Old Dec 03, 2012, 08:34 AM
Wregie is offline
Find More Posts by Wregie
Wregie's Avatar
United Kingdom, Middlesbrough
Joined Aug 2011
So I finally got to maiden my modded SuperCub this morning. The three W's have been getting in the way up until now (Work, Weather, Wife) to be fair the Girlfriend doesn't give me grief but I felt I had to blame somebody.
It was probably a bit windy for a maiden but it was the best chance in a while so I went for it. It still needs a bit more trimming but initial thoughts are good. The mods have certainly livened up the cub. Slow crawl to instant unlimited verticle and a good roll rate.
  • Clipped wing by removing centre section
  • Carbon rod
  • E-Flight Power 10
  • RC Custom motor mount
  • 40 amp ESC
  • Turnigy 11.1 v 2200ma
I flew without the wing struts because I haven't decided on the best method to shorten them yet, any suggestions? They will be only for appearance because the carbon rod is more than stiff enough.
It still climbs quite a bit on full throttle and I was wondering if, I altered the angle of attack of the wing by raising it slightly at the rear, this would help? Any thoughts?
Wregie is offline Find More Posts by Wregie
Old Dec 03, 2012, 08:39 AM
quitcherbitchen is offline
Find More Posts by quitcherbitchen
Bombs away!!!
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
The solution is so easy you will wonder why you didn't think of it. Mark where the struts meet the wing. Cut them 1/2 inch beyond. Take them out and using a lighter heat the tip and bend up with a screw driver to make a 100 degree bend. Cool and then reinsert.
quitcherbitchen is offline Find More Posts by quitcherbitchen
Old Dec 03, 2012, 09:44 AM
jaksno is offline
Find More Posts by jaksno
jaksno's Avatar
Norwood, CO
Joined Jul 2009
Originally Posted by fishycomics View Post
I made my own cowl, with water putty, and casted a mold, used a 7-11 bottle, and heat gun to shrink on the cast, allowed cool and a near perfect cast..
Fishy', post some pics of your cowl making!
jo
jaksno is offline Find More Posts by jaksno
Old Dec 03, 2012, 03:01 PM
19000rpm is offline
Find More Posts by 19000rpm
Joined Aug 2009
  • Carbon rod
  • E-Flight Power 10
  • 40 amp ESC
I've had an SC set-up like yours for a couple of years now. It has been a blast. I fly it four seasons on 8x9 props for speed and 10x8's for thrust.
In addition to changing the AOA, the simplest things you can do are to make it a bit more nose heavy, by moving the battery, and dial in a little down elevator trim. A more aggressive step is to change the thrust angle, using a thin washer on the top 2 screws between the firewall and motor mount.
It takes quite a bit to make it fly level, WOT, because there is still a lot of wing area and asymmetrical airfoil that makes it want to continue to gain altitude the faster it goes. Take small steps until you get it where you like it. Then let her rip!
19000rpm is offline Find More Posts by 19000rpm
Old Dec 03, 2012, 04:21 PM
WVrailfan is online now
Find More Posts by WVrailfan
WVrailfan's Avatar
United States, WV, St Albans
Joined Jun 2011
Tried my Cub with floats today. I added 1 oz of weight to the nose and she flies like a dream again. Takes off and lands smooth as silk.
Jim
WVrailfan is online now Find More Posts by WVrailfan
Old Dec 03, 2012, 04:44 PM
.quietguy is offline
Find More Posts by .quietguy
Closed Account
Joined May 2012
Nice paintwork...
.quietguy is offline Find More Posts by .quietguy
Old Dec 03, 2012, 06:17 PM
Wregie is offline
Wregie's Avatar
Joined Aug 2011
Have you tried altering the AoA?
The problem I had with down trim was that when I throttled back I had to pull back on th stick. I was hoping to get it trimmed a bit more neutral across the rev range or am I dreaming?
Old Dec 03, 2012, 06:32 PM
WVrailfan's Avatar
Joined Jun 2011
Originally Posted by .quietguy View Post
Nice paintwork...
Thanks, the fuse and wing are covered with Oracal vinyl film. I chose the high vis colors because I use this with 808 cams and sometimes take it up over 1000 feet flying LOS. Plus it will be easier to find if I lose it someday.
