United States, AL, Orange Beach
Joined Oct 2012
Super Annoyed with the Super Cub
Took my 6 year old out to fly the SC this morning. Checked all the controls and everything worked fine. I take off, do one circuit around the field, drop a parachute man. I turned to tell my son it was okay to chase the parachute and turned back to see the plane abruptly pitch down. It was about 30 feet up and maybe 80 to 100 feet to my south. I have no elevator response. So I shut off the throttle and watched helplessly as the plane hit the ground nose first.
Broke the cowling, bent the prop shaft and landing gear. I chalked this up to some sort of pilot error. I replaced the cowling prop and shaft, straightened the landing gear and tried again. I did a range check, taxied the plane up and down the field and everything was working fine. So I did a couple of touch and go's. No issues for about 5 minutes. Then about 50 to 70 feet up and about 20 feet west of me the plane abruptly pitched down again. I had throttle control and rudder but no elevator. Again I watched helplessly as the plane smacked the ground, HARD this time. Destroyed the brand new cowling. The prop is toast, the new shaft is toast. Lord knows what else. I'm too po'd to look right now. The fuselage snapped in half right before the tail assembly. As the attached picture shows the elevator is jammed down. After the crash i tried the controls. Rudder works, throttle works, no response from the elevator. I can hear the servo make noise but there is no movement on the control surface. So I guess the servo went bad. I've only had this plane a month and I'm really angry right now. If I had crashed due to pilot error, fine. But this was an obvious servo issue that ruined my quality flying time with my son and smashed up my basically new plane. And before you ask, no this isn't due to ACT. I unplugged the sensors before I ever flew the plane for the first time. The nearest hobby store that's open on Sunday is an hour away. So I guess we'll have to fly the Champ or find something else to do today.
United States, TX, Sherman
Joined May 2012
Call Hobby Zone customer service and share all this with them - my guess is they'll replace your plane. Best of luck... ... Lennie |
Joined Oct 2012
Thanks Lennie. I was already planning on contacting them in the morning. I feel better after lunch and a nice nap. My son wants to go back to the field, watch the other guys fly and play with the Champ so the day isn't lost.
HH needs to upgrade the RTFs to 21st century electronics. DSM receivers are 5 bucks, brushed esc's are less then 10. Servos are as cheap as 3. Using a brushed motor with a gearbox is prehistoric when you can buy a 980kv motor for 10 bucks. That's why I advise people to build their own from parts. It's simple and you wind up with a more reliable system . You don't need a lot of tools and it's cheaper. Here's a build log on a SC with the stock brushed motor that works very well. http://www.rcgroups.com/forums/showthread.php?t=1214571 If someone is interested in doing this as a brushless version I can post that also...with bolt on parts..not something you have to create, as in the motor mount. |
![]() Might floats do the same? They are adding "flying surface" area ,and probably some lift, to the plane after all... I just add enough down elevator trim to make the plane behave as normal/compensate for the added "flying surfaces", no need to weigh it down/make it more nose heavy when flying with skis... |
Joined Oct 2006
Plus 1 call HH, be calm, about it, it is a one time deal. They will send you a new plane 100%. Reading this thread, deep in it, XPORT. that is the drop module, my guess, hope I am wrong, may have caused the issue? For me. I can no longer fly a bigger prop, I get cut outs. I used the drop module a few times, but do not blame it, I have reverted back to all stock. and my brown outs are no longer. I made my own cowl, with water putty, and casted a mold, used a 7-11 bottle, and heat gun to shrink on the cast, allowed cool and a near perfect cast.. I improved where I do not need to use it yet. but something to look into. thin cowl, a money making scheme adds up in the long run.Now my Cub is getting old so anything today goes. will look for a replacement one day ![]() Keep us posted about your experience with HH |
| Thread Tools | |
| Discussion Ultimate HobbyZone SuperCub Help Thread (part 3) | ArsonDave | Beginner Training Area (Aircraft-Electric) | 33164 | Nov 14, 2010 11:35 PM |
| Discussion Ultimate HobbyZone SuperCub Help Thread (Part 2) | guapoman2000 | Beginner Training Area (Aircraft-Electric) | 1102 | Jul 03, 2008 11:34 AM |
| Discussion Ultimate HobbyZone SuperCub Help Thread (part I) | TheDustyPagan | Beginner Training Area (Aircraft-Electric) | 8442 | Apr 19, 2008 08:23 PM |
| The Ultimate Slow Stick Help Thread - Part 4 | Martin Hunter | Beginner Training Area (Aircraft-Electric) | 824 | May 31, 2004 01:00 AM |
| The Ultimate Slow Stick Help Thread - Part 2 | Martin Hunter | Beginner Training Area (Aircraft-Electric) | 565 | Feb 17, 2004 10:35 AM |
