Old Sep 23, 2011, 11:15 AM
S.Bartfast is offline
Find More Posts by S.Bartfast
Australia, SA, Adelaide
Joined May 2011
Originally Posted by MikeC47 View Post
I also made a run to the Port-A-Potty after landing.
Are you allowed to fly FPV in these competitions?
Imagine that...
Winning "gold", "on the can"!
S.Bartfast is offline Find More Posts by S.Bartfast
Old Sep 23, 2011, 12:25 PM
traumkumy is offline
Find More Posts by traumkumy
France
Joined Sep 2011
Had a good flight this afternoon, good weather, almost no wind, 45 minute on the sme pack with a bit of accrobatics and some land & takeoff.
But on a approach, where my goal was not to land but just to slowly follow the landing zone, the propeler get stuck in the canopy and I had an emergency landing.
Did it already happen to you ? how to deal with this ? tape on the canopy ?
traumkumy is offline Find More Posts by traumkumy
Old Sep 23, 2011, 12:33 PM
skyhawk newbie is offline
Find More Posts by skyhawk newbie
Not a newbie anymore..
skyhawk newbie's Avatar
Ireland, Cork
Joined Oct 2010
I use a rubber band on all my powered glider canopys...
Holds the canopy on while in flight,
then the prop tight to the fuse when in transport....
skyhawk newbie is offline Find More Posts by skyhawk newbie
Old Sep 27, 2011, 03:58 PM
Cactusflyr is offline
Find More Posts by Cactusflyr
Joined May 2008
Hey there...sorry to hear about your Phoenix....did your canopy survive. i am looking for one as mine came off. any help will be appreciated. james
Cactusflyr is offline Find More Posts by Cactusflyr
Old Sep 28, 2011, 01:12 AM
France
Joined Sep 2011
Hi, no damage at all, just an unwanted landing on a cultivated field (I hate doing that).
Beside of that I started to rebuild the inside, the servo tray as moved back by around 10cm, I've made a small support to hold the turnigy receiver verticaly in the big hole just beside the servos, and a long battery holder (17cm) screwed in the bottom of the fuse. I hope to have no difficulties to adjust the CG between 80-85 with this new setup.
I received the new radio (T9X) new motor, new ESC, and new servo but as usual I miss lot off small bits to mount them... Even the 1.8mm nylon clevis don't fit
Old Sep 28, 2011, 02:26 AM
Freddan is offline
Find More Posts by Freddan
Sweden
Joined Sep 2007
I did some work on the Phoenix yesterday. With my newly installed flaps I wanted a separate bec. So yesterday I installed a 3A bec and converted to 2.4GHz. Works just fine and now I just have a couple of hours of programming to do on my 8FG.
I have one question though. Im using the Orange Fasst compatible Rx from Hobbyking. Its a full range receiver so it should be fine even for a gliders, right? I've just recently gone from MHz to GHz so I'm not super confident in this yet.
Freddan is offline Find More Posts by Freddan
Old Sep 28, 2011, 05:17 AM
Ireland, Cork
Joined Oct 2010
I've got a few Spektrum Orange Rx's for Hobbyking,never had a problem or lose of signal with and of them . .
Old Sep 28, 2011, 05:53 AM
Freddan is offline
Sweden
Joined Sep 2007
Sounds good. I've been flying a couple orange ones in other planes but a 2 meter glider can travel pretty far away but I don't think there will be a problem, mostly checking to be sure. There's no need for satellite antennas or anything? Just a standard full range receiver with properly placed antennas?
Do these orange (frsky) receivers feature any kind of signal quality checkup like I've read some receivers have? Like a led blinking if there have been any loss of signal during flight. The small manual doesn't say much.
Old Sep 28, 2011, 06:13 AM
BarnOwl is offline
Find More Posts by BarnOwl
Heli's and gliders, what else?
BarnOwl's Avatar
Nederland, GE, Slijk-Ewijk
Joined Apr 2006
Actually I bought a Turnigy 9x transmitter for my son a year ago and we often go flying together. I have never seen any problems so far with this tx. He has put the er9x software on it and it is a great tx! In some ways it even beats my Aurora 9.
He's using the $ 8,00 Turnigy rx. So I bet these Oranges will do the job just fine!
