United States, CA, Chico
Joined Mar 2011
Re: Motor Mount
From what I've been able to "recently" piece together on the motor mount situation I'm gonna guess that Lanyu has not only updated their 2.6 big boy but possibly the 2m as well as noted in posts above #2141, 2142, 2146
Ck out Ali's vid on 2.6 new motor mount. Also read in his notes below the video he makes mention - quote "It seems like they have finally resolve the issue with this new motor setup that they put on Phoenix Evolution glider and OTHER (2m model?) gliders."
Take it for what it's worth boys (& girls) it looks like the guys "down under" are the first (maybe because they're closer to China than we are) to get the 2m "V2" and the rest of us are and we're just gonna have to wait our turn in line. Please - NO CUTS!
Joined Mar 2011
Hoosier, I could have it all wrong and maybe all of them are set up the way yours is but from what I saw in Ali's vid his had the latest update motor mount? I just want to sort this all out before I lay down the $ and have to do a front end mod.
G'day all you P2K devotees ...
Hmmm ... Dunno if my ARF P2K is a V2 version, 'cos I bought it from HKG, because the SYD w/h was Nil Stock ... although I think they've got some more in now ... as they sent me an email reminder ... six times in a row ... ![]() Anyway, I don't know what's been done to the motor mount on the inside of Ali's fuselage, but from the outside it looks very little different from the O.E. motor mount hardware that came with my model. I had already decided to scrap & bin this stuff anyway because of info gleaned from a good few earlier P2K posts, and rebuilt the motor mount to give far better heat insulation, and strengthen that very thin plastic firewall ... ref. post 2228 ... which shows pretty well what I did. I note here that Ali's motor still got very hot, and does not bode well for that easily softened plastic fuselage nose area. ... He pulled his finger away PDQ ![]() Having noted that, and as there should be at least double the area for exit air holes as inlet slots, I reckon that additional cooling air exit holes would have to be added in addition to that very small cooling air exit hole right at the back of the fuselage. This has now been modified on my fuselage, opening out that hole almost completely, only leaving sufficient tail post required for the new lower rudder hinge ... which I posted about some time later. I intend opening up the slot in the bracket between the two tail-group mounting screws as well, and in addition perhaps a slot cut in the canopy towards the back end. Also if I can get a couple of cut down plastic spoons to stick to the fuselage, I'll be adding them to the original inlet holes too, to assist in directing cooling air inside! ... these spoon inlets, which I noted in someone's earlier post, can go some way to cure the prop blade catching in the canopy as well. ![]() Now that I've received my servos from HKG ... very slow shipping ... not their fault ... I'll be modifying their lead lengths to suit the four wing servos, which will hopefully mean the darned thing will be somewhere closer to getting finished ... and then programmed. I've never known an ARF to take so long to be put together! ![]() So unless something else comes up, I'll lay off posting until it is! Daffy. |
Australia, VIC, Chadstone
Joined Dec 2011
Motor -> PCB -> Wood -> Plastic(fuse) -> Metal Plate Note NO WOOD outside. It looks like there are at least three versions of the motor mount sandwich: V1: Motor -> PCB -> Plastic(fuse) -> Metal Plate Users added their own Wood plate to the inside, http://www.rcgroups.com/forums/showp...&postcount=318, before the kit started shipping with the wood pre-installed: V2: Motor -> PCB -> Wood -> Plastic(fuse) -> Metal Plate And now it seems there is a third variation: V3: Motor -> PCB -> Wood -> Plastic(fuse) -> Wood -> Metal Plate The V3 obviously comes with a down side of less prop shaft length for the collet to grip and an increased likelihood of loosing your spinner. What Lanyu really need to do is produce a V4 with a motor/prop combo that does not overheat as severely as the current. Versions aside, I'm of the opinion that it's more important HOW you use the motor than WHAT version of the mount you have. If your motor is getting that hot that you need an extra layer of wood on the outside (V3) to insulate the plastic from the metal plate (which is only heated by the motor screws!), then surely it is just a matter of time before your motor loses performance or dies completely? So how hot is too hot for a motor? |
I have left the daylight world and entered the night world!!! No, I'm not a vampire. I'm a NIGHT FLYER!!!
I put LEDS on my glider. I spent three hours or so soldering wires last night and toinght I flew my Phoenix Evolution when the sun was going down. After a few minutes up the sun was down and it was dark. A few cars slowed down to take a look too! It was a really neat and new experience and I'm hooked, more night flying! More LEDs! |
The 2836-1000 (Wich is actually more like 1200-1400kv) comes with its own 4mm collet adaptor.. wich you can swap with the piece in the stock propeller cone.. thats what i did and so far never had problems .. simply replace the piece wich grabs the shaft with the one that comes with the 2836-1000
| Thread Tools | |
| For Sale HK Phoenix 2000 glider | blk822 | Aircraft - Electric - Airplanes (FS/W) | 4 | Aug 23, 2011 07:21 PM |
| Discussion Still having electric problems with my hobbyking Phoenix 2000, Crashvideo | kyrkbymannen | Electric Sailplanes | 3 | Jul 09, 2011 07:34 PM |
| Discussion Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 | KillerCut | Electric Sailplanes | 14 | Jun 06, 2011 09:57 AM |
| Discussion hobby king Phoenix 2000 EPO Composite R/C Glider | doomracing | Electric Sailplanes | 3 | May 31, 2011 10:09 PM |
