Old Mar 08, 2011, 07:14 AM
skyhawk newbie is offline
Find More Posts by skyhawk newbie
Not a newbie anymore..
skyhawk newbie's Avatar
Ireland, Cork
Joined Oct 2010
Originally Posted by cvanscho View Post
I wouldn't set the CoG further forward of the manufacturers recommended point. Usually such marks are extremely conservative (i.e. too far forward). With time you will probably finalise on a setting that is considerably back from 70 mm to achieve a neutral trim. 65 mm may be unflyable.
Hi Chris..How goes with you..
So set for 70mm as per manual...
skyhawk newbie is offline Find More Posts by skyhawk newbie
Old Mar 08, 2011, 07:17 AM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
I'm great tanx! Day off, so going for a quick fly now
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Mar 08, 2011, 07:53 AM
AndreasXX is offline
Find More Posts by AndreasXX
Sweden!!
AndreasXX's Avatar
Sverige, Gävleborgs Län, Gävle
Joined Mar 2011
Custom Paint...
hello!
here is a picture of my Phoenix, custom paint and a little moore grunt!
Description:
tonight i´ll install the new motor and esc....
Turnigy 2836 1000kv
Hobbyking Blue series 40A ESC 4A/5V bec
40mm/4mm foldingprop spinner
9x5 CAM Carbon propeller
I hope i´ll be satisfied....also got a 10x6 prop...but i didn´t like that it will be too much 4 the motor....but if i only use it 4 like 5-10 seconds to climb it might work right?
// Andreas (Sweden)
AndreasXX is offline Find More Posts by AndreasXX
Old Mar 08, 2011, 08:28 AM
Ireland, Cork
Joined Oct 2010
Originally Posted by AndreasXX View Post
hello!
Attachment 3852976
// Andreas (Sweden)
Hi Andreas... Your Phoenix look's Wicked..
What did you set your CofG at...as Manual 70mm??
Old Mar 08, 2011, 09:01 AM
Sweden!!
AndreasXX's Avatar
Joined Mar 2011
Hello!
Yes i`m pretty pleaced myself
hmmmm.....yes as the manual, there were "spots" on each wing that marked CoG...
i had to mix in dive to throttle, mine almoast made a looping when i aplied fukll throttle....and it banked hard to the right aswell....so i pointed the engine down and left (orginal engine)
ill place the new motor straight and add moore down and mix in a little left...
//Andreas
Old Mar 08, 2011, 09:10 PM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
My Radian, which is very similar to the Phoenix, has a very noticeable amount of down and left bias built into the motor mount. That is preferable to correcting it with elevator and rudder trim because the latter causes increased drag.
kaptondave is offline Find More Posts by kaptondave
Old Mar 09, 2011, 07:50 AM
Ireland, Cork
Joined Oct 2010
Well here it is a last.....
Phoenix 2000 Glider.wmv (3 min 12 sec)
Old Mar 09, 2011, 09:35 AM
Sweden!!
AndreasXX's Avatar
Joined Mar 2011
hey skyhawk!
looks good
are you using the flaps as airbrake instead of flaps?
is it ok to only use 2 screws to fit the motor?...or do i have to use 4...?
did you install your motor straight or directed some were?
//Andreas
Old Mar 09, 2011, 09:57 AM
Joined Jan 2010
Same question as Andreas. Why are your flaps deflecting upward?
Old Mar 09, 2011, 10:27 AM
Ireland, Cork
Joined Oct 2010
hey skyhawk!
looks good
//Andreas
I'd use 4 scew's for the motor....
Motor is as straight as I could get it , with the new Fiberglass firewall..
Never used Flaps before... So this is totaly new to me...
The Flaps are connected to the landing gear plug on my AR500 Rx
using the landing gear switch on my DX5e Tx...
Could only get them to rise up ...wire in the right way..
Why are they ment to come down....
Old Mar 09, 2011, 10:45 AM
Joined Jan 2010
Originally Posted by skyhawk newbie View Post
The Flaps are connected to the landing gear plug on my AR500 Rx using the landing gear switch on my DX5e Tx...
Why are they ment to come down......
Flaps always deflect down. The idea of flaps is to increase drag to slow the plane down while also increasing lift to lower the stall speed. If your radio has a Flap channel use that instead of the Gear channel. If not you can turn the flap servos around, or buy a servo reversing module.
Old Mar 09, 2011, 10:52 AM
Ireland, Cork
Joined Oct 2010
Can I not just turn the plug around and reverse the polarity...
Old Mar 09, 2011, 10:58 AM
BarnOwl is offline
Find More Posts by BarnOwl
Heli's and gliders, what else?
BarnOwl's Avatar
Nederland, GE, Slijk-Ewijk
Joined Apr 2006
Why not just reverse the gear channel?
BarnOwl is offline Find More Posts by BarnOwl
Old Mar 09, 2011, 11:04 AM
Ireland, Cork
Joined Oct 2010
That would be the easyest way...
But you cann't reverse the landing gear switch on a Spektrum DX5e..
Old Mar 09, 2011, 11:19 AM
BarnOwl is offline
BarnOwl's Avatar
Joined Apr 2006
Ok, didn't know that........
Discussion Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 KillerCut Electric Sailplanes 20 Jun 22, 2016 07:23 PM
For Sale HK Phoenix 2000 glider blk822 Aircraft - Electric - Airplanes (FS/W) 4 Aug 23, 2011 07:21 PM
Discussion Still having electric problems with my hobbyking Phoenix 2000, Crashvideo kyrkbymannen Electric Sailplanes 3 Jul 09, 2011 07:34 PM
Discussion hobby king Phoenix 2000 EPO Composite R/C Glider doomracing Electric Sailplanes 3 May 31, 2011 10:09 PM
