Old Dec 23, 2012, 08:41 PM
Nereth is offline
Find More Posts by Nereth
Joined Jun 2012
Originally Posted by fastfwd View Post
this glider is VERY light,when i first started motor on maiden flight,i stopped it as it didnt sound like it had enough power to even fly. i thought maybe i didnt have esc throttle calibrated. But it was and it fly's very well and is fast. I think a bigger motor might be to much for it being so light,and may even twist motor mount out of fuse. ??
Yeah that's a really significant problem because I was thinking of using it as something of a warmliner... the motor+prop is enough to take it to about 100-110 kph, do you think the plane might go to pieces at those speeds?
Nereth is offline Find More Posts by Nereth
Old Dec 24, 2012, 03:42 AM
HoosierGuy is offline
Find More Posts by HoosierGuy
HoosierGuy's Avatar
United States, IN
Joined Jan 2012
Merry Christmas to all my fellow Lanyu Phoenix 2000/Evolution glider flyers and all others who love electric gliders! Bring on 2013!
HoosierGuy is offline Find More Posts by HoosierGuy
Old Dec 24, 2012, 05:32 AM
ilipin is offline
Find More Posts by ilipin
ilipin's Avatar
Россия, Пермский край, город Пермь
Joined Jul 2011
Originally Posted by Nereth View Post
I already have a full power system (battery, ESC, motor, prop) from an existing glider, I am trying to decide if putting it into a phoenix 2000 is viable, and if so, is it an upgrade or not
What spinner diameter would you say is correct for this plane?
If you already have power system - try to fit it. There is enough place, if you move servos on tail. You can install 35 mm motor inside, but you need a long (not short) shaft and accuracy fit motor cable.
Kit prop have 3mm shaft diameter.
ilipin is offline Find More Posts by ilipin
Old Dec 25, 2012, 03:37 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
I run a 36mm in mine with great results.
3639 750kv with a 13x7 prop and it gives unlimited vertical climb out and gets to altitude really quickly.
Teamsherman is offline Find More Posts by Teamsherman
Old Dec 25, 2012, 06:34 AM
rhampton is offline
Find More Posts by rhampton
USA, FL, Clearwater
Joined Dec 2007
i plane on buying this glider on ebay within the next day or 2. i just wanted to ask, is this Glider reliable right out the box? i plan on buying the PnP..i'm going to use my DX7 and AR500 rx. Is it a major build? how fast can one get this airborne. just a few questions to ease my mind before i buy....
i also heard of a motor heating the foam issue? i'm wondering if i purchase this from ebay,,will i get the latest fix batch...that's a major concern for me...
Any feedback would be great...
http://cgi.ebay.com/ws/eBayISAPI.dll...m=150969794223
rhampton is offline Find More Posts by rhampton
Old Dec 25, 2012, 07:48 AM
viking60 is offline
Find More Posts by viking60
High Altitude Flyer
viking60's Avatar
Fairplay, South Park, CO
Joined Sep 2005
I bought my Version III Phoenix 2000 kit from tHobby King's USA warehouse a few weeks ago. There are two major issues to deal with: COOLING and RUDDER
1: OPEN THE MOTOR COOLING AIR VENTING through all layers of the motor mount and fuselage nose; if you do this, the motor will have a far better chance of staying cool. I also enlarged the air intakes on the sides of the nose & cut away the insulating heat shrink covering from selected areas of the ESC, then mounted the ESC on the underside of the battery tray to insure good air flow past it. I also cut a pir of cooling air exit holes on either side of the plastic fuselage aft of the wing's trailing edge, to let the warm air out. (See post 2435 on page 163 for more details & photos)
A vented prop spinner allows more cooling air through the motor: (see post 2442)
2: Add a hinge to the bottom of the rudder- it definitely needs one. See post 2464 on page 165 for details of a simple way of doing this.
VIKING
viking60 is offline Find More Posts by viking60
Old Dec 25, 2012, 08:13 AM
rhampton is offline
USA, FL, Clearwater
Joined Dec 2007
Is this glider the same as the phoenix Evolution 2.6?
Old Dec 25, 2012, 10:09 PM
alfiev is offline
Find More Posts by alfiev
A4Framie
alfiev's Avatar
New Zealand, Marlborough, Woodbourne
Joined Nov 2011
Originally Posted by macshack View Post
Not an excellent thermaller but it will mix it with the best on a good day. i have no problems with it on good days and have managed to climb to 483 mtrs on one flight, "Jolly Logic" altimeter.
Excellent value for money and I've hod no issues with any of the equipment supplied with it. either has my dad.
Heh!! What was the decent like....?
AlfieV
alfiev is offline Find More Posts by alfiev
Old Dec 25, 2012, 11:14 PM
woodenshoe is offline
Find More Posts by woodenshoe
remotely sensitive
woodenshoe's Avatar
United States, WI, Verona
Joined Oct 2011
Ad, check all servos on the new glider to Viking"s List. Two of my servos were "dead on arrival" That said, the gears are interchangeable with Tower Pro 9gs and possibly others. I re-geared both with a few dead servos I had lying around. Servos now have been reliable.
