USA, AZ, Chandler
Joined Oct 2010
Hey Guys - I have an LP supercub with added ailerons using two HS-55 servos. The extra servos were causing brownouts so I bought this BEC.
http://www.dimensionengineering.com/SmartBEC.htm I went to hook it up but am stumped. Since the black box doesn't have separate wires for the receiver and ESC I'm not sure what to do with the 2 connectors. Anyone have any experience with this BEC or any suggestions? |
USA, AZ, Chandler
Joined Oct 2010
I agree, jaksno. If you look at the installation guide PDF, it specifically states it will handle 6 HS-55's. But the amp draw isn't adding up. I found on the net that the HS-55's pull up to 500ma, I don't know what stock parkzone servos pull. Lets say they are 500ma as well. That's 2 amps. That's already more than the peak amp rating. So I'm confused about that as well.
Legot - I agree it wasn't the best purchase. I ordered it 2 months ago (before I found servo amp draw ratings) based on the install guide saying it will support 6 servos. It just arrived last week, which is a whole different story that I'm not going to get in to. I am planning on a full electronics upgrade and was going to use this with the stock black box until I get the parts together. Obviosly, that's not going to happen. I have everything I need for a refit except an ESC. I have a spare brushless 18amp ESC and spektrum receiver. If I use a brushless esc with a brushed motor it will always spin at zero throttle correct? Toppers - The 3amp ratings most ESC's are spec'd at is for a linear BEC. Which from what I have read is a very optimistic rating. The external one I have is a switching BEC. In the end, I guess I just need to try it with the new equipment and see what happens. Live and learn. |
USA, AZ, Chandler
Joined Oct 2010
According to Dimension Engineering, "Many people don't realize
that their ESC's BEC rating is misleading. With the linear BEC built into most speed controls, the current rating decreases as pack voltage increases. For example, several popular 25A ESCs with "3A" BECs are only capable of supplying 0.5A when running from a 3s pack". I know most people will say they never had a problem - the internal BEC has worked fine. Is this just marketing hype or a true "safety" feature? |
I use Spektrum and feel safer having external UBEC's (switching
) in all 9 planes to avoid potential problems, especially the Spektrum RX low voltage brown out.I've never seen the benefit of a linear BEC in a 2.4GHz world, so never bought or used a linear BEC.... Whether this is marketing hype or necesity is impossible to prove, as you say, most people fly ESC's with integral linear BEC with no problem. For me the small investment ($4) in a 3A switching BEC is worth the effort as a bit of insurance and reduce the load (temp) on the ESC. I've been using these HK UBEC's for 3 years now without issue. Toppers |
And sorry if there were any harsh feelings earlier. I suppose that you could try to find the black box's built in bec and disconnect it, replacing it with yours, but it is most likely much more trouble than its worth. |
Seward, NE
Joined Nov 2006
Anyone need a black box or controller?
I was cleaning out a drawer tonight and found some SC stuff... I have a channel 3 controller and matching receiver. All of the ACT and both servos are still attached. The only thing missing is one of the arms on a servo and the motor/gearbox. I remember buying a SC just for the fuselage at one point so I never even flew it with these electronics. I even have an old green nimh or nicd (can't remember which that it is) and charger... Anyone have a need for any of this stuff? I figured I might try to get a few bucks out of it otherwise, I could hold on to it for some project that comes up with the kids in the next few years :-) |
Ron |
the whole number of servos supported by the built-in bec has always bothered me. on one hand, it's obvious only so much voltage can be handled by it. on the other, there are many new RTF models out that have upwards of 9 servos or more! For instance, this plane on my "to buy" list-
http://www.bananahobby.com/2076.html 10x 9gram servos plus the gear drive retracts! so, i dunno. i don't worry much about it unless i've paid a lot (several hundred) for something. |
| Thread Tools | |
| Discussion Ultimate HobbyZone SuperCub Help Thread (part 3) | ArsonDave | Beginner Training Area (Aircraft-Electric) | 33164 | Nov 14, 2010 11:35 PM |
| Discussion Ultimate HobbyZone SuperCub Help Thread (Part 2) | guapoman2000 | Beginner Training Area (Aircraft-Electric) | 1102 | Jul 03, 2008 11:34 AM |
| Discussion Ultimate HobbyZone SuperCub Help Thread (part I) | TheDustyPagan | Beginner Training Area (Aircraft-Electric) | 8442 | Apr 19, 2008 08:23 PM |
| The Ultimate Slow Stick Help Thread - Part 4 | Martin Hunter | Beginner Training Area (Aircraft-Electric) | 824 | May 31, 2004 01:00 AM |
| The Ultimate Slow Stick Help Thread - Part 2 | Martin Hunter | Beginner Training Area (Aircraft-Electric) | 565 | Feb 17, 2004 10:35 AM |
