This thread is privately moderated by superdave42, who may elect to delete unwanted replies.
Old Nov 14, 2010, 06:36 PM
superdave42 is offline
Find More Posts by superdave42
Designer
superdave42's Avatar
morgan hill california
Joined May 2004
Viper Recon Quadrocopter Hybrid
In January 2010 I had an idea to build a FPV aircraft and figured a Tri-copter would be the best layout as the front rotors are spread far apart allowing a clear view.
in January I had searched the net and was not able to find anything like this so I thought it was a neat innovation.
I started initial testing of the v-tail towards the end of January as you can see in the YouTube videos. I had the YouTube videos locked as private until today.
I always killed the gears in my yaw servo for one reason or another. so I thought about creating a servoless Tri-copter. which turned out to really be a hybrid of a Quadrocopter.
I'm a Mechanical Designer Engineer so unfortunately I was not able to design and write code to create a "proper" Flight Controller for this
All I was able to do at the time was use standard off the shelf parts and see if could just prove out the V-tail concept. Well as you can see the craft works but seriously needs a proper FC to control it and make it stable enough for FPV use.
I really could use some help from you guys to get a flight controller setup for this platform. I had thought about modifying the Shrediquette FC but I do not know enough about programming to re-do the mixer code.
I had been keeping this project secret but I found I cannot progress and finish it on my own now. I originally intended to use the FMA Co-Pilot but then did not want the environment dependency it required. I really wanted an Accelerometer based auto leveling system.
I designed the chassis before I bought all the electronics gear so really this chassis was too small in my opinion. I used Easton "cammo hunter" arrow shafts for the booms and L.A Heli MaxiR boom clamps and carbon BL motor mounts. The arrow shafts flex a lot and need to be supported to remove the flex. this was purely a POC ( Proof of Concept ) platform.
I intended to scale this up to a much larger size and have removable booms.
anyway here is the Viper Recon prototype that flew with off the shelf parts.
it was very windy in the flight video.
I used a Skookum SK360 for the 2axis gyro and a coaxial mixer and standard gyro for the v-tail.
Let me know what you guys think
Dave
DCC
Viper Recon VTOL Hybrid quad rotor (0 min 56 sec)
Viper Recon Prototype 1st flight (2 min 28 sec)
superdave42 is offline Find More Posts by superdave42
Old Nov 14, 2010, 06:48 PM
Designer
Joined May 2004
prototype
pics of the prototype build. only the chassis was custom designed.
Coaxial mixer test
Elevator Yaw tracking (0 min 27 sec)
V-Tail test fixture ( crude but served the purpose)
Test 1 mixer (0 min 33 sec)
Maiden Flight in decent winds
Another cut of the maiden flight
Old Nov 20, 2010, 01:41 PM
AtTheCross is offline
Find More Posts by AtTheCross
Jesus Freak
AtTheCross's Avatar
Southern CA
Joined Oct 2008
aside from the cool factor what's the benefits of the v tail design?
AtTheCross is offline Find More Posts by AtTheCross
Old Nov 20, 2010, 01:58 PM
Designer
Joined May 2004
Tri-copter'ish form factor without a servo.
Old Nov 20, 2010, 02:25 PM
Jesus Freak
AtTheCross's Avatar
Southern CA
Joined Oct 2008
very kewl looking for sure
Old Nov 20, 2010, 02:31 PM
Designer
Joined May 2004
Thanks man
Old Nov 20, 2010, 03:23 PM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, FL, Bonita Springs
Joined Oct 2010
I have no experience with this type of r.c., but this thing looks awesome.
3Daddict is offline Find More Posts by 3Daddict
Old Nov 20, 2010, 10:08 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Certainly very eye catching and an interesting project, but seems like a lot of work just
to avoid using a sturdy metal gear servo on the tail of a tricopter.
ian
Daemon is online now Find More Posts by Daemon
Old Nov 20, 2010, 10:25 PM
Designer
Joined May 2004
ian
Thanks Ian, yeah that thought has crossed my mind a lot. a Servo works great. but then again everyone has a servo.
Discussion X-3D X-BL Quadrocopter, general quadrocopter, x-ufo discussion PART 3 tend2it Multirotor Talk 2717 Sep 02, 2015 10:37 PM
Build Log Quadrocopter-Hybrid "Viper Recon" superdave42 Multirotor Talk 22 Nov 18, 2010 04:45 PM
For Sale Quadrocopter starter kit: Spectrolutions Dammar board (v2) + other quadrocopter gear Smokytyrz Aircraft - Electric - Helis (FS/W) 1 Apr 27, 2009 09:34 AM
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion PART 2 tend2it Multirotor Talk 2203 Nov 08, 2008 08:23 PM
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion tend2it Multirotor Talk 2529 Apr 26, 2008 07:45 PM
