Old Jul 03, 2012, 05:06 PM
Chompwat is offline
Find More Posts by Chompwat
Tally Ho Chaps!
Chompwat's Avatar
United Kingdom, England, Ipswich
Joined Mar 2012
Fortunately it is a very clean break, and the parts seem to fit back together well. My hobby shop recommended 'UHU por' which is a transparent contact glue especially for expanded polystyrene. I've not tried it yet so I'll post once the repair is complete. I was going to reinforce the repair with packing tape.
This is clearly a weak point so I may glue some CF strip externally either side of the pushrod exits.
I haven't used Gorilla Glue either. I've heard that it grows in the joint. Is that right?
Chompwat is offline Find More Posts by Chompwat
Old Jul 03, 2012, 06:49 PM
CANNONFODDER0 is offline
Find More Posts by CANNONFODDER0
CANNONFODDER0's Avatar
United States, VA, Arlington
Joined Jan 2011
Originally Posted by Endlesslag View Post
Guerilla glue....Is that the kind that runs through and gets on everything then disappears?
Originally Posted by Chompwat View Post
... I haven't used Gorilla Glue either. I've heard that it grows in the joint. Is that right?
The Gorilla Glue I used was thick and sticky like syrup. It expands and bubbles quite a bit (2x-3x according to the page) and cures by moisture, so the instructions say to dampen one surface (probably more important when I was in NM than here in VA). Some folks moved to the white version, but I haven't ran out of the old stuff yet.
v/r,
C-F
CANNONFODDER0 is offline Find More Posts by CANNONFODDER0
Old Jul 03, 2012, 11:59 PM
RexSe7en is offline
Find More Posts by RexSe7en
Go Ducks
RexSe7en's Avatar
United States, OR, Milwaukie
Joined Feb 2012
I like the white gorilla glue for these types of repairs. It expands into all the nooks and crannies creating a nice strong bond. The original gorilla glue works well too, but the white gorilla glue dries faster. With that being said, I've never used the UHU por, so it's hard for me to compare the two. I hear that the UHU por works very well though.
RexSe7en is offline Find More Posts by RexSe7en
Old Jul 04, 2012, 01:59 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
UHU POR is what I use for most of my repairs. I have even used it for complete foam model builds.
When the tail of my Cub broke off, I used it with a couple of cocktail sticks for extra re-enforcement .
You can use UHU POR as a contact glue, Allowing it to dry for a few minutes. Or an instance glue by putting the two surfaces together. This does take a little longer to dry.
I also have gorilla glue that I use at times for other type of fixes.
Flypoppa is offline Find More Posts by Flypoppa
Old Jul 04, 2012, 05:53 PM
Chompwat is offline
Tally Ho Chaps!
Chompwat's Avatar
Joined Mar 2012
In hindsight I think I should have let it dry and used it as a contact glue. I joined the two halves while the adhesive was still wet and after four hours is not fully set. However the repair is virtually invisible and everything is still in line. I will probably still reinforce the join, certainly at least with packing tape when I can find it.
Old Jul 05, 2012, 02:58 AM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Four hours? You must have used a lot of glue.
If it is not set, pull it apart and then let it dry and do it as a contact glue.
Old Jul 05, 2012, 03:02 AM
Lord_Of_Fear is offline
Find More Posts by Lord_Of_Fear
Joined Jul 2012
I have have the brushed motor super cub with nicad batteries and wondered if its prop shaft transmission supposed to be nosey when u spin the prop ?
The noise seems to come from the plastic gears, my other models are fitted with brushless motors and when i spin the prop on them they are silent.
Lord_Of_Fear is offline Find More Posts by Lord_Of_Fear
Old Jul 05, 2012, 07:00 AM
19000rpm is offline
Find More Posts by 19000rpm
Joined Aug 2009
The SC gear box is quite noisy when you are used to brushless, non geared, setups. But, it's normal to the extent that it hasn't been damaged in a crash; or worn out from use.
If the plane has been crashed it might be even louder than normal due to bent, or misaligned gears, and/or shaft, or a cracked gear case. An out of balance prop adds to the noise as well.
If in doubt; you might want to do an inspection and have a replacement gearbox on hand.
19000rpm is offline Find More Posts by 19000rpm
Old Jul 05, 2012, 07:14 AM
Joined Jul 2012
Ok thanks for the info , i will take the cowling off and have a look. it has taken 1 nose dive into the ground although i cant remember is it was less noisy before that happened or not.
cheers
Old Jul 05, 2012, 11:02 AM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
I had the test flight of my Super-cub with flaps and ailerons. Flies like a 'Funcub'.
Parkzone Super-Cub with Flaps & Ailerons. The test flight. (5 min 31 sec)
Old Jul 05, 2012, 02:03 PM
19000rpm is offline
Joined Aug 2009
cheers
Look very closely at the box. Cracks often happen in places where surfaces join and they are difficult to see sometimes. I suggest you take the gear box off of the firewall, remove the motor and twist the box. You'll see any cracks then.
Also, check to see if the large gear is running true on the shaft. If it isn't; the motor pinion will not mesh properly and there can be quite a racket from that.
The bottom line on these gearboxes, IMO, is that they were designed with low cost and functionality in mind and not efficiency. Which is OK; they do the job.
Old Jul 05, 2012, 02:07 PM
Chompwat is offline
Tally Ho Chaps!
Chompwat's Avatar
Joined Mar 2012
Mine has been noisy from new in comparison to a brushless motor. I've carried out all the checks suggested by 19000rpm and everything is running true.
Old Jul 05, 2012, 02:17 PM
jetpackninja is offline
Find More Posts by jetpackninja
Planes in flames,,,
jetpackninja's Avatar
Gravity Sucks
Joined Aug 2010
Yeah- any geared motor is going to sound noisy compared to a brushless
jetpackninja is offline Find More Posts by jetpackninja
Old Jul 05, 2012, 02:29 PM
aeronca is offline
Find More Posts by aeronca
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
https://vimeo.com/45251914
Good show, Flypoppa!
Aeronca
aeronca is offline Find More Posts by aeronca
Old Jul 05, 2012, 09:10 PM
mwoneal is offline
Find More Posts by mwoneal
United States, CO, Denver
Joined Apr 2012
Thanks guys. Sadly we pay almost the same in pounds as you guys pay in Dollars in the US. So the Champ comes in at almost 80. Still if it worked for mwoneal it may be worth the price.
My Supercub fus snapped just in front of the tailplane on it's last outing and it spends a couple of hours on the bench for every few minutes in the air.
I'd say do it if you really want to learn on your own. The Champ flies slow, and if you lose control, as long as you are high enough just kill the throttle let go of the stick, and it will self right every time. Once you feel comfortable with the champ, take a run at the SC again. It will seem much more like you can control it and know what to do.
mwoneal is offline Find More Posts by mwoneal
Discussion Ultimate HobbyZone SuperCub Help Thread (part 3) ArsonDave Beginner Training Area (Aircraft-Electric) 33164 Nov 14, 2010 11:35 PM
Discussion Ultimate HobbyZone SuperCub Help Thread (Part 2) guapoman2000 Beginner Training Area (Aircraft-Electric) 1102 Jul 03, 2008 11:34 AM
Discussion Ultimate HobbyZone SuperCub Help Thread (part I) TheDustyPagan Beginner Training Area (Aircraft-Electric) 8442 Apr 19, 2008 08:23 PM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 01:00 AM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 10:35 AM
