Old Feb 26, 2013, 06:32 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
Originally Posted by Maximilionalpha View Post
You're using this plane for FPV??? I hope the best for you with that, bro! This is not a glider that is made for FPV'ing. It's already heavy enough, without any added weight. Doesn't thermal all that well and once it's out of control, it's out of control! Keep us posted!
LOL I love this plane ! it is the lightest one i have,turns on a dime,and floats forever. maybe you need some them reading glasses ?
fastfwd is offline Find More Posts by fastfwd
Old Feb 27, 2013, 02:43 AM
Flahultarn is offline
Find More Posts by Flahultarn
Flap flier
Flahultarn's Avatar
Sweden
Joined Aug 2011
Originally Posted by mustflynow2 View Post
at the root is 200mm at knee 190mm and about 120mm at 50mm from tip. Tip radius starts at about 100mm from tip and measures 140mm. it's a bit hard to measure in that area, but thereabouts.
Thanks a lot! I'm trying to figure out how much the wing connection mod described earlier will do for the wing load and if it's worth while building a bit of wing area to get a few more dm2. Will start flying as it is though
BTW, seems like my bird will show up with the mailman today=) and I accidently happen to have a day off from work
Flahultarn is offline Find More Posts by Flahultarn
Old Feb 27, 2013, 04:27 PM
fastfwd is offline
Joined Mar 2012
one thing ,on the tail assembly where it meets the fuselage i had to get it centered on fuse then use a touch of glue to hold it there,otherwise it has a tendency to move around while in flight
Old Feb 28, 2013, 02:06 AM
Flap flier
Flahultarn's Avatar
Sweden
Joined Aug 2011
Ok, thanks for the tip! I will check the fit and see if it is firm. Some here have glued the tail in place to have it secure but I'd prefer having it loose for transportation I think.
It looks really nice, now waiting for the motor and some more things to be delivered. I was thinking initially to reinforce the nose with glass fiber on the outside and a firmer motor mount inside but that's probably overkill.
http://static.rcgroups.net/forums/at...g?d=1346306121
This look really nice though. If it works with the motor I ordered, this is the way I'll go.
Old Feb 28, 2013, 03:59 AM
mustflynow2 is offline
Find More Posts by mustflynow2
The Sequel
mustflynow2's Avatar
Australia, VIC
Joined Sep 2011
I use a strip of double sided tape to hold the vertical stab in place plus screws.
How are you setting yours up, what motor combo? I don't think any permanent fixings are required. I use a 4 mm ply and 1.5 mm fiberglass ic board sandwich to hold things in place. Am pulling 600 watts with 13x6.5 on 4s. No issue to speak of. Leaves me open to easily change motors for a different set up.
http://www.rcgroups.com/forums/showp...postcount=2732
mustflynow2 is offline Find More Posts by mustflynow2
Old Feb 28, 2013, 05:29 AM
Flap flier
Flahultarn's Avatar
Sweden
Joined Aug 2011
So you don't think it's necessary to strenghten the motor mount that much? Well, I assume it's the heat that is threatening and I think the motor will stay cool, I'll use this one, Tgy D2836 XP kv1100 with a Plush 40A ESC and probably 9-10x6 or something like that, on 3-cell. I'll have to reverse the motor shaft but that can be handled. The motor is on its way, but I think I regret the kv choice I made, should have gone with the kv950 instead to swing a slightly bigger prop. We'll see how it works.
I have another of these motors, the D3530/kv1100, and I'm impressed of the performance. Stays cool even at heavy load.
Old Mar 01, 2013, 07:48 AM
craposo is offline
Find More Posts by craposo
Portugal, Santarém, Chamusca
Joined Jan 2013
Hello.
Today one more flight, everything fine, but i can´t set the break on esc.
I will buy another esc and probably a motor.
What you think about this set?
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Will the 30 amp esc will work or it will be best to buy the 40 amp?
Thank you.
craposo is offline Find More Posts by craposo
Old Mar 01, 2013, 09:25 AM
Maximilionalpha is offline
Find More Posts by Maximilionalpha
Maximilionalpha's Avatar
United States, NJ, Rahway
Joined Mar 2012
Originally Posted by craposo View Post
Hello.
Thank you.
