Espritmodel.com Heli Air
Old Jul 12, 2012, 07:07 PM
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Originally Posted by jaksno View Post
10x6 wood works real well with the 450 - looks scale, too.
jaksno
I don't like wooden props. Too many termites problems.
2500GENE is offline Find More Posts by 2500GENE
Old Jul 12, 2012, 07:59 PM
United States, CO, Denver
Joined Apr 2012
Originally Posted by 2500GENE View Post
A very small drop of CA on the end of the axle before putting the plastic nut back on will eliminate that from ever happening again.
Don't let it stick to the wheel.
Thanks, will do that
mwoneal is offline Find More Posts by mwoneal
Old Jul 12, 2012, 11:58 PM
United States, TX, Bryan
Joined May 2011
Brushless wooden prop suggestion for motor?
I'm working on a Piper cub project and I want to paint it in traditional J-3 Cub yellow and black.
I going brushless using this motor
I'd like to put on a wooden prop, or a plastic prop that LOOKS wooden to enhance the "real look".
Could someone suggest a wooden prop or plastic prop that looks wooden that will work w/ this motor?
When I search for wooden props they all seem to way a lot more than the plastic props and I worry that's not good, will they cause too much wear n tear on the motor?
I.E. PKZ1019 weighs 0.4 grams http://www.wholesaletrains.com/Detai...0817720http://
Whereas the Turnigy ultra-light wooden prop 10x6 weighs 35 grams. http://www.hobbyking.com/hobbyking/s...idProduct=8825
Thanks.
gigemaggs99 is offline Find More Posts by gigemaggs99
Old Jul 13, 2012, 03:09 AM
lowdive's Avatar
anaheim, ca
Joined Apr 2005
as you found, wood props are heavier and usually better suited to gas/nitro motors. you can use them with electric (brushless) but it means higher amps and more battery used to turn it. as long as the motor and battery can handle the amps it should be fine. expect lower flight times, though.
lowdive is offline Find More Posts by lowdive
Old Jul 13, 2012, 09:11 AM
Joined May 2011
Ok, thank you sir, the main reason I'm going brushless and a bigger battery 2600mah, is to get longer flight times. So the plastic lighter prop will work better for me.
Thanks again.
Old Jul 13, 2012, 01:22 PM
WVrailfan's Avatar
United States, WV, St Albans
Joined Jun 2011
What kind of wood props are you guys using? I checked the props I use most on my 450 and 480 re powered SC and found a wood Top Flite 10X5 is 14 grams, a plastic MAS Electric 10X8 is 17 grams, a wood Zinger 10X6 is 18 grams and a plastic APC 10X6 is 22 grams. I've not noticed a discernible difference in flight time and after my usual 12 minute flights my motor, ESC and battery are not much above ambient temps.
In my experience, the 8 gram between the props does not make significant difference in amp draw or flight time.
Jim
WVrailfan is offline Find More Posts by WVrailfan
Old Jul 13, 2012, 01:50 PM
Joined May 2011
Jim
Well SWEET this is what I need to look for then. I'd love to have a wooden prop on my J-3 build of the Hobbyzone Super Cub. It's a work in progress so I'm still gathering materials.
I'll search for this wood Top Flite 10X5 you're referring to.
Thank you.
Old Jul 13, 2012, 01:56 PM
Joined May 2012
Stupid question alert....
Does anyone struggle squeezing the battery into the fuselage? Is their a simple mod to make it easier?
Boro is offline Find More Posts by Boro
Old Jul 13, 2012, 02:26 PM
Joined Feb 2010
I put the end with the wire leads in first with the wire ends tucked up and out of the way. IOnce that end of the battery is in I then push the other end in. Its a tight fit but it usually goes in pretty smoothly.
jwp2 is online now Find More Posts by jwp2
Old Jul 13, 2012, 02:30 PM
Real Time Recon
realtimerecon's Avatar
smith mt. lake VA.
Joined Jan 2007
Stick it, or any other sized batt. underneath and forget about it
realtimerecon is offline Find More Posts by realtimerecon
Old Jul 13, 2012, 02:35 PM
Joined May 2011
I'm using the stock 11.1v 1300mah 3S Lipos from parkzone. I took my wife's finger-nail scissors and clipped out the back of the batter box. This way I didn't have to remove the entire box. I DID NOT clip out the back supports that connect to the screws to the battery box lid. I only clipped out the middle section.
Now I can slip the stock battery in and out w/ the label facing me as I put the battery in, so the label would be facing the ground once installed. The wires face towards the front of the plane, this allows me to slip the back of the batter in first, into the empty space I cut out from the battery box/cage. This has helped me out a lot. Prior to doing this I always felt like I was going to break something attempting to put the batteries in.
Hope this helps.
Old Jul 13, 2012, 04:21 PM
Joined May 2012
Not just me then. Cheers
Old Jul 13, 2012, 05:01 PM
Chop it, cut it, bash it
quitcherbitchen's Avatar
United States, CA, Altadena
Joined Jul 2011
The box was originally designed for nicads that's why it is so small.
quitcherbitchen is offline Find More Posts by quitcherbitchen
Old Jul 13, 2012, 05:16 PM
United States, CA, Oceanside
Joined Apr 2011
The problem is that without support of some kind, the plane feels really fragile when you put the battery in. My solution was to buy a 15 dollar airplane work stand. Now I just flip the plane on it's back in the stand and gently press the battery in with the wires facing toward the back of the plane. Fits nice and stays put.
chucksolo69 is offline Find More Posts by chucksolo69
Old Jul 13, 2012, 05:24 PM
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
when i first got my cub i used gentle consistent pressure to get the battery in. eventually i think the bbox adapted as well or maybe i just don't notice it anymore. but yeah, the first few times was annoying.
cmdl is offline Find More Posts by cmdl
Discussion Ultimate HobbyZone SuperCub Help Thread (part 3) ArsonDave Beginner Training Area (Aircraft-Electric) 33164 Nov 14, 2010 11:35 PM
Discussion Ultimate HobbyZone SuperCub Help Thread (Part 2) guapoman2000 Beginner Training Area (Aircraft-Electric) 1102 Jul 03, 2008 11:34 AM
Discussion Ultimate HobbyZone SuperCub Help Thread (part I) TheDustyPagan Beginner Training Area (Aircraft-Electric) 8442 Apr 19, 2008 08:23 PM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 01:00 AM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 10:35 AM
