Old Mar 14, 2013, 05:49 PM
JLT_GTI is online now
Find More Posts by JLT_GTI
JLT_GTI's Avatar
Spain, Principado de Asturias, Oviedo
Joined Jun 2010
Originally Posted by Maximilionalpha View Post
I've flown my Phoenix in really strong winds, performed steep dive maneuvers, loops and rolls and have never seen the wings flex. Currently making some elevator and rudder mods, so mine is down for the moment.
Well.. not flexing like in other planes i had (the HawkSky in stock config had a really flexy wings) but when in strong winds when i make a pass close i can see the wings wobbling a bit up and down... there is certainly some flexing there.. not much but some is ..
But that guy is really good with the controls.. also since he uses the Phoenix as a pure unpowered glider.. he has way more free space in the fuselage.. so maybe he can get more ballast there.. as you know in sloping the more balast the more speed if you can get enought lift
JLT_GTI is online now Find More Posts by JLT_GTI
Old Mar 14, 2013, 10:18 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
got out today for a flight,love this glider,it is so stable and floats like a dream.
fastfwd is offline Find More Posts by fastfwd
Old Mar 14, 2013, 10:20 PM
nightfox7 is offline
Find More Posts by nightfox7
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
United States, GA, Cornelia
Joined Jan 2012
How does the Phoenix compare to say the radian? It seems to be a very good deal..
We are starting a bit of a glider competition at our club and i'm looking for a budget glider to go along with them.
nightfox7 is offline Find More Posts by nightfox7
Old Mar 14, 2013, 10:41 PM
Maximilionalpha is offline
Find More Posts by Maximilionalpha
Maximilionalpha's Avatar
United States, NJ, Rahway
Joined Mar 2012
That's like comparing apples, to oranges. The Radian's a 3 channel floater, while the Phoenix 2k is a 5 channel speed demon, that cuts through the air like a hot knife through butter.
Maximilionalpha is offline Find More Posts by Maximilionalpha
Old Mar 15, 2013, 09:31 AM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
I gotcha! How does it handle just gliding and thermaling?
Old Mar 15, 2013, 09:54 AM
BarnOwl is offline
Find More Posts by BarnOwl
Heli's and gliders, what else?
BarnOwl's Avatar
Nederland, GE, Slijk-Ewijk
Joined Apr 2006
Same here........as I see alot of gliders (Like my Radian Pro) flex like hell, the Phoenix has wings as stiff as a wooden pole!
BarnOwl is offline Find More Posts by BarnOwl
Old Mar 15, 2013, 10:26 AM
Joined Mar 2012
With a nice head wind, great! If you can find a good thermal, it'll handle okay and by that I mean because the wings don't flex enough, they slice through the air and therefore, won't let the plane thermal that great.
Old Mar 15, 2013, 01:45 PM
gdouglas is online now
Find More Posts by gdouglas
Camber down and screw it up.
gdouglas's Avatar
United States, MT, Kalispell
Joined Aug 2004
Huh??? That makes no sense whatsoever.
gdouglas is online now Find More Posts by gdouglas
Old Mar 15, 2013, 01:54 PM
gdouglas's Avatar
Joined Aug 2004
It handles just great as long as you keep the speed up and don't stall. Add a bit of camber with the flaps and it will thermal quite well. I've had several hour+ flights on just one 25 second motor burn.
Greg
Old Mar 15, 2013, 02:49 PM
fastfwd is offline
Joined Mar 2012
Greg
yes it will tip stall if you try to turn at very low speeds ( i know as i have done it) and it will float forever with flaps down for a stock motor i think it is VERY fast,not a climbing beast but the design allows it to cut the air and moves real fast.
skip to 2.12 minutes and youll see im floating the try to turn and down she comes,zero damage
Phoenix 2000 (2 min 23 sec)
Old Mar 16, 2013, 10:23 AM
Robert P is offline
Find More Posts by Robert P
Joined Dec 2012
back into gliding
hi
i used to fly power 25 years ago and got into gliders recently. have pretty much mastered the Radian and have a sophisticated lady but as it is winter not flown on the hi start. am i over my head with the Pheonix 2000?
i can fly and land the Radian in a football field and recently spec'd out and lost it.
Robert P is offline Find More Posts by Robert P
Old Mar 16, 2013, 10:30 AM
Robert P is offline
Joined Dec 2012
back into gliding
hi
Old Mar 16, 2013, 11:41 AM
fastfwd is offline
Joined Mar 2012
Originally Posted by Robert P View Post
hi
do you have the Phoenix or the evolution ? mine is the evolution with longer wings and it is a sweet stable plane,must even with the longer wings you need a little power when turning other than that it is easy to fly and to land. Think you will be just fine.
Old Mar 16, 2013, 02:22 PM
gdouglas's Avatar
Joined Aug 2004
Not sure what you mean by that, FF. The only power I need is when I launch it to get it up to 200 meters. After that, the motor is shut off (automatically if I have my ALES timer in there). It's a powered sailplane. There's no need to be flying around powered.
I get the impression that some people think this is a hotliner, or an acrobatic electric flyer. It's a sailplane. You can fly however you want to, but it was designed (the wing/tail/fuse planform, the airfoil, the control surfaces) to be a sailplane. The only reason that motor is up front is so you don't have to lay out a hi-start or a winch. It isn't designed for motoring the sailplane around under power. You CAN do this, but it's not as efficient (or challenging) as hunting for nothing but rising air to keep you aloft.
The flaps are used for glide path control. And, to a lesser extent, speed control. They're typically used on landing to allow the sailplane to come in at a much steeper angle (than without the flaps) without gathering too much speed. They can also be programmed (if you have the right radio) as either full span ailerons, or with a slight amount of 'up' (for cruise mode - called reflex - typically used to get out of sink, or to cruise at a faster speed while looking for lift), or a slight amount of down (for slowing it down slightly - called camber - used primarily in a thermal to slow it down while in lift). Or - when programmed to deflect 45-90 degrees down, they are used as airbrakes (see above) on landing. By 'slight amount' referenced above, I mean a few degrees only.
I just hate to see the Phoenix / Evolution bashed for things it wasn't meant to do. Like 'oh, the rudder is completely ineffective to turn'. Or 'My dog rolls faster than this thing'. Well, that's because it's a powered sailplane.
Off my soapbox now.
Greg
Old Mar 16, 2013, 02:59 PM
Joined Mar 2012
Rudder mod to make my Phoenix turn without using so much aileron.
Discussion Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 KillerCut Electric Sailplanes 20 Jun 22, 2016 07:23 PM
For Sale HK Phoenix 2000 glider blk822 Aircraft - Electric - Airplanes (FS/W) 4 Aug 23, 2011 07:21 PM
Discussion Still having electric problems with my hobbyking Phoenix 2000, Crashvideo kyrkbymannen Electric Sailplanes 3 Jul 09, 2011 07:34 PM
Discussion hobby king Phoenix 2000 EPO Composite R/C Glider doomracing Electric Sailplanes 3 May 31, 2011 10:09 PM
