Old Nov 26, 2012, 02:39 AM
mustflynow2 is online now
Find More Posts by mustflynow2
The Sequel
mustflynow2's Avatar
Australia, VIC
Joined Sep 2011
Originally Posted by _Richard View Post
I can understand the first thing (due to the lack of the right motor incidence angle) but... I can't understand the second one. It seems a CG problem...
Full flaps
mustflynow2 is online now Find More Posts by mustflynow2
Old Nov 26, 2012, 03:51 AM
ilipin is offline
Find More Posts by ilipin
ilipin's Avatar
Россия, Пермский край, город Пермь
Joined Jul 2011
My Phoenix 2000 setup:
At first time, I decide do not install anything else on sailplane - just motor, esc, serovos ans rx.
But FPV won!
I had to add spare parts, they mustn't stay on the ground:
FY30A for stabilization,
FY117 OSD with current sensor.
Fatshark camera with tilt+shift.
Myflydreams AT module
900Mhz video tx
Yea, sailplane is not a FPV model, spare place isn't enough
Ele and rudder servos I moved to tail. I use a digital servos with micro form factor D05010MG. 0.5 kg/cm is enough.
How I plan to use new plane: for fun and training. Use a heavy Raptor with Sony Nex for training flights and stuns very nervous for me
Maiden flight:
http://www.youtube.com/watch?feature...&v=MC2NqSKl2jA
I think, camera becomes b/w after I give 12v instead of 5 And it shows IR now
Still waiting a head tracking
ilipin is offline Find More Posts by ilipin
Old Nov 26, 2012, 04:44 AM
_Richard is offline
Find More Posts by _Richard
Joined May 2012
Originally Posted by mustflynow2 View Post
Full flaps
Aaaaaah! Ok! It has been a "language trap": "Without power and full flaps" was for me "Without power and (whithout) full-flaps".
I've got "butterfly" for landing, with some "down elevator" mixed in.
_Richard is offline Find More Posts by _Richard
Old Nov 26, 2012, 05:30 AM
The Sequel
Australia, VIC
Joined Sep 2011
I figured that was what he meant. Perhaps pulling flap at some speed and ballooning it up. i got butterfly set up too, but really don't use it as it is very manageable and doesn't carry alot of energy.
Old Nov 26, 2012, 04:03 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
But FPV won!
900Mhz video tx
Maiden flight:
just pure sweetness !!! Thanks !
fastfwd is offline Find More Posts by fastfwd
Old Nov 26, 2012, 04:40 PM
The Sequel
Australia, VIC
Joined Sep 2011
Nice maiden ilipin, you have lots of space to fly. Very bleak though. Fpv won out, easier on the eyes? Loved the pan out to the wing! I'm stuck flying mostly in the city.
I may benifit from moving tail servos aft as my set up is heavy and I need to move my batt as far back as possible, could you post some pics of how you positioned your servos if possible? Would like to see. How is your video range? Reckon you could top 2000 ft?
Old Nov 26, 2012, 06:55 PM
HoosierGuy is offline
Find More Posts by HoosierGuy
HoosierGuy's Avatar
United States, IN
Joined Jan 2012
Very very nice ilipin!!!
HoosierGuy is offline Find More Posts by HoosierGuy
Old Nov 27, 2012, 01:36 AM
gdouglas is offline
Find More Posts by gdouglas
Camber down and screw it up.
gdouglas's Avatar
United States, MT, Kalispell
Joined Aug 2004
Originally Posted by Markran View Post
I received the Phoenix 2000...[LIST=1] I'm trying to figure out what happened with the throttle not responding before tempting gravity again. I've never had that kind of problem before. My radio has always been reliable and the receiver module I was using has worked reliably in another plane. The Phoenix was only 150 feet or so away from me. I was using the stock four servo set up (no flaps). Is this rapid loss and return of response consistent with the description "brown out"? Is this likely attributable to the stock ESC/BEC with only four servos? I now have a 3v SBEC on order from HK. What else should I check? Can anyone suggest troubleshooting steps or advice?
Mark, Ouch, sorry to hear about your unplanned meeting with Mother earth. During your post, or in any of the replies, I don't see anything about a range check. You DID do a range check before flight, right? On my Spektrum, it's one of the menu items. It puts out less RF power from the transmitter, and you're supposed to still have complete control at 30 paces, I believe it is. You might need your radio manual to see how to do it. Highly recommended anytime you move stuff around or put electronics into a new airframe.
I've been thinking about a scenario where the propeller blade is stuck on the canopy, and you try to give it full throttle. A stalled motor draws LOTS of current, probably enough to pull the voltage down below the threshold of the receiver and/or servos working. This could cause a power off type reset. Once the airborn electronics have reset, it should recover, and you should have control again, not sure why you didn't.
But anyway, first thing I would do is a range check of your radio. Better to have someone hold the model, and give it full throttle, and move all servos continually while doing the check.
Good luck.
Greg
gdouglas is offline Find More Posts by gdouglas
Old Nov 27, 2012, 01:01 PM
fastfwd is offline
Joined Mar 2012
new phoenix evolution just arrived , start the build later tonight, first thing to go will be the stock esc,then the stock clevis's and put in extra hinges on rudder .. fun fun fun !!
Old Nov 27, 2012, 10:17 PM
Lou_p is offline
Find More Posts by Lou_p
United States, MD, Baltimore
Joined Oct 2011
What battery connectors came with your stock version, also what size battery, amp wise?
Lou
Lou_p is offline Find More Posts by Lou_p
Old Nov 27, 2012, 11:49 PM
Markran is online now
Find More Posts by Markran
Markran's Avatar
United States, CA, Sacramento
Joined Aug 2011
Good luck.
Greg
Thanks for the tips Greg!
Markran is online now Find More Posts by Markran
Old Nov 28, 2012, 08:00 AM
viking60 is offline
Find More Posts by viking60
High Altitude Flyer
viking60's Avatar
Fairplay, South Park, CO
Joined Sep 2005
Lou
Lou,
mine came in a couple of weeks ago from Hobby King's USA warehouse with the Deans Powerpole battery connector. I changed out to an XT60 connector, since the Nano-Tech batteries I use come with them.
VIKING
viking60 is offline Find More Posts by viking60
Old Nov 28, 2012, 10:09 AM
fastfwd is offline
Joined Mar 2012
Lou
No battery with this one.30 amp esc, with a deans connector, will put in a 40 amp esc
Old Nov 28, 2012, 10:28 AM
Lou_p is offline
Joined Oct 2011
Thanks Guys..
Old Nov 28, 2012, 04:33 PM
fastfwd is offline
Joined Mar 2012
man is there a real english manual that tells a guy which screw goes where on these planes ? Hate to put wrong screw in and mess up threads on plastic parts.
Discussion Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 KillerCut Electric Sailplanes 20 Jun 22, 2016 07:23 PM
For Sale HK Phoenix 2000 glider blk822 Aircraft - Electric - Airplanes (FS/W) 4 Aug 23, 2011 07:21 PM
Discussion Still having electric problems with my hobbyking Phoenix 2000, Crashvideo kyrkbymannen Electric Sailplanes 3 Jul 09, 2011 07:34 PM
Discussion hobby king Phoenix 2000 EPO Composite R/C Glider doomracing Electric Sailplanes 3 May 31, 2011 10:09 PM
