You can move that as well . . both trays are only held in place by screw's .. By moving the servo tray back abit , you can do away with the plastic clevises at the tail end... and use something like these.. http://www.hobbyking.com/hobbyking/s...F5pack%5F.html on the control rods . . . |
France
Joined Sep 2011
To not having to do the trim at each filght. As you seems verry inspired, maybe you have an idea to raise the front of the elevator by around 1cm to flaten the "V longitudinal" ? And maybe tighten it a bit in the same mod. |
Australia, SA, Adelaide
Joined May 2011
Just another thought...
How do you guys transport your birds around? I ride a motorbike every where I go and secure my Radian in a trailer I tow behind, but the Phoenix will not disassemble easily into its original box like the Radian does. Any thoughts as to where one could get a secure carrying case for a phoenix? |
France
Joined Sep 2011
But from base this angle is 4,3°* which is a lot. It's usually between 1 or 2°, or under 1° for accrobatic or race plane. This angle (4,3°) cause lot of drag, so reduce model speed and maneuverability, and is less needed with a 80mm gravity center. (*) 4,3° is the total angle I mesured between stab and wing (thats what is call V longitudinal in french) |
France
Joined Sep 2011
no special tool needed : http://aerololo.free.fr/articles.php?lng=fr&pg=184
see how fast you can go , before you feel your a55 leaving the seat..... ![]() just take the wing off and still use your trailer.... .. |
Joined May 2011
That is what I'll do, it's just that it is an open trailer and I don't want to strap the wings down too hard. With my Radian I just put the plane back in it's original box and strap the box down, and that works fine. I was after a large case or something to carry the Phoenix in, you know, like those aluminum camera cases people use. It's just that the wingspan is fairly large and they don't come apart particularly easily. Just wondering what other people do. Do you guys just carry them loose in the back of your cars or do you have something that you carry them in?
| Thread Tools | |
| For Sale HK Phoenix 2000 glider | blk822 | Aircraft - Electric - Airplanes (FS/W) | 4 | Aug 23, 2011 07:21 PM |
| Discussion Still having electric problems with my hobbyking Phoenix 2000, Crashvideo | kyrkbymannen | Electric Sailplanes | 3 | Jul 09, 2011 07:34 PM |
| Discussion Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 | KillerCut | Electric Sailplanes | 14 | Jun 06, 2011 09:57 AM |
| Discussion hobby king Phoenix 2000 EPO Composite R/C Glider | doomracing | Electric Sailplanes | 3 | May 31, 2011 10:09 PM |
