Old Apr 15, 2012, 03:47 PM
scootrb4 is offline
Find More Posts by scootrb4
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
Death of a Super Cub
I could do some corny poem but the truth is I took my modified Cubby over the line today where there was no coming back.
She went all in at high speed, the extra weight tore the wing, the fuse, the tail apart.
She was my first plane. I'll always have fond memories of that....not the shredded foam flying in the breeze.
Long live Super cub memories.
scootrb4 is offline Find More Posts by scootrb4
Old Apr 15, 2012, 04:11 PM
A Rdnek is offline
Find More Posts by A Rdnek
Bruno, GOOD DOG
A Rdnek's Avatar
United States, IA, Grinnell
Joined Aug 2007
So, get another one quick.
Ron
A Rdnek is offline Find More Posts by A Rdnek
Old Apr 15, 2012, 05:57 PM
Joelster is offline
Find More Posts by Joelster
Joined Dec 2011
Originally Posted by dkrhardy View Post
I was NOT trying to offend you. I guess I should have included a "smile" so you knew I was being sarcastic, not being mean and nasty.
You are in the right area, stay around and you will get help. Anything broken needs to be replaced before you fly again. These little critters are fairly delicate and the least vibration is not good and may tear the plane apart. That is why folks balance everything right down to a gnats ................
Look at a youtube on prop balancing. Even a brand new prop may not be balanced close enough.
Don
No worries, will keep trying until I get this thing in the air again Thanks guys.
Joelster is offline Find More Posts by Joelster
Old Apr 15, 2012, 08:13 PM
flightphotog is offline
Find More Posts by flightphotog
Airspeed, altitude, and brains
flightphotog's Avatar
Wolverine MI Northern Lower Peninsula
Joined Feb 2009
Originally Posted by wopachop View Post
Ok i been thinking. So here it goes. W TF is up with the SuperChub??? I feel like there are hard core plane enthusiasts who say and do stupid things once the superCub enters the arena. I will give two examples.
On the main HobbyZone website you can click on the HZ superCub. There you find specs and modification instructions. The first major flaw is the darn website says the superCub COG is between 2.5-3 inches. That confuses new pilots like me. The COG of a plane does not have a range. Also the COG of the superCub is not even between the range they give. W TF?
Second problem is the rudder modification they teach. The designer moves the control horn forward to a meatier section of the rudder. But now the control horn is no longer in line with the pivot. Thats a major flaw to me. Or is it? Does it matter? I want symmetry between my stick inputs.
So my point...i dont frieken know. Wanted to post the picture of the control horn mod i did to bring the holes back in line with the pivot.
Its 2 control horns epoxied together. I have read glues dont stick well to the nylon horns. But just like the main HobbyZone website you cant believe everything you read.
Cant write the word W T F on this forum. Oh how cute. Reinforcing the dorky never get laid vibe that goes with RC.
wopachop - I understand your confusion and consternation! (Sorry, trying to keep up the dorkyness!) In looking at that photo, I assume that the piece of nylon control horn that they glued on there is a solid, non-moving, piece. This would mean that the attachment/pivot point of the clevis to the control horn hole is at the very tip of the added nylon piece...which looks to be even with the hinge line...and therefore a perfectly valid physical relationship.
That being said, I have been flying my SC, in one configuration or another, for 4 years, and hundreds of flights...and have NEVER had any problem with the rudder control horn! And keep in mind that I have crashed her numerous times...although not much any more. I am not sure I understand why they think it needs to be changed?!
-Craig-
EDIT - nevermind...I thought that picture you posted was THEIR mod...I now understand that was your modification of their mod...NEVERMIND!
flightphotog is offline Find More Posts by flightphotog
Old Apr 16, 2012, 10:19 AM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
Accident investigation into the Death of a Super Cub Sunday afternoon.
I determined that the Elevator failed in a high G maneuver. While pulling up out of a high speed dive the elevator broke in the middle. Due to the control arm being connected to only one side this left the plane uncontrollable. Perhaps a better pilot could have saved it. At that speed there was little time for compensatory action. It was over in a moment.
In conclusion; there is a lot of info here about reinforcing the wing to handle the high Gs a faster (brushless conversion) will allow. But I wished I had paid as much attention to the Elevator... I have an idea of how to do it with a simple piece of flat U shaped aluminum but, alas, it's too late now.
I hope this helps somebody, I know some one can say I told you so.
Old Apr 16, 2012, 11:07 AM
jaksno is offline
Find More Posts by jaksno
jaksno's Avatar
Norwood, CO
Joined Jul 2009
A simple solution: epoxy a piece of 'stick' along the top and or bottom of the center section of the elevator as a preventive measure. Soften the edges all around on the 'top side' of the 'stick', paint, and you'll never notice it.
jo
jaksno is offline Find More Posts by jaksno
Old Apr 16, 2012, 08:40 PM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
A few grams of prevention.
Old Apr 16, 2012, 10:36 PM
wopachop is offline
Find More Posts by wopachop
Joined Apr 2007
This fella seen a few flights. Looked tough sitting there wanted to share the pic.
wopachop is offline Find More Posts by wopachop
Old Apr 17, 2012, 12:34 AM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
Hey, You got enough prop on that biotch!?
Old Apr 17, 2012, 07:01 PM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
What is with those tires? I'm serious, tell me!
Don
dkrhardy is offline Find More Posts by dkrhardy
Old Apr 17, 2012, 10:14 PM
lowdive is offline
Find More Posts by lowdive
lowdive's Avatar
anaheim, ca
Joined Apr 2005
wait.... you haven't been keeping up with _every_ post? shame shame! them tires is drilled out to reduce some of their weight.
even found the posts for ya!
http://www.rcgroups.com/forums/showp...99&postcount=1
http://www.rcgroups.com/forums/showp...6&postcount=11
lowdive is offline Find More Posts by lowdive
Old Apr 18, 2012, 10:45 AM
dkrhardy is offline
Joined Oct 2010
lowdive - you KNOW I've been here all the time! But, I sure did miss the photos and narative on the "three oh" set up! So it was just a "lighten these suckers a bit" kind of thing. I thought maybe, just maybe, it was to soften the landings a bit. Tires squish rather than bounce. Not! So who is going to follow the lead and go a bit bigger, maybe three fives?
Don
Old Apr 18, 2012, 11:08 AM
jetpackninja is offline
Find More Posts by jetpackninja
Planes in flames,,,
jetpackninja's Avatar
Gravity Sucks
Joined Aug 2010
Me
Four O's
jetpackninja is offline Find More Posts by jetpackninja
Old Apr 18, 2012, 11:11 AM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
OK- maybe I exaggerated, they are only 100mm
Old Apr 18, 2012, 11:45 AM
lowdive is offline
lowdive's Avatar
anaheim, ca
Joined Apr 2005
i have 5" dubro softies.... on my 6' w.s. cub!
Discussion Ultimate HobbyZone SuperCub Help Thread (part 3) ArsonDave Beginner Training Area (Aircraft-Electric) 33164 Nov 14, 2010 11:35 PM
Discussion Ultimate HobbyZone SuperCub Help Thread (Part 2) guapoman2000 Beginner Training Area (Aircraft-Electric) 1102 Jul 03, 2008 11:34 AM
Discussion Ultimate HobbyZone SuperCub Help Thread (part I) TheDustyPagan Beginner Training Area (Aircraft-Electric) 8442 Apr 19, 2008 08:23 PM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 01:00 AM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 10:35 AM
