Old Sep 22, 2011, 02:59 AM
skyhawk newbie is offline
Find More Posts by skyhawk newbie
Not a newbie anymore..
skyhawk newbie's Avatar
Ireland, Cork
Joined Oct 2010
Just 4 hex head screws..
Take my wings off every time..
skyhawk newbie is offline Find More Posts by skyhawk newbie
Old Sep 22, 2011, 03:46 AM
Freddan is offline
Find More Posts by Freddan
Sweden
Joined Sep 2007
Yeah the screws are pretty quick. But there's also 4 servo leads to connect and disconnect every time. At least if youre using flaps. But I still think.it's pretty quick.
Freddan is offline Find More Posts by Freddan
Old Sep 22, 2011, 04:49 AM
Ireland, Cork
Joined Oct 2010
Never set up crow,so only have 2 leads as my flaps and ailerons are on Y leads....
hardly ever use my Phoenix as a field flyer , I'm mainly on the slope's and
as a Slope Soarer I can highly recommend it . .
Old Sep 22, 2011, 08:46 AM
Toppers is offline
Find More Posts by Toppers
Toppers's Avatar
Canada, ON, Oakville
Joined May 2008
Come on.... it's not that bad.... an extra minute at the field.
In order to sneek my Pheonix on a family roadtrip vacation I took the wings apart and even removed the horizontal stab.... 5 mins total getting it back together.... 3 for the stab and 2 to get the wings back together and on the fuselage.... my wife didn't even know it was in the car !!! (Priceless )
Toppers is offline Find More Posts by Toppers
Old Sep 22, 2011, 10:46 AM
eosglider is offline
Find More Posts by eosglider
Addicted to lift
eosglider's Avatar
United States, FL, Miami
Joined Jul 2010
LOL...
The Sneakiness... (0 min 7 sec)
eosglider is offline Find More Posts by eosglider
Old Sep 22, 2011, 11:01 AM
S.Bartfast is offline
Find More Posts by S.Bartfast
Australia, SA, Adelaide
Joined May 2011
Yeah, maybe that's what I'll have to end up doing. I'm just not too keen on running those tiny screws in and out of that timber every time I fly, but if that's how its gots to be, that's how its gots to be.
S.Bartfast is offline Find More Posts by S.Bartfast
Old Sep 22, 2011, 11:25 AM
BarnOwl is offline
Find More Posts by BarnOwl
Heli's and gliders, what else?
BarnOwl's Avatar
Nederland, GE, Slijk-Ewijk
Joined Apr 2006
Well, I never have to unscrew it (yet) because I fly across the road....
But if you have to do it on a regular base, change them for hex screws, as skyhawk is suggesting. They are a lot easier to screw and unscrew then the philips ones the plane comes with.
BarnOwl is offline Find More Posts by BarnOwl
Old Sep 22, 2011, 01:12 PM
Ireland, Cork
Joined Oct 2010
You leave the wing in one piece . .
You just remove the wing.. 4 Hex head screw's
You don't take the wing apart... why would you . it's only 2 meters long...
Old Sep 22, 2011, 01:25 PM
Addicted to lift
eosglider's Avatar
Joined Jul 2010
There's a guy here that cut some foam out and used velcro between that wooden strip and the wing instead of those screws.
Old Sep 22, 2011, 06:52 PM
Ireland, Cork
Joined Oct 2010
I couldn't take the wing apart even if I wanted to..
I glued the wing halfs together as well as the white wing joiner and wooden strip was glued in place then covered with fiber tape .
Old Sep 22, 2011, 07:00 PM
Ireland, Cork
Joined Oct 2010
For the flaps / ailerons used these fittings . .
Fiber tape on the LE ...
used heat shrink over the clevises at the tail...
Old Sep 22, 2011, 09:36 PM
MikeC47 is offline
Find More Posts by MikeC47
Growing up is overrated
MikeC47's Avatar
Bellevue, WA, USA
Joined Nov 2009
Iíve been a little quiet lately
Hi everyone
I have been a little quiet the last two weeks, life has really gotten in the way of having fun lately. I thought I would check in and respond to a couple of the questions that I just read, it’s been a little while.
To club17 and salkeld17, I put cooling holes in the front of my fuselage, reinforced it with plywood like you were suggesting, and have had no problems with the strength of the front end. I would guess I have over 50 flights on mine and it is holding up great. I posted some pictures in this post. http://www.rcgroups.com/forums/showp...&postcount=557
Freddan, I cut a hole in the back part of the canopy to help with the air exhaust. I don’t know if it has helped, but putting it in the canopy didn’t affect the strength of the fuselage. Picture here. http://www.rcgroups.com/forums/showp...&postcount=368
S.Bartfast, I have to take the wing off and then take the wing apart each time I go to the field. I have an old Toyota MR2 and the wing won’t fit in my car in one piece. I hardened the screw holes in the wood piece on the wing with CA, and it is still holding up great after more than 50 flights. As for a case, I am looking into getting a small trailer for my bicycle, and I will probably build some type of case out of ľ” plywood to hold everything safely. I have never seen anything like that on the market, so if you find something I would be interested in seeing it. As far as the wing, it takes less than 5 minutes to assemble everything at the field, a little bit of a pain, but the flying is worth it.
And now to brag a little. On the 16th of this month I was able to get out to the field and had my best day of gliding ever. Over 52 minutes of thermal gliding after one 40 second motor run. Check on the September Big Sky contest and as of today a Phoenix 2000 is at the top of the leader board. Who would have thought that a $100 glider could do that?
MikeC47 is offline Find More Posts by MikeC47
Old Sep 23, 2011, 03:20 AM
Ireland, Cork
Joined Oct 2010
Well Done Mike. .
Thermal Leaderboard:
MikeC47
Glider/plane name: Phoenix 2000
Thermal or Slope: Thermal
Date and Time of flight: 9/16/2011 1:10PM
Duration of flight: 52:23, 40 sec motor run
Old Sep 23, 2011, 03:36 AM
BarnOwl is offline
BarnOwl's Avatar
Joined Apr 2006
Indeed! Gongrats Mike! So everybody that doubts the thermalling capacaties of the Phoenix 2000 should not be anymore....
Didn't you get a sore neck after such a long time? I once had a very long flight, but could not repeat it again with our Dutch summer.
Old Sep 23, 2011, 10:53 AM
MikeC47 is offline
MikeC47's Avatar
Bellevue, WA, USA
Joined Nov 2009
Thanks skyhawk and BarnOwl. Yes on the sore neck, I have to admit that when I lost the last thermal and couldn’t find any more I was not that upset. I also made a run to the Port-A-Potty after landing.
Discussion Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 KillerCut Electric Sailplanes 18 Nov 18, 2015 07:33 AM
For Sale HK Phoenix 2000 glider blk822 Aircraft - Electric - Airplanes (FS/W) 4 Aug 23, 2011 08:21 PM
Discussion Still having electric problems with my hobbyking Phoenix 2000, Crashvideo kyrkbymannen Electric Sailplanes 3 Jul 09, 2011 08:34 PM
Discussion hobby king Phoenix 2000 EPO Composite R/C Glider doomracing Electric Sailplanes 3 May 31, 2011 11:09 PM
