Old Nov 15, 2010, 07:56 AM
NiceOh is offline
Find More Posts by NiceOh
Joined Nov 2010
How can convert simcable E-sky to turnigy 9x(JR port)
Hi, everyone.
I have Turnigy 9x Transmitter.
and I have USB Simulator-cable for E-sky TX.
I heard The turnigy 9x can use by 3.5 speaker jack.
So, I want to convert my simcable (E-sky to JR)
I know e-sky port pin place. (1,2,3,4,GND)
E-sky port like S-VIDEO port.
What can I do for convert? I need some advice and picture about convert
Here some material photo, Please,Tell me your idea for me..
http://blog.naver.com/oscturby/80118863294
Please help me, Thank you.
NiceOh is offline Find More Posts by NiceOh
Old Nov 15, 2010, 12:42 PM
Malc C is offline
Find More Posts by Malc C
UK
Joined Oct 2003
If you mean how do you change the mini-din plug to a 3.5mm jack and assuming you don't want the e-sky connectivity, then your best option would be toc ut the S video connector off and and then simply connect GND to GND and the tip of the jack plug to whatever wire accepts the PPM signal on. The only way I can think of is to plug the jack into the socket on the TX and with the interface connected try each wire in the cable to the tip terminal on the jack plug to see if it gets a result.
Without knowing what voltages could be present on the wires coming from the TX or the interface I'm not going to be held responsible if it damages your TX, the interface or both - you do so at your own risk
Malc C is offline Find More Posts by Malc C
Old Nov 15, 2010, 04:59 PM
NiceOh is offline
Joined Nov 2010
Thank you so much opinion.
I'd like to make convert socket, I will to use by VGA acc.(multi socket).
Because,I don't want to cut line original FMS S-video conncetor.
Can you tell me how to connect line to line? (GND, signal +)
Just Need I simply connect to connect 2 line?
Please tell me about pin info.
Actually , I don't know very well about this port output signal.
So, I'm worried about wrong connect.
I need a little more your description about it.
(Please, need a simple photo and explain briefly)
I found my socket info. (http://www.mftech.de/buchsen_en.htm)
When I have done, Can I use switch(gear and flap) in simulator?
-Important this thing.
Because, I already have a 4ch simulator Transmitter for only PC.
but this is no have switch. I want to use switch by TX
I'm waitting your reply, Thank you.
Old Nov 15, 2010, 05:07 PM
Malc C is offline
UK
Joined Oct 2003
If you don't want to cu off the existing plug, then you'll need to make an adapter up from an inline socket to suit the E-sky plug, connecting pin 1 (as you look at the plug on the USB interface face on it will be the reverse of that image - so it will be bottom right) to the tip terminal of the 3.5mm mono jack, then connect the GND to the shaft terminal. That should work
Old Nov 17, 2010, 12:31 AM
NiceOh is offline
Joined Nov 2010
I made it done. Succeed.
But, My plan was changed.
Because, I can't use gender(S-VIDEO).
When I make it done that had a short circuit (GND,Signal+)
So, I connection it direct line in PCB. very very Simple and good.
I have some problem in Realflght G4.5 Simulater.
I don't know setting about TX switch (Flap, Gear.)
I was check setting (pass though. but I can't use.. )
Thank you.
Discussion Turnigy 9x can't figure out flapperon Gigaah Radios 16 Mar 03, 2014 11:19 PM
For Sale Fly Sky, Turnigy 9X, Eurgle parts chicken hawk Aircraft - General - Radio Equipment (FS/W) 27 Nov 05, 2013 07:02 PM
Idea How to make FlySky/Turnigy 9X JR module compatible ppan Radios 4 Jan 12, 2011 01:38 PM
Help! How can I to convert simcable E-sky to turnigy 9x? NiceOh Radios 0 Nov 15, 2010 05:58 AM
Help! Can't get my Turnigy 9X to work with Phoenix agent1940 Simulators 1 Oct 22, 2010 01:42 AM
