Old May 01, 2011, 05:29 PM
skyhawk newbie is offline
Find More Posts by skyhawk newbie
Not a newbie anymore..
skyhawk newbie's Avatar
Ireland, Cork
Joined Oct 2010
Originally Posted by mr_eagle6 View Post
So what can I do so I do not burn the stock motor ? Smaller prop ?
It's a Glider, and therefor is ment to be flown like one...
allso very good as a slope soarer or thermo glider...
The motor will be OK as long as you only use it to climb and then glide...
30 second burst to get you up into the sky..
skyhawk newbie is offline Find More Posts by skyhawk newbie
Old May 01, 2011, 07:43 PM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
[QUOTE=acuamie;18117703... you will burn your stock motor.[/QUOTE]Acuamie, I would certainly like to hear why you think he will burn the motor just by using a battery with more amp-hour capacity. That will make the battery run longer but sill NOT deliver any more current at WOT than the stock 1300 mah battery.
YES you can use a 2200 mah battery with no worries. You will need to adjust the battery position to give the same cg as with the stock battery.
kaptondave is offline Find More Posts by kaptondave
Old May 01, 2011, 08:19 PM
mr_eagle6 is offline
Find More Posts by mr_eagle6
United States, OH, Dayton
Joined Jan 2007
That is what I thought too, it should pull the same amount of amps no matter what the source is. . . . but then doubt start setteling in and I do not have a watt meter.
Yes I want to fly it as a glider I love hunting for thermals I used to own a Electra from goldberg and loved those 1 - 1.5 hr flights
mr_eagle6 is offline Find More Posts by mr_eagle6
Old May 01, 2011, 11:00 PM
acuamie is offline
Find More Posts by acuamie
acuamie's Avatar
Malaysia, Federal Territory of Putrajaya, Putrajaya
Joined Apr 2009
it is a "STOCK" motor brother. unless u change it to or something reliable brand. my first maiden using all stock motor and esc with 3s 1500mah/20c and flying superb. then i change to 2200mah and the motor smoking, but the stock esc still good. (my true experience). maybe u should watch-out you C rating on your 2200mah batteries.
930~1100kv with 1500mah/20C : 331W with 29.8A at peak with 10x6 prop. maybe our friends here would share their wattmeter rating with 2200mah/20C/25C with their prop for comparison. . lets help mr_eagle6 fly his new glider soon...
-cheers- acu
p/s: maybe u can use this for basic guide. http://adamone.rchomepage.com/calc_motor.htm
acuamie is offline Find More Posts by acuamie
Old May 02, 2011, 12:37 AM
Joined Jan 2010
The reason your motor got hot had nothing to do with changing to a 2200 mah battery, or with the C rating. I suspect that you simply ran it too long at a high throttle setting. The stock motor is not meant to run at high power continuously.
Old May 02, 2011, 04:23 AM
Ireland, Cork
Joined Oct 2010
Thats right Dave....
In his Vid ( Few pages Back ) he runns his motor on WOT
for most of the flight..
http://www.rcgroups.com/forums/showp...&postcount=208
Old May 02, 2011, 05:55 AM
acuamie is offline
acuamie's Avatar
Joined Apr 2009
maybe yes or maybe not. but we can learn something here. thanks to our friends here that gave me the idea for how to fly and mod the glider. sometimes i ending up flying the glider with a way of flying the warbird.
sometimes we need a devil advocate to make thing right.. hehehe..
Old May 02, 2011, 07:09 AM
Ireland, Cork
Joined Oct 2010
This is what you wana get ..
http://www.r2hobbies.com/eng/proddet...pl2402004_mode
Fit a Turnigy 2836 Motor , 9x6 prop and fly it like a hot liner WOT all the time...
Old May 02, 2011, 08:16 AM
acuamie is offline
acuamie's Avatar
Joined Apr 2009
i've place an order for this glider and had to wait for another 10/17 days to my front door...
http://www.hobbyking.com/hobbyking/s...dProduct=16894
Old May 02, 2011, 08:35 AM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
I've flown the (what appears to be the original design) Multiplex version (Merlin) on the slope, and it's perfomance blew me away for such a small plane!
Woodstock 1 is offline Find More Posts by Woodstock 1
Old May 02, 2011, 10:18 AM
acuamie is offline
acuamie's Avatar
Joined Apr 2009
**gulp**
Old May 03, 2011, 08:47 PM
acuamie is offline
acuamie's Avatar
Joined Apr 2009
maybe i'll convert it to pylon racer. heheh
Old May 08, 2011, 03:56 PM
maddawg1 is offline
Find More Posts by maddawg1
maddawg1's Avatar
so-cal
Joined Jun 2010
Maiden my Phoenix 2000 today 1st flight 27min hardest thing about flying this plane is landing took 6 passes to get it slowed down to land gest i will have to install flaps
maddawg1 is offline Find More Posts by maddawg1
Old May 08, 2011, 04:43 PM
Ireland, Cork
Joined Oct 2010
Waiting for the winds to die down,
so I can go out and Fly my Phoenix with the 9c Futaba I've just got..
See if the Phoenix can Crow..
Old May 08, 2011, 04:53 PM
Joined Dec 2005
Not until Tuesday or Wednesday !
Discussion Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 KillerCut Electric Sailplanes 20 Jun 22, 2016 07:23 PM
For Sale HK Phoenix 2000 glider blk822 Aircraft - Electric - Airplanes (FS/W) 4 Aug 23, 2011 07:21 PM
Discussion Still having electric problems with my hobbyking Phoenix 2000, Crashvideo kyrkbymannen Electric Sailplanes 3 Jul 09, 2011 07:34 PM
Discussion hobby king Phoenix 2000 EPO Composite R/C Glider doomracing Electric Sailplanes 3 May 31, 2011 10:09 PM
