In this thread there are pictures. So far it's been holding nicely. |
![]() I haven't seen anything on the M.A.C.I web site about flying FPV.. Sean |
I think That Toppers way would work fine. .it has for him..But I would of CA Glued the 2 plywood pieces together, then screwed them secure from the out side of the fuse... one screw on each side ,just infront of the vents... Sean |
Joined Feb 2006
Thanks for Your Response
However, my real world is far from ideal. Ten days ago, I received my Phoenix 2000 (HK USA). As most, I recognized the weak points, among those is the motor mount. No big deal, I thought, with a circular 1/8" plywood epoxied to the inside of the nose should do it. But epoxy did not work for nor JB Weld. To BarnOwl, thanks for "EpoxyFlooding" idea, although I am somewhat skeptical that epoxy really bonded to the plastic fuselage. I did a mallet test. A plywood that is not bonded to the inside of the fuselage, to me, does not serve any structural support. I don't think it can be considered a firewall (consult a structural engineer to confirm. No, I am not one). It is but a spacer. My research led me to Devcon Methacrylate (Plastic Welder). I just purchased some from Amazon. I will gladly report if it works. If, Devcon does not work me, I will follow "skyhawk newbie's" approach - the best option I can see. Del |
Not sure why anyone would take a mallet to a new glider to test it's structural integrity.... that's a bit like taking a new car and finding a wall or tractor-trailer to hit?
Planes and especially gliders need to be light, and so I would recommend keeping your reinforcements to a minimum. In my limited experience I find hot glue and gorrilla glue bond best to plastic... but I have only tried the mainstream glues (CA, weldbond, epoxy, canopy glue, wood glue, gorrilla glue, hot glue). Toppers |
Oh I forgot... talking of ideal RC glider worlds... my third flight on my first day flying the Pheonix... I was trying flaps and slowed the glider to a stop about 15'-20' above the ground. It dropped it's nose and nose-planted HARD.... my firewall / spacer / motor mount was absolutely fine... the fuselage just aft of the nose was completely buckled and crumpled and now angled 20` down as well..... I was crushed too !!! But the beauty of the polyethene fuselage is I just pulled the nose forward and up and the crumple just popped back to the stock shape... no harm done. I was cautious of the nose strength for a flight or two... but many dozens of flights later had forgotten the incident altogether until you mentioned 'ideal world'...
Better to have a lighter more flyable plane / glider and fix the odd repair than reinforce it to death... that's why I fly foam planes... I've got pretty good repairing with epoxy and gorrilla glue. I just remembered... that same nose-in crash cracked a wing in half too (epoxied back as new...no problem). .....none of us live in a ideal RC world. Toppers |
Probably if I hit my nose cone hard enough the thing will come apart. The point is it is working: It gives me the extra structural integrity I need for the firewall. Even if it should come loose it is stil giving that extra strength so I am not worried about it at all.....
Joined Feb 2006
Yes, gliders should be light! Then why add something that does not serve a purpose but provide a false sense of security. Most say it (spacer modification) works. I am sure many would also say it works stock. |
![]() Theres ove 900 postes on this thread from Guy's that have been flying /crashing / Moding the Phoenix to there needs ... Re-read this WHOLE thread for a sensible soltion... Then go and see a structural engineer who fly's the phoenix 2000 glider...... what do you want for a $75 PnP Glider .... BLOOD.... .. |
Be sure they don't forget to strap it to a rocket sled and run it into the side of mountain - it's the only way to be sure! B!LL! |
If the contact patch between the motor and the surface in front of it is say effectively 25mm in diameter, the body of that motor rigidly prevents flexing of the firewall within the 25mm circle. Now add a plywood/aluminium/stone disc in front of the motor, say 30mm in diameter. It's held by screws just as tightly as the motor, even without a glue bond, and therefore it resists flexing of the plastic firewall in a backward direction. If the corresponding disc at the front of the firewall is also sufficiently wide and inflexible, then there'll be no flexing in that direction either. In the case of the Phoenix that's the ~40mm steel plate into which the stock motor screws are counter-sunk. Make the rear plate even wider, 35mm or 40mm, and there's correspondingly less flex again. The effect is achieved without glue, and it clearly means the disc touching the motor is more than a "spacer" on account of its bigger diameter. |
| Thread Tools | |
| For Sale HK Phoenix 2000 glider | blk822 | Aircraft - Electric - Airplanes (FS/W) | 4 | Aug 23, 2011 07:21 PM |
| Discussion Still having electric problems with my hobbyking Phoenix 2000, Crashvideo | kyrkbymannen | Electric Sailplanes | 3 | Jul 09, 2011 07:34 PM |
| Discussion Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 | KillerCut | Electric Sailplanes | 14 | Jun 06, 2011 09:57 AM |
| Discussion hobby king Phoenix 2000 EPO Composite R/C Glider | doomracing | Electric Sailplanes | 3 | May 31, 2011 10:09 PM |
