Old Oct 19, 2011, 09:39 PM
Toppers is offline
Find More Posts by Toppers
Toppers's Avatar
Canada, ON, Oakville
Joined May 2008
Originally Posted by Fugitive_Bill View Post
Be sure they don't forget to strap it to a rocket sled and run it into the side of mountain - it's the only way to be sure!
B!LL!
Hillarious
Toppers is offline Find More Posts by Toppers
Old Oct 19, 2011, 09:45 PM
delperena is offline
Find More Posts by delperena
Joined Feb 2006
Enlightening
H2SO4,
You enlightened me. Thank you.
To All,
I apologize for generating an outrage. Thanks for the thread.
Del
delperena is offline Find More Posts by delperena
Old Oct 19, 2011, 10:42 PM
Fugitive_Bill is offline
Find More Posts by Fugitive_Bill
CURIOSITY Has Landed!
Fugitive_Bill's Avatar
Sydney, Australia
Joined Jul 2005
No need to apologize DEL, I for one just couldn't resist having a bit of dig at your scientific/engineering side of it! - I'm the one who should be sorry I guess.
But all most of us doing, from what I've seen is putting the ply board meant for the slope spinner inside the fuse and the motor mounted to that, with metal plate sandwiched on the outside of fuse, no glue - Well I use a little just to tack/line things in place while screwing it together. (See my and other pics a few pages back).
B!
Fugitive_Bill is offline Find More Posts by Fugitive_Bill
Old Oct 20, 2011, 01:08 AM
headlessagain is online now
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
I thought one the main reasons for adding a plywood disc in front of the motor was to insulate the plastic from heat damage caused by extended motor runs
This problem will be heightened if a more heavier watt hungry/hotter motor is used. The heat deforms and weakens the plastic firewall and in extreme circumstances allows the motor to break free in a spectacular fashion
Andy
headlessagain is online now Find More Posts by headlessagain
Old Oct 20, 2011, 09:43 AM
Toppers is offline
Toppers's Avatar
Joined May 2008
Agreed... I think the biggest problem with the stock set up is the prop is far to big from that motor causing it to seriously overheat.
Old Oct 20, 2011, 11:41 AM
skyhawk newbie is offline
Find More Posts by skyhawk newbie
Not a newbie anymore..
skyhawk newbie's Avatar
Ireland, Cork
Joined Oct 2010
9x6 . .
skyhawk newbie is offline Find More Posts by skyhawk newbie
Old Oct 20, 2011, 01:39 PM
grumman1 is offline
Find More Posts by grumman1
Rochester, New York
Joined Jun 2009
Hi Guy's
I've been reading this thread and decided a nice Christmas present from my wife would be the Phoenix 2000. While I'm at it I might as well have her include a new motor and prop.
Decided to go with the NTM 28-26A motor, but don't know what prop-spinner to include.Any suggestions ?
Thanks in advance,
Pat
grumman1 is offline Find More Posts by grumman1
Old Oct 20, 2011, 02:20 PM
Ireland, Cork
Joined Oct 2010
Originally Posted by grumman1 View Post
Hi Guy's
Thanks in advance,
Pat
Not to sure about the NTM 28-26a...
Alot of the guys here have the Hobbyking 2836 1000kv 300watts...
that motor with a 40amp ESC running a 9x6 prop....
Old Oct 20, 2011, 04:04 PM
bluegsxr6 is offline
Find More Posts by bluegsxr6
Joined Oct 2011
Prop Selection
do you have to buy a new spinner to get the 9 x 6 blades or is there a direct replacement? If so which one
Ty
bluegsxr6 is offline Find More Posts by bluegsxr6
Old Oct 20, 2011, 04:17 PM
Ireland, Cork
Joined Oct 2010
Ty
Most 9x6 props should fit the stock spinner....
Old Oct 20, 2011, 04:41 PM
Joined Oct 2011
looks like there are yoke sizes and 8mm might be the choice.
Old Oct 20, 2011, 04:59 PM
Philosan1 is offline
Find More Posts by Philosan1
It's supposed to fly that way?
Philosan1's Avatar
Spain, AL, Zurgena
Joined Mar 2011
You could try this spinner from Giantcod :
http://www.giantcod.co.uk/40mm-40mm-...-p-403348.html.
I've got one fitted to the NTM35-30 motor on my Phoenix, and they also do the accessory kit:
http://www.giantcod.co.uk/advanced_s...+35-XX&x=0&y=0
At least they appear to have both in stock!
The blades supplied with the Phoenix are 9x6, just don't break them as nobody seems to have them in stock!
Philosan1 is offline Find More Posts by Philosan1
Old Oct 20, 2011, 05:17 PM
Joined Oct 2011
I use apc props on all my other planes so i found this replacement adapter and props
adapter
http://www.graysonhobby.com/catalog/...fts-p-405.htmland props
http://www.graysonhobby.com/catalog/...rop-p-722.html
Old Oct 20, 2011, 05:49 PM
Ireland, Cork
Joined Oct 2010
The Blades I got with my Phoenix where 10x6...
Giantcod sell the Folding Propeller blades (pair) 8mm Root 1.80..
or look on E-Bay...
Old Oct 20, 2011, 06:38 PM
grumman1 is offline
Rochester, New York
Joined Jun 2009
thanks for the response . the NTM is lighter then the turigy 2836. and from what I gather does the same job. A lighter plane is a Happy plane
Pat
Discussion Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 KillerCut Electric Sailplanes 20 Jun 22, 2016 07:23 PM
For Sale HK Phoenix 2000 glider blk822 Aircraft - Electric - Airplanes (FS/W) 4 Aug 23, 2011 07:21 PM
Discussion Still having electric problems with my hobbyking Phoenix 2000, Crashvideo kyrkbymannen Electric Sailplanes 3 Jul 09, 2011 07:34 PM
Discussion hobby king Phoenix 2000 EPO Composite R/C Glider doomracing Electric Sailplanes 3 May 31, 2011 10:09 PM
