I have received those on a couple of types of servos I have bought but never seen just the arm available for sale anywhere. You can accomplish the same thing using a wheel if you can find one to fit the splines of whatever servo you are using. http://www.servocity.com/html/servo_arms___horns.html Ted |
I've actually looked everywhere I can think of & even some I just dredged up....not like me to not do my 'homework'. *LOL* But that 'wheel' idea might do the trick - thanks! And for all the other comments, queries & quips.....short answer is, I'm using 'em for something else, & ease of adjustment w/o servo removal is the primary goal, & the 'intermediacy' (sp?) they'll provide, an added convenience. But first, I gotta find the darn things! Is there a thread (looked briefly) where they discuss these 'designing/building stuff' type things?? Back to Ted....you pull the trigger yet, bud? ETA? Can't wait to hear your P2K impressions!
And now, for something completely different........
Hey guys, afa lengthy motor runs & the resultant heat problems....I saw something touched upon elsewhere (offsite) which got me to thinking. (HEY, it happens!!) *LOL*
Might just be my half-arse memory but, can't say I exactly recall seeing a specific spec about the P2K being (?strictly?) a 3s-LiPo plane. What I'm wondering is, anybody ever tried a 2s pack? The lower voltage would present less heat problems....& maybe even better flight-time package thru a higher mAh tradeoff, weight-wise. Thoughts?
Lance |
Well of course you'd have less instantaneous or 'call-able' power - meaning you would have to climb more leisurely & it would take longer ( + ~50% if my headcalc's working right) to get to any given altitude. But you'd be using juice at a lower 'flow' rate (amperage) too, so by time you get to 'that' given altitude, you'd have used same amount of power/watts, less any efficiency differences. All meaning you'd produce same(-ish) amount of heat during the trip up -- but the advantage sought is to cut the peak heat. Right?
Of course, you could achieve the same effect by running at ~2/3 max throttle. Think about it. (Got a little 'eye-opener' the EagleTree readings have revealed to me. For later, but wanted to hear some mindsets on the subject first.)
Another 2 quick questions..
How are you guys placing the outer servos? Because as you know theese servos have the arm in one side of them ![]() And i realiced that if i put the servo so the arm side its near the horn .. the suplied pushrod its too long and i have to screw the quick link full to get it centered.. but if i turn arround the servo and put the arm end at the oposite side i get more room.. i want to make sure before screwing up ![]() Also.. how are you gluing the servos? i did it allready in a CloudsFly (foamie) and a SIG Ninja (not foamie but foam core wings) but here the servo sits well but seems to have lots of play.. im not sure if double side tape will hold it specially with the torsion needed to fully raise those ailerons |
Lance |
Sweden
Joined Sep 2007
I just checked my wing. I use HXTs too. I placed the servo arm away from the aileron and used the short pushrod which made a perfect fit for me.
I donīt quite remember but Iīm pretty sure I hot glued mine in. As long as the servo fits kind of snug in the servo well I find hot glue to be the perfect adhesive. The snug fit in the well keeps the servo sturdy and in place and the glue mostly keeps the servo from dropping out. Hot glue is great because itīs easy to pry loose if you have to replace the servo later. |
Yup. Took delivery several weeks ago in fact. I have all of the electronics and bits gathered and set aside but it's still in the build queue for now. Hangar space is another problem now as well. On the servo horn issue again. If you can't find what you want or one to fit your servo, make one using an existing arm and some thin plywood. Here is an example of an offset dual arm as food for thought. If you only need a single arm, make it look like the one you pictured. Attach to the regular control arm with fine wire or two tiny screws. Harden the area around the holes where the push rod will go with CA. Ted |
Secure servos
[QUOTE=JLT_GTI;21366921]Another 2 quick questions..
How are you guys placing the outer servos? Because as you know theese servos have the arm in one side of them ************************************************** ************************* I put masking tape around bottom or side that lays in wing , then some up sides where they make contact with foam Then I use RTV SILICONE , found at auto stores - which secures them. Let Silicone dry over night , later if you have to take em out ? easy to dig back out .........te |
Lance |
Thanks all for the advises..
I put double side tape for the bottom and sides and driped CA where the servo made contact with the sides.. if any need arises in the future to replace/remove them using a razor for the sides should be enought.. im tempted to use also low temp hot glue to fill some gaps and reinforce a bit the join.. just finished the servo install..now only wiring remains.. wires are allready put but i think i will need some minor extensions to the Rx wich goes inside the fuselage.. one of the flap servos is short by like 1/2cm but i think i just need to carve that cm out of the foam ... or maybe add that couple cm extra wire.. for the rest seems to be done (tought i still havent mounted the wings even once yet) only placing and fixing internal components remains.. Now we only need the weather to give a truce the afternoon of saturday to have a maiden... its been raining for 2 weeks straight now |
Sweden
Joined Sep 2007
One disparagiing note - don't expect to cut thru the cured CA adhesive later -- you'll have to cut away the foam around it.
I wrap servos with blue painter's tape - provides a little 'tooth' for the adhesive - then a pea-sized dollop of hot-glue to hold 'em in place. As Freddan said, hot glue makes later removal without damage a piece o' cake. That's at the home shop -- I also keep a roll of double-sided tape ('servo' tape, actually) in my field kit for a quick fix....tho in truth, I've loaned more of it out to others for fixes than I've used myself! Silicon, I'd be cautious with -- some types of foam don't like it. A friend of mine used it extensively on a foamie 3D kit he built. Left it out in the garage to cure overnight when he finished building it, & when he went to get it next morning to take to the field, found basically a pool of sticky rubbery substance. As with any untried material / adhesive combination, best advice is trial it first on an unaffected area! I know you've heard & read that a thousand times....but it's said that often for a reason.
| Thread Tools | |
| For Sale HK Phoenix 2000 glider | blk822 | Aircraft - Electric - Airplanes (FS/W) | 4 | Aug 23, 2011 07:21 PM |
| Discussion Still having electric problems with my hobbyking Phoenix 2000, Crashvideo | kyrkbymannen | Electric Sailplanes | 3 | Jul 09, 2011 07:34 PM |
| Discussion Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 | KillerCut | Electric Sailplanes | 14 | Jun 06, 2011 09:57 AM |
| Discussion hobby king Phoenix 2000 EPO Composite R/C Glider | doomracing | Electric Sailplanes | 3 | May 31, 2011 10:09 PM |
