joined Dec 2009
Finally I've added wings !! - it really starts looking like a plane!
- it's huge!
Description:
I think this plane will look nice when I add some colors to it! - but I think I'll have a maiden before taping...
Description:
Lenght: 152, wingspan:135
Description:
I hope it will get enough air through the edf's... the area is approx 110% of the fan area (or duct area??)...
Description:
I will use two servos for each flap, to make it strong..
I did a thrust test, it can not climb vertical, but I still got plenty of thrust!
- the weight without batteries is ca 1500 grams, and I will expect around 1900 grams when it's done. I did not measure the trust but I think it was around 1500 grams...
Old Nov 21, 2010, 10:38 AM
Foskje is offline
Norway
Joined Dec 2009
I just realised this thread should be placed in "Scratchbuilt EDFs" , is there a way to move this whole thread?
Old Nov 21, 2010, 10:44 AM
Foskje is offline
Norway
Joined Dec 2009
- more pics:
I got a problem; - I need a steerable front wheel, but the batteries is just ahead the whhel and they make the wire bend! - I need to find a way to make the front wheel setup strong enough and still be steerable.
The plane itself is almost finished, I need to solve the front wheel problem, and then it's time for first flight!
Description:
Description:
Description:
I like it !!!
Old Nov 21, 2010, 04:34 PM
j3tman is offline
Find More Posts by j3tman
Were..is..my..Super..Suit ..
j3tman's Avatar
United States, NE, Papillion
Joined Sep 2009
That plane looks like its ready for some serious dogfighting.
j3tman,
j3tman is offline Find More Posts by j3tman
Old Nov 21, 2010, 11:50 PM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
It kinda reminds me of a wraith dart from Stargate Atlantis
specially the first picture
Mal
kushal_22 is offline Find More Posts by kushal_22
Old Nov 22, 2010, 09:41 AM
Foskje is offline
Norway
Joined Dec 2009
-it's huge too... I hope it will fly as good as my test plane (in the start of this thread)...
i'm exited about the thrust with full loaded batteries and if the edfs get enough air- the intake is big enough...
if it is... I think I'll add thrust vectoring...?!? - then it will be a really dogfighter!!!
"kushal_22"
"wraith dart"
well, a bit, - I did watch star-wars 1-6 while I designed it, so It might have affected my design - made it more "science fiction"
Tanks for your comments!
Old Nov 26, 2010, 05:45 AM
Foskje is offline
Norway
Joined Dec 2009
Taxiing.mp4 (1 min 57 sec)
Old Nov 28, 2010, 09:52 AM
Foskje is offline
Norway
Joined Dec 2009
My first crash!
well, I had my first chrash today! :s I went to a nearby football ground, went to one end and was ready for some taxing before takeoff. I would test takeoff speed and how it is in the air before I put trottle to max. It went well, trottle up, the plane was gaining speed. I could se the planelift off the ground, so I turned the trottle off. The plane had a lot of speed, and did not stop until there was a tree in the end of the football ground...
See my pictures for damage
Description:
Description:
Description:
The glue is drying while I write this update - I will be flying in a couple of days! (-I hope!)
Old Nov 30, 2010, 11:41 AM
Foskje is offline
Norway
Joined Dec 2009
My secound crash
Well I have been out trying to takeoff, nice start, but the plane began jumping when I tried to lift off, the front tires went off and the nose broke...
Description:
Description:
What could be wrong???
- I will try more speed and elevators that will be as wide as possible.
I hope it will make a positive difference!
- next try in a couple of days...
Old Dec 01, 2010, 12:00 AM
kushal_22's Avatar
Kamloops
Joined Dec 2001
Thats one thing about foam breaks easy but repairs just about as easy
hope third try goes better for ya.
Mal
Old Dec 01, 2010, 09:15 AM
Foskje is offline
Norway
Joined Dec 2009
Yepp, easy to repair.. it only takes a lot of glue
I am repairing it just now, hope for third attempt tomorrow,
be prepaired for total crash and end of this project - or succsess!!!
- I hope to make a video about it!
Old Dec 02, 2010, 08:31 PM
airbagit13 is offline
Find More Posts by airbagit13
Plane Destroyer / Life Enjoyer
airbagit13's Avatar
Miami, FL
Joined May 2009
That looks great, good luck on tomorrow flight.
airbagit13 is offline Find More Posts by airbagit13
Yippee! My first finished scratch build! WLJayne Scale Kit/Scratch Built 52 Dec 01, 2010 06:32 AM
Discussion Build a plane from scratch! SolarPlane1011 Beginner Training Area (Aircraft-Electric) 11 Nov 08, 2010 11:02 AM
Discussion Suggestions for my first scratch-build s_mack Foamies (Scratchbuilt) 22 Oct 11, 2010 02:41 AM
Rave My first scratch build EZE-Fan from RCM&E hb888 Electric Ducted Fan Jet Talk 0 Aug 17, 2007 01:45 PM
My first Design Scratch Build Project Heather Electric Plane Talk 20 Jul 22, 2001 11:03 AM