Jim
Old Dec 03, 2012, 06:41 PM
Closed Account
Joined May 2012
Jim
1000 feet!? Holy moley!
Highest I've had my Stratos is about 150 feet... hahaha
Guess I'm truly a Noob eh.
Sorry... don't know what LOS or AOA are...
Old Dec 03, 2012, 06:53 PM
WVrailfan's Avatar
Joined Jun 2011
LOS flying "Line of Sight" as opposed to FPV. AOA "Angle of Attack" or "Angle of Attitude."
Jim
Old Dec 03, 2012, 07:18 PM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
jo
Bananarama, you know that song.
so allow me some- heck found it.
If you take note I eventually found the right bottle and got one done, just never used it. 10 months ago, I am still on the same cowl, with cutting the front out some.
trick we do to prevent the cowl from cracking is to apply tape on the INSIDE, and you do not need to go through all this trouble
I used masking tape
Hobbyzone super Cub how to make a replica Cowl (4 min 43 sec)
1500 ft plus give or take. using a altimeter by Eagle tree.
dam everytime I try looking at vimeo I see a picture
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Dec 03, 2012, 07:23 PM
zamjohn is offline
Find More Posts by zamjohn
Canada, MB, Steinbach
Joined Jul 2011
HH Super Cub
I am now flying my super cub with floats here in the cold north country. I have 480 motor in mine w/40A speed control & 10/7 apc prop. Took it up last saturday for first time w/floats and I was pretty nervous but it took off near as fast as w/gear and no I didn't have to rebalance cg. It is really a blast to fly with floats on snow. I find the landings so much easier and more graceful on snow. Had about 15-20km wind and it did toss plane around a little more and the turns were a little slower. I will try my other wing w/ailerons to see if turns sharpen up a bit. Not sure how to go about making skis as I would like to try that as well with the super cub?
Most challenging thing now is keeping fingers warm
zamjohn is offline Find More Posts by zamjohn
Old Dec 03, 2012, 07:32 PM
19000rpm is offline
Joined Aug 2009
No, you're not dreaming. It's a delicate balance. I altered all of the things I mentioned including AoA. The down elevator trim is just a few degrees. I don't have to add up elevator when I back the throttle off.
I think the increased thrust angle is the key. It pulls the nose down somewhat proportionally to the increase in speed/lift. But at lower throttle it doesn't have a much of a noticeable effect.
Old Dec 03, 2012, 11:10 PM
fotoflyer is offline
Find More Posts by fotoflyer
United States, TX, Richardson
Joined Oct 2011
Originally Posted by BamaBasher View Post
Then about 50 to 70 feet up and about 20 feet west of me the plane abruptly pitched down again. I had throttle control and rudder but no elevator. Again I watched helplessly as the plane smacked the ground, HARD this time. Destroyed the brand new cowling. The prop is toast, the new shaft is toast. Lord knows what else. I'm too po'd to look right now. The fuselage snapped in half right before the tail assembly.
Very sorry to hear about the problem with your SC. I highly recommend calling the seller and telling them the story. I have had similar disasters with brand new planes and HH has been very good to me.
Just out of curiosity, you said the fuselage snapped in half. Maybe it's my old eyes but I can't see that in the picture you posted. Did you already repair it, or maybe just set it back in place?
I hope by now you have a brand new plane and you can again go out and enjoy flying with your son. Wow, only 6 years old and he has all that interest and skill already?
fotoflyer is offline Find More Posts by fotoflyer
Old Dec 04, 2012, 04:34 AM
Wregie is offline
Wregie's Avatar
Joined Aug 2011
Thanks I will keep fiddling.. Calm day today so I wll give it another couple of flights and then go from there.
Discussion Ultimate HobbyZone SuperCub Help Thread (part 3) ArsonDave Beginner Training Area (Aircraft-Electric) 33164 Nov 14, 2010 11:35 PM
Discussion Ultimate HobbyZone SuperCub Help Thread (Part 2) guapoman2000 Beginner Training Area (Aircraft-Electric) 1102 Jul 03, 2008 11:34 AM
Discussion Ultimate HobbyZone SuperCub Help Thread (part I) TheDustyPagan Beginner Training Area (Aircraft-Electric) 8442 Apr 19, 2008 08:23 PM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 01:00 AM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 10:35 AM
