Old Feb 05, 2013, 04:38 PM
quitcherbitchen is offline
Find More Posts by quitcherbitchen
Bombs away!!!
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
With a name like Lemon doesn't that scare you?
quitcherbitchen is offline Find More Posts by quitcherbitchen
Old Feb 05, 2013, 05:12 PM
bstansbu is offline
Find More Posts by bstansbu
Joined Feb 2013
Maiden flight today. Took a bit of getting use to. Holy power batman. It took a lot of down elevator trim to get it to fly level. Are you guys typically needing to add some lead weight to the front to get a better CG? I think maybe it is tail heavy a bit causing my flight characteristics to be off a bit. I also felt that maybe I'm not getting enough aileron throw. I will try adjusting which hole I go in on the control horn.
bstansbu is offline Find More Posts by bstansbu
Old Feb 05, 2013, 05:21 PM
Bombs away!!!
Joined Jul 2011
You are tail heavy or you need to shim the front of the rear horizontal stab 1/8" in the front leading edge.
Old Feb 05, 2013, 06:08 PM
wopachop is offline
Find More Posts by wopachop
Joined Apr 2007
Measure back 2 1/4 inch from the front of the main wing. Put your fingers on the marks and see if the plane balances.
The new motor is lighter i had to move my battery more forward. Try moving components before adding weight if ya can.
wopachop is offline Find More Posts by wopachop
Old Feb 05, 2013, 07:06 PM
Bombs away!!!
Joined Jul 2011
There isn't much room to move components in a Super Cub. Just add a little lead to the firewall and you should be fine. I usually do put the ESC up front in the cowl though. Plus a smidge of lead.
Old Feb 05, 2013, 07:33 PM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
I use this for adding weight to things. I embed some of it in some butyl putty and I can stick it anywhere I want. I use it when balancing my RC truck/buggy wheels. It's basically shot pellets.
http://www.greathobbies.com/producti...rod_id=DXMBD38
Description:
North_of_49 is offline Find More Posts by North_of_49
Old Feb 05, 2013, 07:38 PM
Rcbyair is offline
Find More Posts by Rcbyair
How's the wind today?
Rcbyair's Avatar
Canada, ON, Toronto
Joined Oct 2011
I had to add 30 grams to my fire wall. I recall my first test flight with my Project Cub BL conversion being just like yours.
Rcbyair is offline Find More Posts by Rcbyair
Old Feb 05, 2013, 07:52 PM
wopachop is offline
Joined Apr 2007
Use the lipo to balance.
It does not have to be constrained by the shape of the battery box.
Mine is stuffed a couple inches into the foam firewall to balance out.
Lighter is better with cub. No need to add weight on purpose.
Old Feb 05, 2013, 08:27 PM
bstansbu is offline
Joined Feb 2013
Can you explain what you mean?
I can't move anything else fwd. I could put the esc in the front by the Motor but that would require soldering extensions and I don't want to tackle that just yet
Plus the esc weighs next to nothing.
I'm going to head to the local tire shop and see if they can spot me an oz worth of the tire balancing lead. I'll stick some to the fire wall.
Old Feb 05, 2013, 09:05 PM
Bombs away!!!
Joined Jul 2011
You need to change the tail plane incidence my putting a popsicle stick under the leading edge of the horizontal stab and then screw it down. Just in the fuselage area.
Old Feb 06, 2013, 02:57 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
I can't understand why it should be nessesary to change the incidence of either the tail or main wing. If the COG is correct then that should be it.
When the power system is changed, then of course if lighter motors are used then extra weight needs to be added to the front.
With extra power the SC will want to climb. This is what the trim controls are for.
Trim for climb, trim for level flight, and trim for landing.
Flypoppa is offline Find More Posts by Flypoppa
Old Feb 06, 2013, 06:20 AM
Bombs away!!!
Joined Jul 2011
Try it you'll like it.
Old Feb 06, 2013, 07:54 AM
Turner2 is offline
Find More Posts by Turner2
Tallahassee, FL
Joined Sep 2009
Originally Posted by Flypoppa View Post
I can't understand why it should be nessesary to change the incidence of either the tail or main wing....
If the plane climbs severely under full throttle tuning wing/H-stab incidence will reduce that tendency. Ideally what you want to wind up with is a setup that has as little elevator trim as possible during your most used throttle setting.
Turner2 is offline Find More Posts by Turner2
Old Feb 06, 2013, 10:08 AM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Turner, there are many fresh water fishing weights you can try. Some have hooks whereas you could just hook inside the fuse to see how it goes. Some lead weights are flat, some long and round. The possibilities are endless.
http://www.basspro.com/Fishing-Termi...0uxaf#Category
Living in Florida, you shouldn't have a hard time finding a tackle shop..
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Feb 06, 2013, 10:40 AM
wopachop is offline
Joined Apr 2007
Man you guys are killin me hahahaha!!!!
Planes are supposed to be fun. So if you can just add some weight to get the sucker up in the air then rock on. Fly and enjoy it.
But adding weight as a permanent CG solution to a light foam plane is an all around bad idea in my opinion.
You got a huge ass lipo battery. Move it around till the plane balances. Whats the point of modifying the battery box if the end product still leaves you tail heavy?
But either way its all about fun. I think the plane will be more fun to fly the lighter you can build it though.
In terms of the angle of incidence i agree with QuitYoBitchen. That is my favorite superCub mod of all time. From what i have read previously in this thread i guess they designed the cub to have favorable flight characteristics of a 3 channel trainer. The plane naturally wants to nose up which helps keep a beginner from crashing.
Once you learn to fly that becomes annoying and actually makes the plane harder to control with accuracy. I think its easier and much more solid to raise the tail edge of the main wing. Instead of messing with the skinny footprint of the rear stabilizer. But the effects are the same. You can test the mod in about 30 seconds. Cut a strip of cardboard or stick a rubber band under the back of the main wing before you position it on the plane.
Discussion Ultimate HobbyZone SuperCub Help Thread (part 3) ArsonDave Beginner Training Area (Aircraft-Electric) 33164 Nov 14, 2010 11:35 PM
Discussion Ultimate HobbyZone SuperCub Help Thread (Part 2) guapoman2000 Beginner Training Area (Aircraft-Electric) 1102 Jul 03, 2008 11:34 AM
Discussion Ultimate HobbyZone SuperCub Help Thread (part I) TheDustyPagan Beginner Training Area (Aircraft-Electric) 8442 Apr 19, 2008 08:23 PM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 01:00 AM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 10:35 AM
