If you are willing to spend that much, look for a Castle Creations 10 amp BEC. You should find it for around $20.
http://www.castlecreations.com/products/ccbec.html |
Sure it's possible. It looks like the flap servo pockets for your plane are like those for the Radian Pro, which is to say that both servos install with the servo arms facing to the right (when viewed from behind, otherwise known as starboard.)
Just use a servo y-cord to connect both flap servos to your receiver's channel 5, which is the gear channel. Adjust your servo linkages so that the servo travel doesn't over-extend the flaps. Should be a piece of cake. |
Your a gent and have been very helpful.. Sean |
New Zealand
Joined Jul 2009
Motor recommendation
so I stuffed up and brought the R2 hobbies ARF version, thinking it was the same as the HK bind and fly! (they are both the same price- so at first glance, and since the r2 hobbies photos showed servos I assumed they were the same.)
Anyway - any recommendations for a cheep motor? thin is going to be a float plane in salt water. Previously i have had success waterproofing everything else, but the motors don't last too long- usually the bearings go. so suggestions of a cheep HK motor that i can be prepared to replace regularly would be appreciated. Cheers |
Didn't want the RTF one But I would of swapped out all the servo's anyhow... So I'm not to botherd about it.... and the mailing charger was cheaper for me.. This is the running gear I'll be useing in mine.. From HobbyKing FS40-4.0 . Folding Prop Spinner 40mm / 4.0mm shaft.. TGS10x6F . TGS 10x6F Precision Folding propeller.. T2836-1000 . Turnigy2836 Brushless Outrunner 1000kv.. HKESC35A . H-KING 35A Fixed Wing Brushless Speed Controler.. HXT900 . HXT900 9g / 1.6kg / .12sec Micro Servo x 6.. T2200.3S.20 .Turnigy 2200mAh 3S 20C Lipo Pack.. And from a Hobby Store in the UK Hobbywing 3amp UBEC.. .. |
Joined Jan 2011
Hi all I also ordered mine!I am so stoked,it should be here in a couple of days.Since i wasnt sure for the prop size, I ordered a spare 12x8 prop.Do you think its too big for the stock motor?I thought it would be a good idea to replace the motor with a 900kv, but I am not sure...Any thoughts and suggestions welcome,since I am a newbie,actually returning to rc flying after a 15 year absence...
As adviced before , I've finally got a Watt meter..
http://www.hobbyking.com/hobbyking/s...dproduct=10080 It arrived yesterday along with my parts from HobbyKing So today I spent my time fitting all the running gear into my Pheonix 2000 Glider.. Then used the Watt meter... with the 10x6 Prop ,I was getting a reading of (on WOT) 445w Max at 32Amp draw.... ( Motor was Very hot to the touch after a 30 sec run) With a 9x5 Prop, I was getting a reading of 245Watt Max at 22Amp .( WOT) This was on Throttle only ,no servo's used on test... So it would be better useing the 9x5 prop with T2836-1000 . Turnigy2836 Brushless Outrunner 1000kv.. On the other hand, if only using it for a climb out for a relatively short time, you can probably use the 10" if you don't keep it at full throttle in a steep climb. The 9" gives that margin of safety. Hopefully I'll get to maiden it tomorrow..... Sean |
| Thread Tools | |
| For Sale HK Phoenix 2000 glider | blk822 | Aircraft - Electric - Airplanes (FS/W) | 4 | Aug 23, 2011 07:21 PM |
| Discussion Still having electric problems with my hobbyking Phoenix 2000, Crashvideo | kyrkbymannen | Electric Sailplanes | 3 | Jul 09, 2011 07:34 PM |
| Discussion Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 | KillerCut | Electric Sailplanes | 14 | Jun 06, 2011 09:57 AM |
| Discussion hobby king Phoenix 2000 EPO Composite R/C Glider | doomracing | Electric Sailplanes | 3 | May 31, 2011 10:09 PM |
