Old Feb 17, 2013, 09:49 AM
quitcherbitchen is offline
Find More Posts by quitcherbitchen
Bombs away!!!
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
Buy a couple spares. That tends to keep fate at bay. Then every time you look in the drawer and see them you can grumble at the wasted money.
quitcherbitchen is offline Find More Posts by quitcherbitchen
Old Feb 17, 2013, 10:12 AM
.quietguy is offline
Find More Posts by .quietguy
Closed Account
Joined May 2012
Originally Posted by Damnandblastit View Post
The dangers of boasting. I boasted to Quityerbitchen yesterday that I have never so much as scratched the cowl on my cub.
One cowl broken.
Never gonna open my mouth again.
Let me take a wild guess here... you exclaimed, "Damnandblastit!" ?
.quietguy is offline Find More Posts by .quietguy
Old Feb 17, 2013, 10:23 AM
Bombs away!!!
Joined Jul 2011
Anyone here live near Damnandblastit? He needs a flying mate.
Old Feb 17, 2013, 10:47 AM
Damnandblastit is offline
Find More Posts by Damnandblastit
A disaster in the making.
United Kingdom, England, Selby
Joined Jan 2013
Certainly not having a good weekend - 2 planes crashed. I never used to have near do's with the cub but now I am getting a little tired of buzzing sedately round, doing loops and flying upside down, so am starting to take it out in stronger winds for the buzz..
Today with half throttle it was almost stationary over the ground with the gusts at times so it was a bit lairy.
I will have to do the aileron mod and flatten the wing almost right out with duck tape on the underside to get a bit more of a challenge. Perhaps when I have spun the AT6 into oblivion.
Damnandblastit is offline Find More Posts by Damnandblastit
Old Feb 17, 2013, 11:58 AM
PiperRon is offline
Find More Posts by PiperRon
PiperRon's Avatar
Joined Feb 2013
Last night I had the SC on the bench and I said to myself, let's add the battery and run in the brushed motor and also see how much battery life I had left after flying earlier.
While the motor was at half throttle on the bench after 3 minutes, the motor shut down. The prop doesn't spin at all with input.
So, I'm thinking the crappy guts in terms of the ESC, or something like that which I was reading last night here in the SC forum. It has weak quality and it appears I have smoked an ESC or a reciever.?? The plane just died, shut down at at the 33 minute mark.??
Thoughts please....
And, if so I am right, is this the time to go to a E-flight set up with the 480 brushless.?? I'm a beginner but can now get the plane in the air and bring it down with no damage. I think I'd likle the BL 480.
PiperRon is offline Find More Posts by PiperRon
Old Feb 17, 2013, 12:07 PM
Bombs away!!!
Joined Jul 2011
480 is like crazy power. it will be nose heavy. 450 is better, but it is up to you. I have both and the 480 is on the heavier bird with all the flaps. Speed is higher all around due to the weight and extra prop it can handle.
Old Feb 17, 2013, 12:10 PM
NWJames is offline
Find More Posts by NWJames
United States, OR, Salem
Joined Feb 2013
No more bent LG..
I think I finally fixed my landing gear for good.. I used some plastic rod ends from an old RC car and CA'd a 1/16" carbon rod to them, slid one end over the wire gear and screwed the other end to the rear float mount..
NWJames is offline Find More Posts by NWJames
Last edited by NWJames; Feb 17, 2013 at 11:47 PM. Reason: Put wrong size carbon rod that i used
Old Feb 17, 2013, 12:24 PM
PiperRon is offline
PiperRon's Avatar
Joined Feb 2013
NWJ... That looks like it will work. I like that, a lot.!!
Thanks for posting.
Old Feb 17, 2013, 12:31 PM
PiperRon is offline
PiperRon's Avatar
Joined Feb 2013
Oh, man. I just put the battery in and and I've got power.?? All operations work.!!
I'm noticing my prop shafts and spinning with slight wabble. I'm thinking the bearing, spacer is blown.??
Why does the prop shaft have wobble.?? I believe the shaft is straight when rolled on a smooth surface.
Also, does a 450 brushless motor equal the power of the stock 480 that is in a Super Cub.??
Old Feb 17, 2013, 12:32 PM
NWJames is offline
Joined Feb 2013
Thanks... I figured I need all the support I can get, my landings are not what you would call textbook after being out of the hobby for 13 years..
Old Feb 17, 2013, 12:46 PM
aeronca is offline
Find More Posts by aeronca
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
I think you will find significantly higher performance from the 450 brushless than from the stock 480-sized brushed motor. At least, that was my experience with the eFlite 450 I put in my built-from-parts SC.
Aeronca
aeronca is offline Find More Posts by aeronca
Old Feb 17, 2013, 01:45 PM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Thoughts please....
Hi Ron, could you elaborate a bit more to us in the red highlight please? I could almost take that sentence to mean you are draining your battery down.
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Feb 17, 2013, 02:40 PM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Originally Posted by NWJames View Post
I think I finally fixed my landing gear for good.. I used some plastic rod ends from an old RC car and CA'd a .030 carbon rod to them, slid one end over the wire gear and screwed the other end to the rear float mount..
I like the idea of the extra struts. But in a heavy and even a not so heavy landing, the gear gets bent back. So could that cause damage to the extra rods.
I would have thought that the extra bracing would be towards the nose.
How is the camera held on, Velcro? It could come off in flight. Or even a bad landing. it would be hard to find in grass. It does happen. I would suggest that you had a lanyard fitted.
Flypoppa is offline Find More Posts by Flypoppa
Old Feb 17, 2013, 03:55 PM
PiperRon is offline
PiperRon's Avatar
Joined Feb 2013
Yes, I was ru8nning a battery down. My post should have read "3 minute mark." I've got to edit my post.
Honestly, I would rather have the 450 brushless. Perfect. But, I'm not quite ready. I need to put a string of good flights together first.
I am amazed at how bet up my plane got and how easy it was to rebuild it. Here's a couple pictures of that nice paint job gone bad. What a long strange trip it's been...
Old Feb 17, 2013, 07:11 PM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
Hey, wop...
I just came across some info from 2 different sources that now has me leery of using the Power Up dsm2 Rx I bought from HURC. I'm thinking of pulling the trigger on a couple of the Lemon-Rx receivers... just want to get your thoughts first... and do you think the end pin version would be better to use in the SC than the top pin?
North_of_49 is offline Find More Posts by North_of_49
Discussion Ultimate HobbyZone SuperCub Help Thread (part 3) ArsonDave Beginner Training Area (Aircraft-Electric) 33164 Nov 14, 2010 11:35 PM
Discussion Ultimate HobbyZone SuperCub Help Thread (Part 2) guapoman2000 Beginner Training Area (Aircraft-Electric) 1102 Jul 03, 2008 11:34 AM
Discussion Ultimate HobbyZone SuperCub Help Thread (part I) TheDustyPagan Beginner Training Area (Aircraft-Electric) 8442 Apr 19, 2008 08:23 PM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 01:00 AM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 10:35 AM
