Aug 04, 2003, 11:06 AM
SF Bay Area
Joined Jan 2003
Flight Report
Test flew the Slinger and its awesome. Much faster than the Zagi 400x, both speed and roll rate. Roll rate was blinding on full rates. It was too hot on the first flight. If I pulled too hard on the elevator, it would snap out of it after a 1/4 loop. Had to tone down the throws and add more expo.
I tried installing a stock zagi pack (8x1700) and it wouldn't fit. The airscoop hit the top of the battery, so I used a 10 cell, Hecell pack. Much more power, but not as much flight time. Flight lasted about 7 minutes on full power throughout.
Other observations:
1) The grey and black is hard to see, as expected. Its even harder when the sun is in front of you.
2) The clear plastic winglets are invisible in the air, so that also makes it hard to gain orientation.
3) The shape of the fuse is wider than a Zagi, so its harder to get a grip. I grip the trailing edge underneath the prop and throw it like a baseball with power off.
Strega
