United States, IN, Bloomington
Joined Feb 2008
Yea, I kinda thought about all this kind of stuff after. During was just a screaming streak in the sky. Happened way too fast. |
France, Midi-Pyrénées, Balma
Joined Aug 2011
does someone tried to use laminated film on the phoenix wings?
Hello,
when building ultrabatics very light glider, there is now a tendency to cover EPP or EPO wings with laminated films. See for exemple http://www.rcgroups.com/forums/showp...4&postcount=25 (There must be better links somewhere) I plan to test it on my new phoenix. If someone tested beforehand, the experience mith be valuable ztrem |
I finally installed my new Turnigy 2836 motor. I hooked up the watt meter and it seemed to read fine up to half throttle or so. Then I ran it up to 100% throttle to see what it would read and the motor mount started breaking/coming lose and I got bad vibrations.
So now I have to put a fiberglass sheet on the nose again or completely rip out that plastic motor mount and put in a a self made one made out of wood or something and then fiberglass it in. |
Read post 2187 for my fix which has proved to be far stronger than that paper thin moulded-in plastic firewall, despite the inclusion of the grossly inadequate, and worse thanuseless extra parts in the kit. ![]() If this mod. fails I'll eat the fuselage ... and that stupid Rudder too, with it's woefully designed lack of a lower hinge, which I've also now corrected with a little thought and butchery to the back end of the fuselage. ![]() However, suffice it to say, my motor mount mod is good and strong, which, with your more powerful motor it obviously isn't! ![]() Just remember that most, in fact just about all, glues do not work on the plastic fuselage, and the contact cement glue I used to hold the inner former in place, is really only to hold it in place until the actual outer ply former/motor mount is screwed to it with the four small 4g self-tappers through that woefully thin plastic firewall, and into the inner ply former to form a ply/plastic/ply sandwich, which will now be adequately strong, being now somewhere over 1/4" (6mm) thick, although the motor is actually mounted against the outer 1/8" (3mm) motor mount, as noted in my earlier post. I hope this earier post repeated may help. ![]() And I also suggest you consider modifying the back end too, with the woeful lack of that lower hinge too, in order to make the Rudder control effective, which, in standard form it definitely is not! ![]() I'll advise you of how I effected my Rudder hinge mod. method if there is sufficient interest from you, or other P2K assemblers. ![]() Daffy. |
For now I'd like to give a quick summary of what I think of this aircraft ...
All in all ... I would not recommend the P2K as supplied and rigged to anyone either new to flying e-sailplanes, or even those more experienced not prepared to spend a considerable amount of time modifying the airframe, as well as binning the supplied Motor, ESC ... and the clevises, in particular, which are a disgrace, and totally inadequate for safe usage in any model. ![]() Even the rest of the included e-flight gear in the PNP version are at best of dubious quality, directly related to the price of the model. ![]() However, some flyers have, after correcting the obvious faults in the P2K as supplied, either PNP or ARF ... which version I'd definitely NOT recommend ... have eventually found that the P2K can be a very good flying e-sailplane. So it has some potential. Knowing what I know now about this model though, I would not have bought it in the first place. Too much work and time required to make it a viable, and more importantly, a safe aircraft. This is solely MHO, and others may think differently. I will continue to persevere with my ARF version though, and hope it'll be worth it! At least it's keeping my thinking cap on, fixing the obvious faults in it. The only positive is the basic price, I suppose. But even then you really just get what you pay for! Daffy. |
Ted |
| Thread Tools | |
| For Sale HK Phoenix 2000 glider | blk822 | Aircraft - Electric - Airplanes (FS/W) | 4 | Aug 23, 2011 07:21 PM |
| Discussion Still having electric problems with my hobbyking Phoenix 2000, Crashvideo | kyrkbymannen | Electric Sailplanes | 3 | Jul 09, 2011 07:34 PM |
| Discussion Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 | KillerCut | Electric Sailplanes | 14 | Jun 06, 2011 09:57 AM |
| Discussion hobby king Phoenix 2000 EPO Composite R/C Glider | doomracing | Electric Sailplanes | 3 | May 31, 2011 10:09 PM |
