This thread is privately moderated by S11D336B, who may elect to delete unwanted replies.
Old Jun 13, 2011, 04:24 PM
jginsandiego is offline
Find More Posts by jginsandiego
jginsandiego's Avatar
Joined Jun 2009
Originally Posted by Michael64 View Post
jginsandiego
Nice video and smooth flying as well, real nice video. Do you mine giving the details on what you flying as far as equipment and it looks like a quad right.
Thanks Michael64
Here is a picture and build log link it has evolved over time But I am real!!!! happy with set up as pictured only differance is there were 3 camras on it in the picture now the Go pro is in the center and the only one. I took FPV camra and TX off untill I get my own goggles for now I fly it while looking at it.
WAITING ON GPS TO TEST FLYING IT ON MISSIONS BY IT SELF ALSO.
http://www.rcgroups.com/forums/showthread.php?t=1410229
jginsandiego is offline Find More Posts by jginsandiego
Old Jun 13, 2011, 04:50 PM
AeroVideoUS is offline
Find More Posts by AeroVideoUS
aka Helidaho
AeroVideoUS's Avatar
United States, ID, Boise
Joined Jun 2010
Hey Earl,
Yes, definitely not your scenic type video :-) Although it is a testament to how well the Hoverfly handles. You're correct, smooth, low forward flight can be tricky via FPV, the Hoverfly helps a lot.
I have to admit I'm not using the Hoverfly OSD feature though. As much as I would like to use it, I REALLY need to see my RSSI signal strength for my own peace of mind so I'm using a Cyclops Easy OSD. It's not really super accurate, as you can tell, but it is helpful. On a side note, when you first use an OSD don't get caught up looking at it too much, ask me how I know
You definitely want to mostly fly forward when flying FPV, hovering is difficult as it's tough to judge how much you're moving.
3D cameras and goggles would be interesting to try. I've read some people that are experimenting with that now.
Paul
Originally Posted by Earl E Adobtr View Post
Ah, a video only an enthusiast could love - great ground hugging technique - harder than it looks. OSD overlay is nice and clear with plenty of info - hopefully once George gets over the GPS hurdle he can add a little more to the HFP screen.
Looks like forward flight is the way to learn fpv. I've been trying to hover and I end up going backwards because of the lack of depth perception. I think some of us older guys could really benefit from 3D but it's just not there yet in terms of price/weight/quality.
AeroVideoUS is offline Find More Posts by AeroVideoUS
Old Jun 13, 2011, 04:57 PM
aka Helidaho
Joined Jun 2010
Hey Matt,
I'm using an elcheapo HK 900MHz 800mw FPV camera/VTx/VRx combo.
I was having some serious video and control range issues when I was on my 2.4GHz Spektrum control gear. Everything seems to work a lot better now that I'm on the UHF Chainlink control gear. My video is a lot clearer and I have more range with a lot less static and dropouts.
I do use a Vee antenna on the quad and a Patch antenna on the ground. I just added an Eagle Eyes diversity system on the ground so I can use two receivers, one with the patch and one with the stock omni antenna. This works especially well when I need to fly behind me.
Also, I use channel 3 on the system which I think is a little higher than 900Mhz. I used channel 0 which is 900Mhz and it was TERRIBLE.
Paul
Originally Posted by rallymatt View Post
Paul,
What FPV video tx/rx are you using? I'm currently using a 200mw 900mhz with a vee on the heli and a regular ducky antenna on the RX and would like more range.
Thinking of using a 500mw 900mhz instead.
Old Jun 13, 2011, 05:19 PM
aka Helidaho
Joined Jun 2010
Originally Posted by kjella View Post
hello her i some recording to a movie some people are making in my town:http://vimeo.com/24937063
it was very windy that evening ,but i think the octo made it good
Good stuff kjella! Some epic scenery and some nice shots. The actor kind of cracked me up but it was a fun video to watch. Way more interesting than mine.
