Old Mar 29, 2011, 06:54 PM
cloaked is offline
Find More Posts by cloaked
Why did I sell them all.
cloaked's Avatar
Australia, NSW, Sutherland
Joined Dec 2010
I just found out HK does Carbon Fibre!
Ill have to put some in the Cub wing when I eventually place an order.
I hate monthly pay
cloaked is offline Find More Posts by cloaked
Old Mar 29, 2011, 08:24 PM
wopachop is offline
Find More Posts by wopachop
Joined Apr 2007
Thanks brotha you were on it with the prop link. Made the order and just seeing this now.
So that the badass brand to buy? How does GWS compare i just bough a bunch of those whoops.
wopachop is offline Find More Posts by wopachop
Old Mar 29, 2011, 08:26 PM
anti-gravity is offline
Find More Posts by anti-gravity
In the 20' glider range
anti-gravity's Avatar
Boise, Idaho
Joined Jul 2009
Different brand for different setup
anti-gravity is offline Find More Posts by anti-gravity
Old Mar 29, 2011, 08:34 PM
wopachop is offline
Joined Apr 2007
I hate monthly pay
What size and thickness you lookin at?
Old Mar 29, 2011, 08:43 PM
cloaked is offline
cloaked's Avatar
Joined Dec 2010
Probably this
http://www.hobbyking.com/hobbyking/s...idProduct=6724
Old Mar 29, 2011, 09:17 PM
wopachop is offline
Joined Apr 2007
Ah man did i buy props for a pusher? Bought these...too weak for my brushless setup?
http://www.hobbyking.com/hobbyking/s...dProduct=10035
Old Mar 29, 2011, 09:19 PM
Boise, Idaho
Joined Jul 2009
You should be ok with that prop.
And no you didnt buy a pusher
Old Mar 29, 2011, 09:20 PM
wopachop is offline
Joined Apr 2007
Geez in a month (hopefully sooner) i better be laughing at these pretty basic questions.
Thanks again for all the help i would be way lost without forums and people willing to take the time.
Old Mar 29, 2011, 09:25 PM
wopachop is offline
Joined Apr 2007
At the time im posting this the first seen review is interesting. There are two listings for that tubing. CF3 and 4. The 3 being thicker but theyre same price.
Just heads up. Only use those rods if straightening wing right?
Even with stock motor and 10/8 when i crank hard turns im amazed the foam wing dont stap like a twig.
Old Mar 29, 2011, 09:28 PM
cloaked is offline
cloaked's Avatar
Joined Dec 2010
Well mine without reinforcement did remember
My new flat wing has a 6mm wooden dowel (Flexy but it wont snap) inserted along 75% of the wing and a whole s&%tload of 5 minute epoxy to hold it in place, plus 2 or 3 layers of packaging tape. If this wing Fails well then Im outta ideas!
I am sort of worried the wing wont generate enough lift at the moment, and am hoping the 9.5x6.5 prop will give it enough lift and speed. Oh well Ill have to wait and see, still waiting on this motor mount. Till that arrives no test flights no nothing!
Old Mar 29, 2011, 09:30 PM
Boise, Idaho
Joined Jul 2009
We all started as noobs. Eventually you will be in my position halping someone else.
Tubes are stronger than a rod, if I am correct? Just go with a tube for this size of plane.
And thats what struts are for
Old Mar 29, 2011, 09:32 PM
wopachop is offline
Joined Apr 2007
How do you determine the best thickness tube? Like 1/3 the wing thickness for example?
Old Mar 29, 2011, 09:39 PM
Boise, Idaho
Joined Jul 2009
Eh. More or less determine your flying style, and ability of the plane to put on the wing. (force)
Then guess what size, hahaha
Old Mar 29, 2011, 10:15 PM
wopachop is offline
Joined Apr 2007
How do TGS props compare with APC, EMP, and GWS?
Anyone screw around with all of them? What about balancing?
Old Mar 29, 2011, 10:24 PM
jer291113 is offline
Find More Posts by jer291113
Heli and E-Plane
United States, FL, Ocala
Joined Nov 2010
Just a heads up that there are two different 5mm tubes with different wall thicknesses.
jer291113 is offline Find More Posts by jer291113
Discussion Ultimate HobbyZone SuperCub Help Thread (part 3) ArsonDave Beginner Training Area (Aircraft-Electric) 33164 Nov 14, 2010 11:35 PM
Discussion Ultimate HobbyZone SuperCub Help Thread (Part 2) guapoman2000 Beginner Training Area (Aircraft-Electric) 1102 Jul 03, 2008 11:34 AM
Discussion Ultimate HobbyZone SuperCub Help Thread (part I) TheDustyPagan Beginner Training Area (Aircraft-Electric) 8442 Apr 19, 2008 08:23 PM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 01:00 AM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 10:35 AM
