Depending which props you use, you might have to ream or drill the prop hole to fit on the adapter which is normal. Some props come with a large hole and a set of different size inserts. |
I flew the ealier model that was powered by the Nimh batteries a few years ago, which flew just fine. Recently I bought a cub, and did the brushless upgrade, with the eflite 480, 30 A esc and new 9g servos. The trim is fine, it turns left and right, up and down, no problems, but everytime i try to fly it, it will go up and to the right, eventually crashing . Everything looks perfect on it before take off. I dont get it, this plane from before flew so easily with duct tape and other battle scars and now i have a new plane that cant into the air. The wings are centered, I use half throttle for takeoff and it seems nose heavy when taking off from the ground, when hand launched it does flips. Any suggetions would help.. I checked the COG it seemed to be where it should, unless Im missing something here i dont get it. Does the brushless motor and mount weigh more than the brushed gear box and motor, thinking about putting the old motor back on cause I wanna fly. I did all my research before ordering the parts, and thought it would be no problem.
480 eflite, eflite 30 a esc, hxt-900 9gservos, orange rx, and dx4 Frustrated Flyer... |
If it was fine before then clearly something has changed! The weight and the weight distribution will both have changed from the stock set up. You haven't said how you have mounted the new motor. Have the stock down thrust and side thrust angles been retained? Where is the ESC positioned. What size Lipo are you using and how is it mounted? Again weight and COG will be affected. I don't understand when you say everything is trimmed fine, how have you managed to trim in flight if it is flying as you say? The cub will fly straight out of the box on a stock set up, so if nothing else has been altered the answer lies in the changes you have made. |
How did the plane fly before you did the B/L conversion, you haven't said!
If it was fine before then clearly something has changed! It was new, and i changed it over. Never flew it before the change.The weight and the weight distribution will both have changed from the stock set up[/B]. You haven't said how you have mounted the new motor. Have the stock down thrust and side thrust angles been retained? Where is the ESC positioned. I bought the mount from custom rc parts,it has the angle on the mount aswell, the esc is velro'd inside the fuse What size Lipo are you using and how is it mounted? Again weight and COG will be affected. Im usign the hobbyzone 1300mah that it came withI don't understand when you say everything is trimmed fine, how have you managed to trim in flight if it is flying as you say? When i say trimmed, the elevator is aligned, aswell as the rudder before takeoff. And they move fine left,right, up,down |
The cub naturally climbs under power, this will be exaggerated with the 480 B/L motor. You can increase the tail plane incidence by adding a strip of 1/8" balsa under the leading edge of the stabiliser which will counter this a bit. Use the low rates on your Tx for starters. If hand launching try and let her get enough airspeed for the control surfaces to be effective, then back off the gas until she levels out. Trim for level flight at around half throttle, and it sounds like you need a bit of left trim too. Visually the controls may look straight on the ground and this has to be the start point, but in the air small amounts of trim make a big difference. I'm sure others will chip in too! Good luck and keep us posted!
I need auxiliary channels (not AIL) for certain accessories that get turned on and off from my Tx, like my switched landing light. i.e. gear, aux Am also trying to shave a few grams here, few grams there... where I can... to offset some of my mods and keep it as close to stock weight as possible. That Lemon-RX is feather light which is appealing. |
ModelAero
Sorry for the off topic but I seen this in my Park Flyer mag.
http://modelaero.com/Merchant5/merchant.mvc? There was a popular one out a year or two ago. Could fly off the grass, onto water, snow, whatever. It was more square and I think it had large flaps. Awesome flying! Can't remember the name. ![]() Mike. |
Joined Apr 2007
Dude just fly the damn plane. Youre playing barbie doll with a cheap foam plane made for beginners to crash and learn and have fun. |
... and this one ain't so cheap anymore with all the stuff I've done to and am still doing to it. If I crash it due to my own dumb thumbs that's one thing and I'm fine with that... if I crash or even lose it due to faulty electronics that I knew had a reputation before hand and went ahead and used them anyway I'd be kicking myself.My goal with this project, before I even bought it, was to turn it into something that I wanted if I could find it, but it apparently doesn't exist... a durable foam 1/8 or 1/9 scale Super Cub that's easy to fly, is easily repairable and has readily available parts, most of which I can get 7 days a week 10 minutes down the road from me. What I'd ideally like is to have something like the Pat Tritle designed balsa kit Super Cubs but I don't have the experience to build or, more important, repair those types of planes. Even with all my scale mods this thing will have, short of it going up in flames, there's nothing I wouldn't be able to repair on it in an hour or over night. |
| Thread Tools | |
| Discussion Ultimate HobbyZone SuperCub Help Thread (part 3) | ArsonDave | Beginner Training Area (Aircraft-Electric) | 33164 | Nov 14, 2010 11:35 PM |
| Discussion Ultimate HobbyZone SuperCub Help Thread (Part 2) | guapoman2000 | Beginner Training Area (Aircraft-Electric) | 1102 | Jul 03, 2008 11:34 AM |
| Discussion Ultimate HobbyZone SuperCub Help Thread (part I) | TheDustyPagan | Beginner Training Area (Aircraft-Electric) | 8442 | Apr 19, 2008 08:23 PM |
| The Ultimate Slow Stick Help Thread - Part 4 | Martin Hunter | Beginner Training Area (Aircraft-Electric) | 824 | May 31, 2004 01:00 AM |
| The Ultimate Slow Stick Help Thread - Part 2 | Martin Hunter | Beginner Training Area (Aircraft-Electric) | 565 | Feb 17, 2004 10:35 AM |