Paul
Old Jun 15, 2011, 11:21 AM
aka Helidaho
Joined Jun 2010
Here is the counter part to my OSD video although this has been edited and stabilized with iMovie
Hoverfly Pro FPV Flying (3 min 21 sec)
Paul
Old Jun 15, 2011, 11:37 AM
S11D336B is offline
Find More Posts by S11D336B
S11D336B's Avatar
USA, FL, Winter Springs
Joined Apr 2006
Nice! That was a really good looking pan in the middle of the video!
http://www.youtube.com/watch?v=5-k3OXPZzJ4
Paul
S11D336B is offline Find More Posts by S11D336B
Site Sponsor
Old Jun 15, 2011, 11:47 AM
Joined Jun 2009
Paul
Which frame are you using for this? I know you had a couple. Are you useing a fixed mount camra for goggles or a gimbal?
I just ordered my camra mount so I can get started with that feature and use the HF out put instead of fixed mount.
http://www.nghobbies.com/cart/index....roducts_id=649
Old Jun 15, 2011, 12:12 PM
rallymatt is offline
Find More Posts by rallymatt
rallymatt's Avatar
Grand Rapids, MI
Joined Aug 2010
Paul
Great work!
rallymatt is offline Find More Posts by rallymatt
Old Jun 15, 2011, 01:05 PM
aka Helidaho
Joined Jun 2010
Thanks! I think I was at about 400 ft. I had the camera pointed a little to low however, I would have liked to have a nice straight horizon
This is my home made aluminum arm frame with center plates from Vic-20 here on RCGroups. The GoPro is on a fixed mount. I also have a separate FPV cam on it's own fixed mount. I would like to add a gimbal but this small frame I'm using is at its weight capacity!
That's a nice looking little GoPro gimbal, report back on how well it works!
Great work!
Thanks! Now if I just had the nerves to fly with action going on around me like you do...
Paul
Old Jun 15, 2011, 01:47 PM
thefokker is offline
Find More Posts by thefokker
Team White Llama
thefokker's Avatar
USA, IL, Mundelein
Joined Mar 2005
Wow Paul great video love the pan. You have some beautiful scenery around you.
thefokker is offline Find More Posts by thefokker
Old Jun 15, 2011, 02:21 PM
Joined Jun 2009
Paul[/QUOTE]
Will do. I found it in someone elses post here on the HF Board.
Old Jun 15, 2011, 03:34 PM
Stacky is offline
Find More Posts by Stacky
Pants first, then shoes
Joined Jan 2011
Paul, really nice flying, one day I hope to catch up to you guys. Love it
Stacky is offline Find More Posts by Stacky
Old Jun 15, 2011, 08:14 PM
aka Helidaho
Joined Jun 2010
Thanks! It is quite scenic in Idaho. I hope to get some really nice stuff when I go camping.
I look forward to your videos with it!
Thanks! I really appreciate it. FPV is where it's at You'll pick it up in no time.
Here's my latest flying video from last night after work in the foothills:
HoverFly Pro FPV Flying in the Foothills (5 min 10 sec)
Paul
Old Jun 16, 2011, 06:07 AM
Paulfpv is offline
Find More Posts by Paulfpv
Joined May 2011
Paul,
Could you please tell me what fpv gear you are using and what camera. Is it a Gopro? I have a Gopro and was thinking of buying Fatshark fpv gear, like this one:
http://www.hobbyking.com/hobbyking/s...dProduct=15126
Also what motors and props are you using?
VERY NICE VIDEO BTW!
Regards
Paul
Paulfpv is offline Find More Posts by Paulfpv
Old Jun 16, 2011, 07:53 AM
ThaiskyDigital is offline
Find More Posts by ThaiskyDigital
Thailand
Joined Apr 2006
ควอต กับงานบวชที่สุราษฎร์ธานี (2 min 3 sec)
This is my HF Pro board that got repair from HF. I use it with very small frame then if can fly in a big group of people.
ThaiskyDigital is offline Find More Posts by ThaiskyDigital
Cool ASH-31 in flight video iflytailies Scale Sailplanes 7 Nov 01, 2010 04:45 PM
Discussion EXI450 Flight Video and crash auto rotation spllouder Aerial Photography 3 Oct 30, 2010 01:46 PM
Discussion EPP Falcon jet a year in the making w/ build video and maiden flight video! j3tman Scratchbuilt EDFs 6 Oct 13, 2010 06:37 AM
Gallery Video Gallery bakon 3D Flying 0 Oct 10, 2010 07:30 PM
Question maximum video size in the video gallery? Happy|Harry Site Chat 1 Jun 13, 2006 03:26 AM
