Old Dec 05, 2012, 10:11 PM
mustflynow2 is online now
Find More Posts by mustflynow2
The Sequel
mustflynow2's Avatar
Australia, VIC
Joined Sep 2011
a couple of pics of the phoenix rudder
mustflynow2 is online now Find More Posts by mustflynow2
Old Dec 05, 2012, 11:55 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
i would think that was a definite mistake in engineering there An easy fix though..
fastfwd is offline Find More Posts by fastfwd
Old Dec 06, 2012, 01:45 AM
_Richard is offline
Find More Posts by _Richard
Joined May 2012
I'm not an expert but I noticed immediately and decided not to fly before fixing its down part to the fusealage. A simple fix and now it's perfect.
_Richard is offline Find More Posts by _Richard
Old Dec 06, 2012, 08:54 AM
viking60 is offline
Find More Posts by viking60
High Altitude Flyer
viking60's Avatar
Fairplay, South Park, CO
Joined Sep 2005
Flying with & without a rudder on gliders- both useful
Friends,
I've done a lot of 'Bank & Yank' flying over the years, too- had a blast doing it!. For some types of flying- specifically for hard-core slope combat like we fly here in Colorado, a rudder would be a useless piece of extra mechanism that would simply add weight, drag, & vulnerability to damage.
And for hotliner / warmliner flying, the rudder has little to offer... yes, it's handy for lining up landings in tight landing sites, & other than that, mostly remains unused.
On my ~40" Me163b, I built in a rudder... when I complete the larger one, I'll omit the operational rudder completely; that's simply relative to the way I choose to design & fly each aircraft.
With the thermal hunting opportunities I have here in Colorado's high country, I occasionally go out to hunt lift, flying low level tight thermals of very modest diameter & light lift dynamics. (Above 600 feet, the whole sky seems to be going up some days... there's no challenge in staying in lift up there. It's down close to the ground where the fresh thermals are born that the real challenge lies.)
But when doing a quick climb to only 250-300 feet AGL, chopping power, & hunting the smaller tight patches of lightly rising air that you'll encounter there, your ability to stay in lift and ride it up to speck out sometimes benefits from employing different flying techniques. That's where staying in a tight column of lightly rising air calls for turning relatively tightly without dropping a wing tip much at all- if you do, you'll loose lift & drop out. In my experience, a "bank & yank" approach just isn't as effective as working with both rudder & ailerons to keep the aircraft's bank attitude flatter while still staying within the tight patch of rising air. [Try it if you get a chance- you just might find it useful...)
Deflecting a rudder slightly does produce a bit of drag... and deflecting ailerons also produces some drag (and adverse yaw in some cases, some setups). It's simply part of flight path control - options available to the pilot to use or not.
Different strokes for Different folks! - It's all fun, all useful!
VIKING
viking60 is offline Find More Posts by viking60
Old Dec 06, 2012, 10:51 AM
Terry Grau is offline
Find More Posts by Terry Grau
Grau Adler
United States, CO, Evergreen
Joined Mar 2012
Rudder to control airspeed???
Sorry Pete,
You can do a lot of things with 3 axis control, including things that were not intended. But rudder for airspeed control, in a turn, is not one of them.
A coordinated turn is all about lift vector.
I don't type fast enough to attempt to prove this, but over forty years with my butt strapped in sailplanes, J3 Cubs, ejection seats and flying busses through the 767-300 tells me it is not so.
No offense intended but there is already too much in accurate info on the web.
Terry,
retired but not dead yet
Terry Grau is offline Find More Posts by Terry Grau
Old Dec 06, 2012, 12:06 PM
fastfwd is offline
Joined Mar 2012
I use rudder all the time on most of my planes.For lining up on runway and keeping wings level,to HELP in turns,to do a flat circle (rudder is a must) to do snap rolls, i wouldn't want to try flying many of my power gliders or 3d planes with no rudder.
Old Dec 06, 2012, 12:36 PM
JLT_GTI is offline
Find More Posts by JLT_GTI
JLT_GTI's Avatar
Spain, Principado de Asturias, Oviedo
Joined Jun 2010
I have a SIG Ninja slope glider... it doesnt have a rudder either
JLT_GTI is offline Find More Posts by JLT_GTI
Old Dec 06, 2012, 12:55 PM
peterlngh is online now
Find More Posts by peterlngh
Joined Apr 2012
You are absolutely right, Terry. Just a senior moment on my part. I have corrected the post to replace speed with "attitude". Thanks for the catch.
pete
peterlngh is online now Find More Posts by peterlngh
Old Dec 06, 2012, 01:16 PM
gdouglas is online now
Find More Posts by gdouglas
Camber down and screw it up.
gdouglas's Avatar
United States, MT, Kalispell
Joined Aug 2004
How can you argue with logic like that? I hate it when I 'loose' lift.