The 2000 and the Evolution are almost the same. Be warned the 2.6m glider wing is HEAVY (like 1.7lbs for wing alone, just weighed it).. has TWO square aluminium tubes running the length of the center wing section, plus heavy almost solid fiberglass rods. The evolution (2.6m) has about 2 inches more vertical tail length. I would not buy the 2.6m again, but would go for the 2000. The price difference is not worth the 60 extra centimeters IMHO.
woodenshoe is offline Find More Posts by woodenshoe
Old Dec 26, 2012, 10:23 AM
viking60 is offline
High Altitude Flyer
viking60's Avatar
Joined Sep 2005
Woodenshoe,
Glad you mentioned the servos; I simply replaced all of the stock ones with some metal gear servos before I ever flew my Phoenix - I simply didn't choose to take a chance on the stock servos in this aircraft.
VIKING
Old Dec 26, 2012, 10:44 AM
BravoGolf is offline
Find More Posts by BravoGolf
Spearheading an Alliance
BravoGolf's Avatar
United States, CO, Aspen
Joined Oct 2010
reliability mods
Another item for concern which I believe has not been addressed with subsequent revisions, and I could certainly be wrong about this, is the cheap ass brittle clevises included definitely need replacing. You've heard the saying you are only as strong as your weakest link? Well these are a very weak link!
I also removed the factory push rods in addition to the oem clevises and sadly don't recall at the moment what I replaced the push rods with. I believe they were dubro with matching sized clevises. I left the factory push rod sleeving as it seemed to be ok with the beefier push rods. It was quite some time ago but I believe I did this (push rod replacement) based on information posted by others earlier in the thread.
If this is no longer a concern, I'll stand corrected.
BG
BravoGolf is offline Find More Posts by BravoGolf
Old Dec 26, 2012, 11:52 AM
viking60 is offline
High Altitude Flyer
viking60's Avatar
Joined Sep 2005
BravoGolf,
The latest version III Phoenix 2000 kit shipped by Hobby King a few weeks ago (USA Warehouse stock) now has some fairly resilient nylon plastic clevises - definitely not 'brittle', so these may have also been upgraded.
They don't necessarily latch closed as well as I would like, but then that's rather typical of plastic clevises. By sliding on a ~3/8" long section of large silicone fuel tubing over the plastic clevis, they seem to be something that will serve their purposes adequately. (I always do the same thing with DuBro or Sullivan plastic clevises, too, as I've also seen them open by themselves over time, so there's really not much difference now.... (I do prefer to install metal clevises, sometimes soldered directly to the control rod on most of my larger aircraft.)
The stock control rods look to be smaller diameter than the 2-56 Dubro or Sullivan clevises, so from what I could tell, just replacing the clevises alone with 2-56 ones is not really an option.
VIKING
Old Dec 26, 2012, 10:02 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
that is where i got mine bud,(Lanyu Hobby,RichTop) it arrived within five days. only thing i did was replace all the crap control clevis,s and put in a bigger and better esc. with the 2.6 wings on this thing is very fast and very responsive,yet will float forever I think you will love it.
fastfwd is offline Find More Posts by fastfwd
Old Dec 26, 2012, 10:28 PM
BravoGolf's Avatar
Joined Oct 2010
phoenix pushrods
Originally Posted by viking60 View Post
BravoGolf,
They don't necessarily latch closed as well as I would like, but by sliding on a ~3/8" long section of large silicone fuel tubing over the clevis, they seem to be something that will serve their purposes adequately. The stock control rods look to be smaller diameter than the 2-56 Dubro clevises, so from what I could tell, just replacing the clevises alone with 2-56 ones is not really an option.
VIKING
Which is why I didn't replace the clevises alone but the entire push rods.
Old Dec 27, 2012, 05:10 AM
rhampton is offline
USA, FL, Clearwater
Joined Dec 2007
Wow fastfwd,, i see you and i have probably had every Glider in the book..i see u on every forum....LOL...it's all good tho, i'm glad....so u actually bought this Phoenix Evolution? i should get mine on Friday in the mail..it's the 742-5 Version..Latest batch..i can wait to see it..Not as Bulky looking as the Diamond 2500 but is sure Lighter....Under 60oz.....u yeahh,,,my back is loving this...a no stress Launching glider...
will keep that in mind about the control clevis...if you have photos, can u upload? i rarely see any except the stock ones online....In fact if anyone has the 2.6m version evolution, can you please post photos,,,,,photos,,,i want to see..
Discussion Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 KillerCut Electric Sailplanes 20 Jun 22, 2016 07:23 PM
For Sale HK Phoenix 2000 glider blk822 Aircraft - Electric - Airplanes (FS/W) 4 Aug 23, 2011 07:21 PM
Discussion Still having electric problems with my hobbyking Phoenix 2000, Crashvideo kyrkbymannen Electric Sailplanes 3 Jul 09, 2011 07:34 PM
Discussion hobby king Phoenix 2000 EPO Composite R/C Glider doomracing Electric Sailplanes 3 May 31, 2011 10:09 PM