BarnOwl is offline Find More Posts by BarnOwl
Old Sep 28, 2011, 06:19 AM
Ireland, Cork
Joined Oct 2010
I my self have a few of the Orange Rx's from Hobbyking..
2 x 6 channel and 1x 9 channel..
Using them with a Spektrum DX5e and with a Futaba 9c fitted with a Spektrum Moduel , I use the R100 Satellite Receiver with all of them..
Using them in my Phoenix 2000 / ST Fox Gliders / Multiplex Cularis ..
Never had any trouble or lose of signal...
Yes they bind the same way as a propper Spektrum Rx,you get the blinking LED if at any stage you've lost signal...
Sean
Old Sep 28, 2011, 09:27 AM
BarnOwl is offline
BarnOwl's Avatar
Joined Apr 2006
Sean
Hey Sean, how do you like the Multiplex Cularis? Off Topic but I just wandered cause I'm looking for a bigger bird.....
Old Sep 29, 2011, 12:43 PM
Freddan is offline
Sweden
Joined Sep 2007
Ive been programming crow and camber and reflex and all sorts of neat stuff, but this is my first glider so I barely know what to do with them. Had 2 flights today and got the hang of it, I think.
I have a question for you. When gliding in normal mode, no flaps or anything. How should I setup the elevator? My elevator is pointing ever so slightly up and in low speed it keeps it altitude well and flies very slow. If I dive just slightly and let it pick up speed it will want to climb pretty much right away.
What am I looking for here? What should a glider do when I let go of the sticks? Continue level and slow or dive slightly but gain speed?
Since my plane climbs with speed Im guessing it might be slightly nose heavy, or is it supposed to do that?
Old Sep 29, 2011, 03:45 PM
France
Joined Sep 2011
I'm far from beeing an expert, but for me it should flight like a handlaunched glider, quite low speed (but not loo slow) and flat as possible. Without doing theses stall / accelerate / climb cycles. In fact FOR ME it should be possible to throw it with the radio off, and it should fly gently.
Also found the recommanded CG was to conservative, I found 80-85mm with PredimRC and tested 80 successfully, more flat run now.
BTW it should be interesting to know what airfoil profile is used on the wing for more precise prediction of the flying speed.
For my side I received my T9X and I'm failling to setup crow, aibrakes or camber adjustement for soaring.
Old Sep 29, 2011, 06:20 PM
Ireland, Cork
Joined Oct 2010
I've got my CG set at 70mm ,but I like to have the phoenix nose heavy as I mainly use it for slope soaring,which it does very well...
Flying her as a warm liner the phoenix will do what you want it to do,
great for mild acro,but not to much or you'll snap the wings off..
See my Vid
inside loops / out side loops / rolls / wing overs ..
Pheonix 2000 Glider. (6 min 29 sec)
No crow , just flaps and ailerons ... flaps on there own are enough for me to slow it down for landing.....
Old Sep 29, 2011, 06:50 PM
H2SO4 is online now
Find More Posts by H2SO4
christian theme park operator
H2SO4's Avatar
Australia, New South Wales, Sydney
Joined Jan 2011
Rapid pulling up in a fast nosedive generally means the plane is nose-heavy.
It's caused by the elevator being trimmed significantly upwards to counter the weight at the front during normal level flight. Once airspeed increases in a dive, so does the downwards force on the tail caused by the elevator angle. However, the weight of the nose remains constant, irrespective of airspeed, and the net result is that sharp pull-up.
There's nothing inherently wrong with "slightly nose heavy", but it deadens control response and makes the plane feel less agile. Aft CG increases maneuverability and "excitement", up to the point where a human cannot fly the thing without gyro assistance
H2SO4 is online now Find More Posts by H2SO4
Discussion Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 KillerCut Electric Sailplanes 20 Jun 22, 2016 07:23 PM
For Sale HK Phoenix 2000 glider blk822 Aircraft - Electric - Airplanes (FS/W) 4 Aug 23, 2011 07:21 PM
Discussion Still having electric problems with my hobbyking Phoenix 2000, Crashvideo kyrkbymannen Electric Sailplanes 3 Jul 09, 2011 07:34 PM
Discussion hobby king Phoenix 2000 EPO Composite R/C Glider doomracing Electric Sailplanes 3 May 31, 2011 10:09 PM