My post had very little to do with the advantages/disadvantages of turning with rudder or ailerons. If you want to fly an incredibly large circle in the most inefficient way possible, go ahead, yaw away. My point was that Viking had said in numerous posts how poor the rudder response was when initiating a turn with the rudder. I pointed out that the Phoenix 2K has a completely flat wing, and the rudder isn 't going to do anything except yaw the plane along its longitudinal axis. It's certainly not going to initiate any turns. He listed 3 other planes that had much better response to 'initiating a turn' using only the rudder, and I pointed out that the 3 he listed all had polyhedral, which rolls the sailplane along its longitudinal axis (no ailerons needed) after application of rudder. Of course they're going to have better (faster) turn response with only the rudder.
I'm just trying to give the P2K a fair shake, as it's doing exactly what it was intended, its rudder does an excellent job.
Good day (and I mean that).
Greg
gdouglas is online now Find More Posts by gdouglas
Old Dec 06, 2012, 01:27 PM
RoboSerg is offline
Find More Posts by RoboSerg
RoboSerg's Avatar
Joined Sep 2011
I am thinking to buy this plane, its only 65 usd ARF in EU!
1. Can I use 1600-2200kv motor with it? 1200kv seems to slow Maybe smth like Turnigy2836 brushless Outrunner 2350kv
2. Can I use a NON folding prop? Will it break durin landing?
3. How long can you glide with 2200mah 3s + 2836 1000kv motor? 20 min?
RoboSerg is offline Find More Posts by RoboSerg
Old Dec 06, 2012, 01:57 PM
fastfwd is offline
Joined Mar 2012
This plane is VERY light ! When i first spun up the stock motor i thought there is not enough power,no way this motor will lift the plane. but she fly's great and fast ! I am using a 1600 3s lipo, hardly used any of it after flying for around 10 minutes,you need the folding prop and the brake set on esc or sure enough you will break the prop.
Old Dec 06, 2012, 02:00 PM
Joined Apr 2012
Hi, RoboSerg.
A sailplane, not a hotliner, will generally use a motor with a kv from 850-1200. One wants to be able to swing a large prop to generate thrust at low speed.
A non folding prop will generate so much drag, particularly if it windmills, that soaring will be virtually impossible.
Soaring time depends on how much current one uses with the motor. A sailplane with four micro servos will be able to run the radio for well over an hour if one doesn't spend time flying under power.
Old Dec 06, 2012, 04:47 PM
HoosierGuy is offline
Find More Posts by HoosierGuy
HoosierGuy's Avatar
United States, IN
Joined Jan 2012
Originally Posted by fastfwd View Post
sweet ! pictures ? Im loading the plane up and going to maiden it this afternoon. Got the 2.5m wings so hope she floats like a humming bird ill do the go pro video and try to keep it close enough to see, go pro isnt that good for this as it makes everything look further away
I'm not sure that foam in the can I used to fix my wings would be good for more repairs. So far it has not become rock hard. I did use it to fix my wings but I also coated the top and bottom with that spackling I bought and then covered the top and bottom with shoo goo. But I'm still experimenting with it though.
HoosierGuy is offline Find More Posts by HoosierGuy
Old Dec 06, 2012, 06:25 PM
fastfwd is offline
Joined Mar 2012
may be you needed to put in a little at a time letting it dry,then add a little more ect until it was built up. If it was me i would go get some foam board or find a chunk of foam at a local hobby shop and glue it in using gorilla glue,first put a bit of water on each side to be glued, then after gluing cover with tape so it cant spread to far. after it is dry it can be sanded off.
Old Dec 06, 2012, 08:04 PM
gdouglas's Avatar
Joined Aug 2004
Hi Serg.
1. Lower RPM = more torque = ability to swing a larger prop.
2. a - it will most certainly break on landing, b - if it doesn't fold back, it's adding quite a bit of drag, not good.
3. The size of the battery is only indirectly proportional to 'how long you can glide'. How long you can glide is dependent on lots of things, mostly catching updrafts (either thermals or wind deflected upwards). I would say it would be possible to glide for days on a 2200 mAH battery pack, assuming you could catch enough rising air to stay aloft. Somewhat more difficult at night.
Greg
Discussion Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 KillerCut Electric Sailplanes 20 Jun 22, 2016 07:23 PM
For Sale HK Phoenix 2000 glider blk822 Aircraft - Electric - Airplanes (FS/W) 4 Aug 23, 2011 07:21 PM
Discussion Still having electric problems with my hobbyking Phoenix 2000, Crashvideo kyrkbymannen Electric Sailplanes 3 Jul 09, 2011 07:34 PM
Discussion hobby king Phoenix 2000 EPO Composite R/C Glider doomracing Electric Sailplanes 3 May 31, 2011 10:09 PM
