Old Nov 15, 2010, 07:55 AM
SA/RCFlyer is offline
Find More Posts by SA/RCFlyer
SA/RCFlyer's Avatar
Joined Jan 2009
OV 10 Bronco
Well here we go again, and they said this was not addictive. I am in the planning stages of an OV 10 Bronco. So far I have got the 3 view downloaded from the sticky above and have started doing some measurements. I had some symmetrical wing cores cut so will be using their cord as a guide for my build. It is going to be a rather slow process and mostly out of foam the polystyrene type with a little ply and balsa here and there for added strength.
If there are some plans out there please let me know. Any comments are welcome. The attached pics are just to wet your appetite, so here goes
SA/RCFlyer is offline Find More Posts by SA/RCFlyer
Old Nov 15, 2010, 11:26 AM
larryross is offline
Find More Posts by larryross
Registered FFF Addict
larryross's Avatar
Grand Junction, Colorado
Joined Dec 2007
OH NO... I just started a C130. This is another one I want to build. What WS are you planning? Will be watching with interest. Ya I have the addiction too.
larryross is offline Find More Posts by larryross
Old Nov 15, 2010, 01:45 PM
SGTalon is offline
Find More Posts by SGTalon
SG Talon... Super Genius.
Lenox, Michigan
Joined Nov 2005
Larry, do you even have room to build another plane!?!?!
Do you need someone to help you fly all these planes? I have always wanted to spend time in Colorado!
SA,
There was another OV-10 that was rolling around on here a couple months ago. You should check that one out too.
SGTalon is offline Find More Posts by SGTalon
Old Nov 15, 2010, 02:30 PM
Whiskers is online now
Find More Posts by Whiskers
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
Good choice!
That thing could be made to fly so well..
Whiskers is online now Find More Posts by Whiskers
Old Nov 15, 2010, 02:32 PM
Ace12GA is offline
Find More Posts by Ace12GA
Ace12GA's Avatar
Canada, ON, Peterborough
Joined Oct 2009
I have built a couple of Bronco like profile planes, and they fly very well. Not exciting like a pusher jet, but really nice to fly.
Ace12GA is offline Find More Posts by Ace12GA
Old Nov 15, 2010, 03:07 PM
Whiskers's Avatar
Joined Feb 2010
Stick enough power into it and it could be very as exciting.
I met. span with two TP 2409-12 motors (400 watts, total)... I'm drooling.
Old Nov 15, 2010, 05:50 PM
larryross's Avatar
Joined Dec 2007
I think that's the problem... I do have room.
I do need someone to help me fly these... that is why I keep having to store them some where.
This probably wouldn't be a good time of year to come to Colorado unless of course you are in to skiing.
Thanks, I'll check out the other one too, but I really don't need another build right now.
SA,
Old Nov 16, 2010, 01:22 AM
SA/RCFlyer's Avatar
Joined Jan 2009
Whiskers when you say "could be made to fly so well" what must I keep in mind when building?
Old Nov 16, 2010, 04:12 AM
Whiskers's Avatar
Joined Feb 2010
Well, for me it would mean: Light, strong, bags of power and plenty of control authority... that sort of thing.
Old Nov 16, 2010, 03:40 PM
SaR is offline
SaR
Find More Posts by SaR
SaR
Ausgezeichnet
SaR's Avatar
Orlando, FL
Joined Sep 2004
Drawings
I used these drawings that were found on the net. Seem to be close to scale. I didn't draw plans just scaled-up each section.
My build:
66" ws
FF foam/balsa/ply
Outer wing panels can be removed for transport.
Using 1100 kv motors and 50 amp controllers in each nacelle
Initial flights will be with 3-cell batteries and 10\6 props then 8\6 on 4-cells
Shooting for 4 1\2 pounds but it may closer to 5 when its ready
Kent
SaR is offline Find More Posts by SaR
Old Nov 17, 2010, 01:34 AM
SA/RCFlyer's Avatar
Joined Jan 2009
Thanks for all the feed back. I am going to do most of it out of polystyrene and just the reinforcements out of ply and balsa. The construction is going to be based on the method in "Building with foam" for park flier plastics. Don't have FF here in South Africa but have loads of polystyrene. Wing span about 1.3 meters chord 250 cm
Old Nov 20, 2010, 05:08 PM
SaR is offline
SaR
SaR
Ausgezeichnet
SaR's Avatar
Orlando, FL
Joined Sep 2004
Any progress on the Bronco? Curious how the build is going.
Mine had its first flight today. Could not have asked for a better maiden. I wish all first flights were that easy! On 4 cells it hauls the mail.
Kent
Old Nov 20, 2010, 05:36 PM
den bach is offline
Find More Posts by den bach
den bach
den bach's Avatar
USA, WA, Moses Lake
Joined Sep 2008
is the bronco an early a-10 warthog type plane?
den bach is offline Find More Posts by den bach
Old Nov 20, 2010, 06:02 PM
SaR is offline
SaR
SaR
Ausgezeichnet
SaR's Avatar
Orlando, FL
Joined Sep 2004
No. It was a observation/strike/Forward air control type developed and used in Vietnam.
Here's a link to a restored German Target Tow version.
http://www.germanwing.de/Start.htm
Old Nov 20, 2010, 09:02 PM
lake flyer is offline
Find More Posts by lake flyer
lake flyer's Avatar
Joined Nov 2005
I saw somewhere that there was a proposal to put floats on these , was it ever done ?
lake flyer is offline Find More Posts by lake flyer
Cool In Flight video of OV-10 Bronco using EyePod mount... Must See!!! jarel design Electric Warbirds 56 Nov 14, 2010 12:13 AM
Wanted 48" Nitromodel/Raidentech OV-10 Bronco - any condition citation560v Aircraft - Electric - Airplanes (FS/W) 2 Oct 27, 2010 12:00 PM
Question Searching for a 48" OV-10 Bronco citation560v Electric Plane Talk 1 Oct 25, 2010 04:46 AM
Sold Hobby Hanger OV-10 Bronco (So Cal) SurfOnH2o Aircraft - Fuel - Airplanes (FS/W) 2 Sep 16, 2010 09:23 PM
