Old Apr 22, 2012, 06:48 AM
flightphotog is offline
Find More Posts by flightphotog
Airspeed, altitude, and brains
flightphotog's Avatar
Wolverine MI Northern Lower Peninsula
Joined Feb 2009
Originally Posted by cmdl View Post
I didn't exactly pay attention to your instructions, my apologies. Cut out the last plastic strip preventing battery from being flat against firewall. Moved COG to 2.8. Good enough for me. I can fly it from here. Thanks for the practical solution jetpackninja.
Do you have at least a LITTLE experience flying? Only reason I ask is if you are very new to this, try to move that CG a little farther forward. I think the book calls for 2.25-2.5...so 2.8 will be a little tail heavy. You might be able to handle that if you have some experience, but otherwise might be a tough way to learn.
-Craig-
flightphotog is offline Find More Posts by flightphotog
Old Apr 22, 2012, 08:30 AM
smitty919 is offline
Find More Posts by smitty919
smitty919's Avatar
manahawkin NJ
Joined Dec 2009
OK just added some bands to the wing and moved my servo connections to the inside holes and my tail and rudder are in the very outer holes so i have the least amount of movement to the tail feathers..
I'm charging up a battery and hope to try it out between some rain drops
smitty919 is offline Find More Posts by smitty919
Old Apr 22, 2012, 09:17 AM
smitty919's Avatar
manahawkin NJ
Joined Dec 2009
yup it worked great no more snap loops when trying to roll or turn.....
Thanks for all the help guys
Old Apr 22, 2012, 12:02 PM
cmdl is offline
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
-Craig-
been flying for little over a month. mostly fly in windy conditions of about 8-9 mph (not by choice). very comfortable flying the cub. i'm hoping that's enough to handle a tail heavy plane. i also fly the sensei (stock) but dunno if that is useful mentioning.
update - decided to play it safe. added some nose weight. now its at 2.3.
cmdl is offline Find More Posts by cmdl
Old Apr 22, 2012, 12:52 PM
Uksaint is offline
Find More Posts by Uksaint
Tumbling Turkey
Uksaint's Avatar
United Kingdom, Nottingham
Joined Mar 2012
Nice one smitty, glad it worked out for you.
Uksaint is offline Find More Posts by Uksaint
Old Apr 22, 2012, 01:24 PM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
GREAT! I just had a feeling.
Side note : I just did a solid mount for my wing and added wooden struts from a generous member here (he will remain anonymous unless he WANTS to come forward) and it LOOKS good. For all I know, my wing might rip off!
Don
dkrhardy is offline Find More Posts by dkrhardy
Old Apr 22, 2012, 03:04 PM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Orlando
Joined Jan 2011
By the way, for those of you with a dx5- you can actually have expo on it-
Dx5e can't do that right???
Endlesslag is offline Find More Posts by Endlesslag
Old Apr 22, 2012, 03:16 PM
smitty919's Avatar
manahawkin NJ
Joined Dec 2009
what exactly will this do is it going to make say my rudder deflect when i use my ailerons?
Old Apr 22, 2012, 03:26 PM
Endlesslag's Avatar
Joined Jan 2011
No. It allows an exponential response instead of linear...softens stick response around center, makes planes less twitchy, while still allowing full control throw.
Old Apr 22, 2012, 05:16 PM
dkrhardy is offline
Joined Oct 2010
I wonder what the expo values are on that pre-set.
Don
Old Apr 22, 2012, 05:28 PM
smitty919's Avatar
manahawkin NJ
Joined Dec 2009
Its now a enjoyable plane to fly and i think i like all the extra power now lol....
I will however move out one hole on the servo end only cause i found with this setup I'm having a hard time flaring up on landing due to little elevator movement.
It keeps nosing over on landings now lol...
Old Apr 22, 2012, 08:51 PM
wopachop is offline
Find More Posts by wopachop
Joined Apr 2007
Havnt checked this for a bit. Read this page though.
Smitty, that is just way too small of throws amigo. I would expect the plane to be even harder to fly. Imagine you'd be giving full left or right stick inputs and the plane would be so slow and sluggish to react. No way you could fly that plane it wind.
Need to get used to moving the sticks less. Just like anything what feels twichy now will be super comfortable later. I would personally recommend the outter hole on the servo at a minimum for the elevator and rudder. Not sure what your aileron setup is.
wopachop is offline Find More Posts by wopachop
Old Apr 22, 2012, 09:10 PM
Endlesslag's Avatar
Joined Jan 2011
Yeah. Try middle holes on each, or whatever it came with stock. If it's still too twitchy you have to get used to not shoving the sticks in the corners, or take advantage of dual rates and expo.
Old Apr 22, 2012, 11:27 PM
jetpackninja is offline
Find More Posts by jetpackninja
Planes in flames,,,
jetpackninja's Avatar
Gravity Sucks
Joined Aug 2010
Even with 4 inch wheels mine likes nose over on grass.
I've finally been able to learn how to grease about 90% of the landings.
My big problem was trying to dead stick the landing, and with the upgraded motor, learning to add just enough throttle to keep enough airspeed to allow it to flair.
It needs just a little prop to get the right speed.
Supercub greased landing (0 min 9 sec)
jetpackninja is offline Find More Posts by jetpackninja
Old Apr 23, 2012, 08:40 AM
quitcherbitchen is offline
Find More Posts by quitcherbitchen
Bombs away!!!
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
Endless, Thanks for the post on the transmitter. That is so cool. I have a bunch of other radios, but I still like flying the Cub with stock electronics. Never needs charging and has the X-port. I can't wait though for Horizon to release the X-port adapter though to use on my other radios.
quitcherbitchen is offline Find More Posts by quitcherbitchen
Discussion Ultimate HobbyZone SuperCub Help Thread (part 3) ArsonDave Beginner Training Area (Aircraft-Electric) 33164 Nov 14, 2010 11:35 PM
Discussion Ultimate HobbyZone SuperCub Help Thread (Part 2) guapoman2000 Beginner Training Area (Aircraft-Electric) 1102 Jul 03, 2008 11:34 AM
Discussion Ultimate HobbyZone SuperCub Help Thread (part I) TheDustyPagan Beginner Training Area (Aircraft-Electric) 8442 Apr 19, 2008 08:23 PM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 01:00 AM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 10:35 AM
