Old Jul 15, 2003, 03:15 AM
Berentsen is offline
Find More Posts by Berentsen
Joined Jan 2003
answer to my previous question (power over lines ?)
Hi everybody !
Here is the answer to my question
"Power over lines ?". You can see a
short description of my first e-C/L
model under
http://home.arcor.de/berentsen/pdf/ecl_b1.pdf
where i use the wires for powering.
a detailed plan will follow in the next days.
Usage of a SPEED 400 motor is also possible, but
don't use it with short lines
Questions and/or discussion is recommend.
Martin
Berentsen is offline Find More Posts by Berentsen
Old Jul 15, 2003, 07:23 PM
Mike Palko is offline
Find More Posts by Mike Palko
Mike Palko's Avatar
Telford Pa
Joined Aug 2002
Thanks for taking the time to post the pictures and info. Did it do any type of aerobatics? At a weight of less than 5oz i would imagine it might.
I built a plane with about 150sq" and 5-6oz all up weight if i remember right (to lazy to look). I had a geared 280 with a 8 or 9 inch prop. The battery's were on he plane (6-8cells). I flew it with different cell #'s, props, balance points, and line lengths but i never got it to do much more than wingovers. All the flights were indoors by the way.
I have had much better luck with .35 size planes. Maybe because i have more interest in them and have put much more time into them. Either way i love to see what others are doing with electric control line!
Mike Palko is offline Find More Posts by Mike Palko
Old Jul 16, 2003, 02:45 AM
Joined Jan 2003
The weight was the reason for taking out the battery's. Approx. 6oz is
possible with on board battery and a speed 280 for a 5 minute flight, but it
isn't really funny. I tried a speed 400 in the same plane, and it run's
very, very good, but only 2 minutes. And these new battery's with higher
capacity are to expensive for testing only (for my opinion).
Martin
Discussion question about my slow stick power system chase4556 Power Systems 0 Jan 14, 2006 01:56 PM
Discussion Thunder Power - question about over discharge. Hovertime Batteries and Chargers 33 Mar 01, 2005 07:47 AM
Power over lines Berentsen Control Line 7 May 07, 2004 07:26 AM
My Twin is getting a little Over weight... rc capo Sport Planes 2 Aug 02, 2001 12:17 PM
question..power leads neal Electric Plane Talk 1 May 09, 2001 11:19 PM