How to set brake on Phoenix 2000 glider (2 min 40 sec)
Maximilionalpha is offline Find More Posts by Maximilionalpha
Old Mar 01, 2013, 10:33 AM
craposo is offline
Joined Jan 2013
I think it was the first thing i tried, beeps in mine are diferent.
Have tried everything i found but nothing works, the worst thing is that today i landed in grass and when i pick up the plane the engine was still trying to turn, i lift it up and i did turn one time and stoped, i guess if i landed it very far away maybe i get a burned motor.
Old Mar 01, 2013, 12:18 PM
fastfwd is offline
Joined Mar 2012
Hello.
Thank you.
this motor will bolt right into the mount http://www.hobbyking.com/hobbyking/s...tor_750kv.html
and i got this esc with the program card,works great http://www.headsuprc.com/servlet/the...-50-Amp/Detail
and program card http://www.headsuprc.com/servlet/the...ard-for/Detail
Old Mar 01, 2013, 03:52 PM
4x4rc is offline
Find More Posts by 4x4rc
Fly, crash, glue. Repeat.
Belgium, Walloon Region, Plombières
Joined Jul 2011
If that's what happened then your problem is throttle calibration, not the brake setting. Sounds like your ESC doesn't know the min and max throttle values.
4x4rc is offline Find More Posts by 4x4rc
Old Mar 03, 2013, 10:35 PM
HoosierGuy is offline
Find More Posts by HoosierGuy
HoosierGuy's Avatar
United States, IN
Joined Jan 2012
Been doing other things this winter (first R.C. car and shooting) but a few days ago I got out my Phoenix Evolution and worked on it more to get it ready for spring. Ailerons are on now and work. Motor seems to run good. It might get to fifty degrees next weekend so I just might fly for the first time in a few months. It's really lite after I ripped off all those LEDs that were on it. The plastic mount that goes over the two wings is a problem though, one holes is stripped out. So now I'm going to use a larger screw. This glider has been through hell and back and I'm sure it will still fly next weekend.
HoosierGuy is offline Find More Posts by HoosierGuy
Old Mar 03, 2013, 11:20 PM
woodenshoe is offline
Find More Posts by woodenshoe
remotely sensitive
woodenshoe's Avatar
United States, WI, Verona
Joined Oct 2011
Glad to have you back Hoosier.. It's called the Phoenix for a reason.. never dies.. rise up from the ashes!!
woodenshoe is offline Find More Posts by woodenshoe
Old Mar 04, 2013, 12:06 AM
Goody63 is online now
Find More Posts by Goody63
How close are those trees?
Goody63's Avatar
Perth, Western Australia
Joined Apr 2008
Maiden
Well maidened mine on the weekend.
Stock standard except for changing out the rudder/elev for HXT 900s, adding flaps and installing a Turnigy 40amp ESC.
Also installed a for Hitec Sensor/GPS.
Gotta say it flew beautifully but it sure lacks performance with the stock electrics and a 1300 3S.
Very tempted to upgrade the motor already also because it gets real hot even with just a few climbs.
Goody63 is online now Find More Posts by Goody63
Old Mar 04, 2013, 01:19 AM
The Sequel
Australia, VIC
Joined Sep 2011
Yep, depends just how light you want to keep in, I use the 750kv red motor mentioned by fastfwd above, when he says it bolts right in, it actually uses 25mm centres compared with 16mm centres for stock, but yes a 35mm outrunner will go in easily enough. I go with 4s and 13x 6.5 etc. so some extra weight, although I must say I flew last night in very calm conditions and with a few mm of camber it cruised so nicely, without too much sink. I had forgotten how quietly it would fly, usually in windier conditions I am throwing it about. There is plenty of info back through the thread on my setup, have had many flights without issue. brendan
Got a pic with your gps in?
Discussion Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 KillerCut Electric Sailplanes 18 Nov 18, 2015 07:33 AM
For Sale HK Phoenix 2000 glider blk822 Aircraft - Electric - Airplanes (FS/W) 4 Aug 23, 2011 08:21 PM
Discussion Still having electric problems with my hobbyking Phoenix 2000, Crashvideo kyrkbymannen Electric Sailplanes 3 Jul 09, 2011 08:34 PM
Discussion hobby king Phoenix 2000 EPO Composite R/C Glider doomracing Electric Sailplanes 3 May 31, 2011 11:09 PM
