Old Mar 14, 2013, 02:54 AM
.quietguy is offline
Find More Posts by .quietguy
Closed Account
Joined May 2012
Originally Posted by simplechamp View Post
Sorry guys, didn't mean to get off topic, I tend to geek out on the electrical stuff too much sometimes, it's the part of this hobby that really interests me, I forget that others might not find it so interesting. The graphs and data I posted are testing a motor and props specifically for my SC though.
It's not that you "over did it" but that I'm not nearly as smart... your data is appreciated.
.quietguy is offline Find More Posts by .quietguy
Old Mar 14, 2013, 07:46 AM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
water rudder
Originally Posted by North_of_49 View Post
Just got back from the LHS... Flyzone water rudders came in
I'll mock one up later with the Sullivan cable and post some pics. Won't actually be installing and using it until there's actually some water to run off.
Here's quick and dirty mock-up. need to figure out how I'm going to mount the rudder, I don't think it needs to be as low in the water as it is on the Flyzone Beaver... I might mod it and also make my own horn for it that sits lower once it's lifted. (EDIT: yeah, I'll probably duplicate the Beaver's mounting position... I can see now that the SC doesn't sit very low in the water when on its floats).
North_of_49 is offline Find More Posts by North_of_49
Old Mar 14, 2013, 09:09 AM
PiperRon is offline
Find More Posts by PiperRon
PiperRon's Avatar
Joined Feb 2013
I like how you used the horn inside the fuse to keep things in line and orderly.
PiperRon is offline Find More Posts by PiperRon
Old Mar 14, 2013, 09:21 AM
Tikigod19 is offline
Find More Posts by Tikigod19
Joined Feb 2013
i might give up on all this!
Super Cub Nose Snapper (1 min 1 sec)
Tikigod19 is offline Find More Posts by Tikigod19
Old Mar 14, 2013, 09:40 AM
robschonk is offline
Find More Posts by robschonk
robschonk's Avatar
United States, NC, Avon
Joined Sep 2012
Here's a pretty slick water rudder installation:
Float Rudder for Hobbyzone Super Cub LP (7 min 46 sec)
robschonk is offline Find More Posts by robschonk
Old Mar 14, 2013, 11:08 AM
Chap1012 is online now
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Originally Posted by Tikigod19 View Post
Tiki, IMHO I think you are trying to bank/turn much too sharp. Soften the rudder input.
Chap1012 is online now Find More Posts by Chap1012
Old Mar 14, 2013, 11:17 AM
Closed Account
Joined May 2012
Don't give up, man... and maybe Chap's right, too steep on the turn/bank?
Glue that sucker back and go again!
Old Mar 14, 2013, 11:33 AM
wopachop is offline
Find More Posts by wopachop
Joined Apr 2007
Have you balanced the plane with the camera attached?
wopachop is offline Find More Posts by wopachop
Old Mar 14, 2013, 11:39 AM
wopachop is offline
Joined Apr 2007
What city you in Tiki?
Old Mar 14, 2013, 12:29 PM
Joined Feb 2013
I'm in Essex, UK guys and haven't balanced with cam (obviously not a gopro despite the stickers) but to be honest it feels ok in the air I just don't have the space to go high enough to feel confident.. I have the controller set to hi.. Mistake?
Old Mar 14, 2013, 12:48 PM
PiperRon is offline
PiperRon's Avatar
Joined Feb 2013
I felt the same way after some of my crashes. But, I quickly found out things can be repaired.
That damage can be repaired. Glue and tape. It'll be fine.
Old Mar 14, 2013, 12:51 PM
PiperRon is offline
PiperRon's Avatar
Joined Feb 2013
Take a couple of pencils and check the Center of Gravity. It makes a world of difference and it's easy to do. CoG on the Super Cub is roughly 2.25 back from the leading edge of the wing.
Old Mar 14, 2013, 12:55 PM
wopachop is offline
Joined Apr 2007
Yes balancing after the addition of a heavy modification like a camera is absolutely critical.
Just use your fingers. Measure back from the leading edge of the main wing about 2 1/4 inches or 55-60mm. Make two marks and put your fingertips on them. Plane should sit level on your fingers.
What holes does the pushrod attach to on the servo arm and control horns?
Most people use the outter most hole on the servo arm.
Then adjust the amount of throw using the control horn.
Outer hole on the control horn=less movement.
Closer holes will make it move much more.
So to start off you could try the outter most holes on both servo arm and control horn.
I would definitely check the plastic firewall. It can pop loose real easy. Also if youre running the stock gearbox it most likely will be cracked and also have a bent shaft.
Old Mar 14, 2013, 01:03 PM
Chompwat is offline
Find More Posts by Chompwat
Tally Ho Chaps!
Chompwat's Avatar
United Kingdom, England, Ipswich
Joined Mar 2012
Hey Tiki, I'm sure I can speak for all that have gone the DIY route, we have all been there!
And still are sometimes!
It is frustrating, but when it starts to come together it is so much fun!
Don't give up mate!
Where are you in Essex?
I'm an Essex Boy now living in Suffolk, but I still work in Colchester.
Chompwat is offline Find More Posts by Chompwat
Old Mar 14, 2013, 03:08 PM
chucksolo69 is offline
Find More Posts by chucksolo69
United States, CA, Oceanside
Joined Apr 2011
Tiki, just a qick question. How long have you been flying the Super Cub?
chucksolo69 is offline Find More Posts by chucksolo69
Discussion Ultimate HobbyZone SuperCub Help Thread (part 3) ArsonDave Beginner Training Area (Aircraft-Electric) 33164 Nov 14, 2010 11:35 PM
Discussion Ultimate HobbyZone SuperCub Help Thread (Part 2) guapoman2000 Beginner Training Area (Aircraft-Electric) 1102 Jul 03, 2008 11:34 AM
Discussion Ultimate HobbyZone SuperCub Help Thread (part I) TheDustyPagan Beginner Training Area (Aircraft-Electric) 8442 Apr 19, 2008 08:23 PM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 01:00 AM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 10:35 AM
