Old Jan 16, 2011, 07:27 AM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Originally Posted by Naval Warfare View Post
gentleman??? Used loosely right?
Hey Dale, got your car all fixed the way you wanted. We can go flying today.
Fleetwood Hopping (0 min 20 sec)
2500GENE is offline Find More Posts by 2500GENE
Old Jan 16, 2011, 07:44 AM
Naval Warfare is offline
Find More Posts by Naval Warfare
Screw the wind, let's fly!
Naval Warfare's Avatar
United States, GA, Sautee Nacoochee
Joined Feb 2008
Originally Posted by 2500GENE View Post
Did ya get a load of that 1400kv in those crash pics?? Fuse trashed, motor OK.What a motor!!
Hey Dale, got your car all fixed the way you wanted. We can go flying today.]
I see where you did your usual thorough job...by forgetting to put the engine back in it
Naval Warfare is offline Find More Posts by Naval Warfare
Old Jan 16, 2011, 07:57 AM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
I assumed you were going to use that 1400kv in it.
Old Jan 16, 2011, 09:06 AM
Joined Feb 2008
Good idea. Did I mention what a hot motor it was?
Old Jan 16, 2011, 09:09 AM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
Prop down. It'll run cooler.
Old Jan 16, 2011, 01:07 PM
NDS777 is offline
Find More Posts by NDS777
USA, AZ, Chandler
Joined Oct 2010
Hey guys - I'm installing a Turnigy 2217 16turn 1050kv 23A Outrunner from hobbyking with an APC 9x6 prop. I'm not sure how to mount the prop. Using four various adapters, I've come up with the following as a best guess:
Is this right?
The shaft is a little wobbly in the adapter holes. Will tightening the nut secure everything or am I supposed to drill out the smaller adapters for a tighter fit?
NDS777 is offline Find More Posts by NDS777
Old Jan 16, 2011, 01:43 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
Is this right?
Too wobbly will cause it to be out of balance. Keep as little play as possible. Ream out a smaller adapter.
Old Jan 16, 2011, 01:47 PM
Toppers is offline
Find More Posts by Toppers
Toppers's Avatar
Canada, ON, Oakville
Joined May 2008
The big silver washer goes the other (nut) side of the prop.
The prop goes directly up against the prop adapter.
The APC prop comes with various inserts to ensure a good fit. You will find one in that set that goes over the threads just... that is the one to use. Push it into the bottom (life side in pic above) of the prop and than push prop and washer onto the prop adapter.
I've never seen the plastic washer between the prop and the nut in your pic. The only thing necessary between the prop and the nut is the aluminium washer.
Cheers
Toppers
Toppers is offline Find More Posts by Toppers
Old Jan 16, 2011, 03:08 PM
Joined Feb 2008
I did to an 8x8 and man was that motor hot.
I'm watchin Deliverance on CMT right now. God I love home movies
Filmed in Tallulah gorge 70 miles from here.Tallulah must mean man killer cuz that gorge has claimed more lives than Gene-os videos
(Although Karl Wallenda did make it across on a hi wire)
Ooh, heres comes the Ned Beatty scene, gotta go...soooooeeeeee
Old Jan 16, 2011, 03:14 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
High school flashbacks?
Old Jan 16, 2011, 03:21 PM
Joined Feb 2008
Hater. You know you wished you was Ned
Old Jan 16, 2011, 06:14 PM
Heavy Chevy is online now
Find More Posts by Heavy Chevy
Vanadu
Heavy Chevy's Avatar
Canada, YT, Whitehorse
Joined Dec 2008
I've been having tons of fun with the supercub in the Clearview sim. It feels pretty close to the real one once you tweek it a bit.
Heavy Chevy is online now Find More Posts by Heavy Chevy
Old Jan 16, 2011, 06:23 PM
cloaked is offline
Find More Posts by cloaked
Why did I sell them all.
cloaked's Avatar
Australia, NSW, Sutherland
Joined Dec 2010
Care to share the tweaks you did? I looked at the settings but it made my brain fizzle out. I have just been flying it stock in Clearview with the e-sky USB controller.
Soon as I get some free time I want to get the glued and improved aussie super cub out there!
cloaked is offline Find More Posts by cloaked
Old Jan 16, 2011, 07:14 PM
Vanadu
Joined Dec 2008
Under 'easy model set up' set you ailerons, elevator and rudder all to 20 and leave expo at 0.
Under 'Advanced model setup" scroll up to the 'M' section and find 'max speed' and change them both to 60.0 Right in that same spot at max speed, you'll find max thrust, change the max thrust to 70.0
I played around with other settings but the above is how I'm flying it now. I just discoverd that even though they are not visible, it behaves on water as though it has floats. Anyways, that setup reminds me of my supercub
Old Jan 16, 2011, 07:46 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
I set mine to
"Overpowered Outrunner with 80mph wind"
and
"Crash like a idiot every flight"
just to see how NWs plane flies.
What's a good simulator to get to have some fun with? I have FMS with the controller and it works ok but I need something more. Is Clearview worth a darn? Can I fly over Colorado and break the sound barrier with it and wake those boys up? Can I buzz Dale's place with a A10 using G Earth coordinates and and take out his trailer with the vulcan cannon??
Discussion Ultimate HobbyZone SuperCub Help Thread (part 3) ArsonDave Beginner Training Area (Aircraft-Electric) 33164 Nov 14, 2010 11:35 PM
Discussion Ultimate HobbyZone SuperCub Help Thread (Part 2) guapoman2000 Beginner Training Area (Aircraft-Electric) 1102 Jul 03, 2008 11:34 AM
Discussion Ultimate HobbyZone SuperCub Help Thread (part I) TheDustyPagan Beginner Training Area (Aircraft-Electric) 8442 Apr 19, 2008 08:23 PM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 01:00 AM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 10:35 AM
