Old Feb 02, 2011, 07:03 AM
skyhawk newbie is offline
Find More Posts by skyhawk newbie
Not a newbie anymore..
skyhawk newbie's Avatar
Ireland, Cork
Joined Oct 2010
Just Ordered my Phoenix from here,,,
http://www.r2hobbies.com/eng/proddet...od=rcpl2401001
Sean
skyhawk newbie is offline Find More Posts by skyhawk newbie
Old Feb 10, 2011, 01:27 PM
Ireland, Cork
Joined Oct 2010
Originally Posted by skyhawk newbie View Post
Ordered on the 2/2/11 my Phoenix from here,,,
Sean
My ARF Phoenix Arrived today...from HongKong...Posted on Monday...
Only took 4 days
Ordered from HobbyKing the same day ...
FS40-4.0 . Folding Prop Spinner 40mm / 4.0mm shaft
T2836-1000 . Turnigy2836 Brushless Outrunner 1000kv
TGS10x6F . TGS 10x6F Precision Folding propeller
HKESC35A . H-KING 35A Fixed Wing Brushless Speed Controler
HK-SS30A . Hobbyking SS Series 25-30A ESC
HXT900 . HXT900 9g / 1.6kg / .12sec Micro Servo
T2200.3S.20 .Turnigy 2200mAh 3S 20C Lipo Pack
All the above where ment to be in stock...
They haven't even left the HongKong warehouse yet ...
Yet HobbyKing Have my Money
Old Feb 10, 2011, 01:30 PM
Ireland, Cork
Joined Oct 2010
Originally Posted by cvanscho View Post
Down-thrust (well, downward-pointing motor which gives some up-thrust more accurately) is normal for all electric sailplanes, otherwise they tend to climb (sometimes enough to loop from launch) under power. It is also possible to mix in down-elevator trim with throttle.
Left angle is unusual. Normally a little bit of right angle is needed. But I would fly it as the designers intended first and see, maybe this plane needs a little left thrust?
I'll have to drive down to Kerry and see you Chris,
once I get all my parts from HobbyKing
Old Feb 10, 2011, 01:49 PM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Hope to see you soon!
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Feb 10, 2011, 05:48 PM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
This looks like a Radian and Radian Pro killer for sure. I have a Radian and love it but can hardly wait to get my hands on one of these.
kaptondave is offline Find More Posts by kaptondave
Old Feb 10, 2011, 06:19 PM
Ireland, Cork
Joined Oct 2010
I got my Phoenix 2000 ARF today, I must say I'm very imprest with the finish on the foam wings, looking forward to getting my order from HobbyKing so I can fit all the parts needed to get it flying...
I love my Radian,But that mite change once the Phoenix is flying...
Old Feb 10, 2011, 07:57 PM
F-111 John is offline
Find More Posts by F-111 John
R.I.P, Aardvark.
F-111 John's Avatar
Holt, MI
Joined Jan 2009
Can't wait for your flight report, Skyhawk.
F-111 John is offline Find More Posts by F-111 John
Old Feb 11, 2011, 06:23 AM
Ireland, Cork
Joined Oct 2010
Here some photo's of my new toy....
Still in the box as it arrived..( some type of foam )
Even the carboard box in side is wraped in bubble wrap..
All the parts inside are wraped in bubble wrap aswell
Out of the box and put together..
Lots of room inside the fuse from my 2200mAh Li-Po..
Tail and Aileron clevises are not the best ,
so I've fitted heat shink tube to them to stop them poping open..
Only fitted sticker to the elevator and Fuse ( pain in the a$$ to do )
So that's it, just got to wait now for all the running gear to arrive from Hobby King...
Sean
Old Feb 12, 2011, 10:27 AM
jsec1992 is offline
Find More Posts by jsec1992
Singapore
Joined Mar 2009
Finally - the maiden
Finally got the plane maidened today. Its all stock from HK except I had to replace one servo and the esc. Earlier I mentioned the motor had no down thrust and its tilted a little to the left. Well, that didn't seem to have a negative impact. For the maiden I used a 1300mah 20c 3S and it was probably too light - strong tendency to climb when flying against the wind. A 2200mah 20C 3S was used for the second flight and it flew much better.
Looking into replacing the stock spinner/prop and setting up flapperons/flaps next.
jsec1992 is offline Find More Posts by jsec1992
Old Feb 12, 2011, 12:26 PM
Ireland, Cork
Joined Oct 2010
What ESC did you use??
Did you stick with a 30 amp.....
Just wondering if your gonna run 6 servo's
would you not be better fitting a 35 amp ESC....
Old Feb 13, 2011, 12:41 AM
jsec1992 is offline
Singapore
Joined Mar 2009
I used a Turnigy Plush 30A. The stock (yellow) was DOA.
Probably starting off with flapperons first since that's easy to setup.
Eventually, I will probably set up flaps with six servos (HXT900) in total. However, I don't think the esc (2A/5V) can handle six servos?
Old Feb 13, 2011, 12:07 PM
R.I.P, Aardvark.
F-111 John's Avatar
Holt, MI
Joined Jan 2009
Unless you're going to do full span ailerons, you won't be using the two flap servos very often, so you can probably get away with just the ESC's BEC. The ESC's BEC should handle four 9 gram servos no problem.
If you plan to use the flap servos as full span ailerons in addition to being flaps, then 6 is too many servos moving all the time for the ESC's BEC. Then you should go with a stand alone switching BEC.
Old Feb 13, 2011, 12:26 PM
Ireland, Cork
Joined Oct 2010
Is there one you would recommend from HobbyKing.....
Old Feb 13, 2011, 12:59 PM
R.I.P, Aardvark.
F-111 John's Avatar
Holt, MI
Joined Jan 2009
I don't have any personal experience with it, but this one has been recommended by others in different threads.
http://www.hobbycity.com/hobbycity/s...idProduct=4319
I suppose this one would work just as well:
http://www.hobbycity.com/hobbycity/s...dProduct=10312
Old Feb 13, 2011, 01:37 PM
Ireland, Cork
Joined Oct 2010
Thanks for the links....
The user reviews are not that good on both of the BESC....
now I've never had to use a BESC before and know nothing about them
(as I've never had to use 6 servos)
But while I was there I found this one.
http://www.hobbycity.com/hobbycity/s...idProduct=6320
Would / could you use the one in my link.....
Thanks Sean
Discussion Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 KillerCut Electric Sailplanes 20 Jun 22, 2016 07:23 PM
For Sale HK Phoenix 2000 glider blk822 Aircraft - Electric - Airplanes (FS/W) 4 Aug 23, 2011 07:21 PM
Discussion Still having electric problems with my hobbyking Phoenix 2000, Crashvideo kyrkbymannen Electric Sailplanes 3 Jul 09, 2011 07:34 PM
Discussion hobby king Phoenix 2000 EPO Composite R/C Glider doomracing Electric Sailplanes 3 May 31, 2011 10:09 PM
