Espritmodel.com Heli Air
Old Nov 12, 2012, 02:45 PM
United States, AL, Orange Beach
Joined Oct 2012
That looks awesome!
BamaBasher is offline Find More Posts by BamaBasher
Old Nov 12, 2012, 03:02 PM
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
That's smart. Too good to fly?
Flypoppa is offline Find More Posts by Flypoppa
Old Nov 12, 2012, 10:28 PM
Noob
ManiZ's Avatar
United States, CO, Castle Rock
Joined Oct 2012
^^^ No idea what that means...but I'll say it is now good enough to fly. No more jittery throttle control; 75% throttle input actually results in 75% throttle, not 100% as it did with the FM setup the plane came with. No more noisy servos; the control movements are quick and precise.
Can't wait to fly this weekend.
ManiZ is offline Find More Posts by ManiZ
Old Nov 14, 2012, 12:31 PM
Joined Sep 2012
Today while flying my prop broke into 2 pieces . I had the dead stick it in that is the second time this is happened is this a common occurrence . Is there something i can do to prevent this?
orangephoner is offline Find More Posts by orangephoner
Old Nov 14, 2012, 12:45 PM
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
What motor and prop are you using?
If it's all stock you may have a bent prop shaft causing vibration and shattering the prop.
2500GENE is offline Find More Posts by 2500GENE
Old Nov 14, 2012, 02:03 PM
Joined Sep 2012
Its all stock and its a brand new motor mount and shaft
Old Nov 14, 2012, 08:32 PM
Joker 53150's Avatar
United States, WI, Muskego
Joined Sep 2012
I've only experienced damage at the prop tips, but that has always been due to ground contact. In fact, even after damaged the props never showed any signs of wear other than at the tips.
Joker 53150 is offline Find More Posts by Joker 53150
Old Nov 15, 2012, 12:02 PM
Joined Sep 2012
Do you think I coud be tightening the prop nut to tight? Putting stress on it?
Old Nov 15, 2012, 01:26 PM
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
That is a possibility. Over tightening could be cracking the hub without you seeing it. What make and type of props are you using? I always 'dead stick' my landings, the SC glides OK.
Old Nov 15, 2012, 08:35 PM
inside joke, inside my head
GySGT Fenix's Avatar
New Zealand, Canterbury, Christchurch
Joined Jul 2012
In my experience a broken prop or bent prop shaft is a result of the prop hitting an object while spinning for example having a mid air with a unsuspecting bird or running into a tree. I'm on my 3rd prop shaft after the previous one broke when I tried to fly it with 2 props on the shaft. TOOOOOO much torque and not enough support.
GySGT Fenix is offline Find More Posts by GySGT Fenix
Old Nov 16, 2012, 02:16 AM
United States, TX, Sherman
Joined May 2012
Now WHY would you want to run two props??
.quietguy is offline Find More Posts by .quietguy
Old Nov 16, 2012, 04:33 AM
Joined Oct 2006
I Dead stick in and at the last second or two I give just some thrust so I do not top over, in the grass
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Nov 16, 2012, 10:55 AM
Joined Sep 2012
I use to always dead stick it in but I found out (at least for me) it was better to have it at a quarter throttle ish and it makes perfect glass landings:thumbup:
Old Nov 18, 2012, 01:59 PM
Hipster Kate Upton approved!!
75zepol's Avatar
United States, CA, Chino Hills
Joined Jul 2012
I love mine. This is the first plane and I learned a lot when it was 3 channel. I recently rebuilt it and added a few things. I added a 3/16 carbon rod across the top lentgh of the wing, filled with gorilla glue which I later trimmed and put white duct tape over. I also set some weights on the wing to take some dyhedrial out but still has a little bit left. It will fly upside dow as far as I can see it
Descriptions are in the pictures.
75zepol is offline Find More Posts by 75zepol
Old Nov 18, 2012, 04:23 PM
Joined May 2012
How's it fly with all the added weight, zepol?
Nice work.
Discussion Ultimate HobbyZone SuperCub Help Thread (part 3) ArsonDave Beginner Training Area (Aircraft-Electric) 33164 Nov 14, 2010 11:35 PM
Discussion Ultimate HobbyZone SuperCub Help Thread (Part 2) guapoman2000 Beginner Training Area (Aircraft-Electric) 1102 Jul 03, 2008 11:34 AM
Discussion Ultimate HobbyZone SuperCub Help Thread (part I) TheDustyPagan Beginner Training Area (Aircraft-Electric) 8442 Apr 19, 2008 08:23 PM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 01:00 AM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 10:35 AM
