Old Mar 12, 2011, 09:21 AM
skyhawk newbie is offline
Find More Posts by skyhawk newbie
Not a newbie anymore..
skyhawk newbie's Avatar
Ireland, Cork
Joined Oct 2010
Originally Posted by polarbear75 View Post
Hi guys I see some really great custom paint in the phoenix, Andreas,it looks beautiful.I as wondering, what kind pf paint could I use?Can the paint used for plastic static model do the trick, using an airbrush?
My respects to you all.
I use Plasti-Kote Projekt Paint...Fast Dry Enamel , Water Based...
Can buy it in B+Q
skyhawk newbie is offline Find More Posts by skyhawk newbie
Old Mar 13, 2011, 12:43 PM
AndreasXX is offline
Find More Posts by AndreasXX
Sweden!!
AndreasXX's Avatar
Sverige, Gävleborgs Län, Gävle
Joined Mar 2011
Tnx PolarBear!!
i used watherbased airbrush paint, and it worked like a sharm
but it`s hard to get the paint to stick to the surfase, best result if you use a non glossy base color before you paint it in the color you want...
Good luck to you
//Andreas
AndreasXX is offline Find More Posts by AndreasXX
Old Mar 19, 2011, 08:34 AM
Sweden!!
AndreasXX's Avatar
Joined Mar 2011
Hello....
were shopuld i have CoG? 70 or 75mm ?
//Andreas
Old Mar 19, 2011, 11:13 AM
Ireland, Cork
Joined Oct 2010
Originally Posted by AndreasXX View Post
Hello....
//Andreas
set mine at 70mm ...
Using a 2200mAh Li-Po , added 20grams to the tail...
Nose still pionts down slightly ...
Old Mar 19, 2011, 12:55 PM
Sweden!!
AndreasXX's Avatar
Joined Mar 2011
hello!
ok i use the same CoG added 25g to the tale
I thought it would be faster then it is....but it is much better then before
i took some pic`s on my modification, i`ll publish them later
//Andreas
Old Mar 19, 2011, 01:14 PM
Ireland, Cork
Joined Oct 2010
hello!
//Andreas
Did you fit the Turnigy 2836 1000kv motor ?
What Prop did you use in the end 10x6 or the 9x5 ??
Old Mar 19, 2011, 01:47 PM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
out of stock at US warehouse
When will it be restocked?
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Mar 19, 2011, 01:53 PM
Ireland, Cork
Joined Oct 2010
R2hobbies have them is stock...
http://www.r2hobbies.com/eng/proddet...pl2402005_mode
Also have the ARF .. Bottom of page left side..
Could try a E-Bay search...
Old Mar 19, 2011, 04:55 PM
BarnOwl is offline
Find More Posts by BarnOwl
Heli's and gliders, what else?
BarnOwl's Avatar
Nederland, GE, Slijk-Ewijk
Joined Apr 2006
Then you might as well get them from the HK warehouse:
http://www.hobbyking.com/hobbyking/s...dProduct=13994
BarnOwl is offline Find More Posts by BarnOwl
Old Mar 20, 2011, 03:39 AM
Sweden!!
AndreasXX's Avatar
Joined Mar 2011
hello!
skyhawk:
i`m using that motor with a CAM Carbon 9x5.....but i thought it would go faster!
maybe a 9x6 ?
//Andreas
Old Mar 20, 2011, 04:00 AM
Ireland, Cork
Joined Oct 2010
hello!
skyhawk:
maybe a 9x6 ?
//Andreas
A 9x6 should make it fly faster...
Just remember the T2836 1000kv motor is only a 300Watt motor ,
so best test with a Watt meter . . .
Old Mar 20, 2011, 08:08 AM
Sweden!!
AndreasXX's Avatar
Joined Mar 2011
hello!
ok...test it 1:st then!
only using the motor to climb, aprox 15-20 seconds.
//Andreas
Old Mar 20, 2011, 10:23 AM
Ireland, Cork
Joined Oct 2010
hello!
//Andreas
You should be fine then...
Old Mar 23, 2011, 05:12 PM
Sweden!!
AndreasXX's Avatar
Joined Mar 2011
hello!
now i have changed to a 9x6 folding and tested it out...it takes 351W and 31A at full throttle....not to bad
//Andreas
Old Mar 23, 2011, 07:18 PM
Ireland, Cork
Joined Oct 2010
hello!
//Andreas
Where did you get the 9x6 prop...
got a link...
I was out on Sunday Last...
Had my first go at Slope Soaring with the Phoenix..
Handled very well, hand launched into the wind.Nice steady climb , court the lift and it was away..only need to use the motor once and that was only because I came to far into the hill to get lift...
Even the guy's at the club were impressed at how gentle
it was in flight for a "cheap Glider"
Discussion Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 KillerCut Electric Sailplanes 18 Nov 18, 2015 06:33 AM
For Sale HK Phoenix 2000 glider blk822 Aircraft - Electric - Airplanes (FS/W) 4 Aug 23, 2011 07:21 PM
Discussion Still having electric problems with my hobbyking Phoenix 2000, Crashvideo kyrkbymannen Electric Sailplanes 3 Jul 09, 2011 07:34 PM
Discussion hobby king Phoenix 2000 EPO Composite R/C Glider doomracing Electric Sailplanes 3 May 31, 2011 10:09 PM
