Old Jul 15, 2003, 02:01 AM
Stregaracer007 is offline
Find More Posts by Stregaracer007
SF Bay Area
Joined Jan 2003
Slinger B-2
Here's a picture of my GP Slinger.
I didn't particularly like the "Captain America" flagship look, so I stripped it off and painted it to look like a B-2 Stealth Bomber.
By the looks of the underside, I don't think the trim is Monocote. It came off really easily. I slid a razor blade underneath to lift up the corner and pulled the rest off.
For Paint I used Testors Model Master Enamel from a can. To prep the iron covering, I used a heat gun to tighten the covering, roughed it up with 000 steel wool and used alcohol to clean off the dust. The color is Gun Ship Grey on top and flat black on the bottom.
I still need to install servos, linkage and put panel lines on top.
Strega
Stregaracer007 is offline Find More Posts by Stregaracer007
Old Jul 15, 2003, 07:33 AM
BIFFSTER is offline
Find More Posts by BIFFSTER
BIFFSTER's Avatar
Tampa Bay area
Joined Jun 2003
Great Idea... I just bought and built my slinger yesterday...kept mine as simple and stock as it gets.... i heard it will give zagi a run. sure hope that is true have you seen one fly??? has anyone compared them next to a zagi???
BIFFSTER is offline Find More Posts by BIFFSTER
Old Jul 15, 2003, 07:34 AM
The Max-Q is offline
Find More Posts by The Max-Q
The Max-Q's Avatar
Mississauga, Ontario
Joined Mar 2003
Nice work! I also thought the paint job was a bit outworldly for a semi-scale Spirit. Nice paint job.
The Max-Q is offline Find More Posts by The Max-Q
Old Jul 15, 2003, 10:13 PM
Air 1 is offline
Find More Posts by Air 1
Air 1's Avatar
McMinnville, TN
Joined May 2002
Yeah, I've compared it to a Zagi. It all around flies like a Zagi, but faster rolls rates and I think its better all around. I really like the build time on it compared to a Zagi. Give us a flight report when you get yours going.
Air 1 is offline Find More Posts by Air 1
Old Jul 16, 2003, 09:33 AM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Compared with GWS B-2 which is comming soon.
http://www.gws.com.tw/english/product/airfly/b-2.htm
Original planning for EDF50 X2. Since USA need Over Power very much, just under engineering change to be fit for twin EDF55s.
GWS4CEO is offline Find More Posts by GWS4CEO
Old Jul 16, 2003, 10:01 AM
Mike Parsons is offline
Find More Posts by Mike Parsons
Forgot how to fly
Mike Parsons's Avatar
Atlanta, Georgia
Joined Oct 2002
**off Topic**
Mr lin,
I am normally an advocate of yours, but this is the second time in two days I have seen you spam another thread to compare (advertise) your product against someone elses. First one was with Stevensaero beta Mini pattern plane (here)and this one. Please keep to comparing or showing your items to the vendors forum and responding appropriately in these forums.
**back on topic**
Strega,
Interested in a flight report.
Mike Parsons is offline Find More Posts by Mike Parsons
Old Jul 16, 2003, 10:27 AM
peterv is offline
Find More Posts by peterv
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
With all the spars in the wing there is no Zagi flap on a power dive pull out, I had one and like the Slinger much better, especially the build time!
BTW NICE Paint job!!
Pete
peterv is offline Find More Posts by peterv
Old Jul 16, 2003, 12:02 PM
AirTek is offline
Find More Posts by AirTek
AirTek's Avatar
Joined Jul 2003
Strega.. I was thinking of painting my black.. but I decided not to because if I taped up the plastic canopy.. then removing it will ruin the paint job. Did you do anything to get around that?
Also.. did the paint job added weight that affected the flight performance?
AirTek is offline Find More Posts by AirTek
Old Jul 16, 2003, 01:32 PM
SF Bay Area
Joined Jan 2003
Slinger B-2
Thanks for looking at my pic and the comments.
I can't comment on the flight performance because I haven't finished it yet. I'm not planning any performance mods, so it should perform just like a regular Slinger; although, it will be harder to see given the color choice.
Airtek, I taped the canopy from the inside using the supplied velcro. Its the same as my Zagi 400X. I don't know how these guys are losing their canopies because mine has never come off. The weight of the paint is neglible. If you paint it all black, it will be even harder to see. I put a black widow mark on the bottom using red trim tape for added orientation.
Old Jul 16, 2003, 01:46 PM
KSU Flyer is offline
Find More Posts by KSU Flyer
KSU Flyer's Avatar
Manhattan, Kansas, United States
Joined Oct 2001
Yup, that is what Mr. Lin is all about...spamming
He has zero manners...
-Mike
KSU Flyer is offline Find More Posts by KSU Flyer
Old Jul 16, 2003, 01:52 PM
Air 1 is offline
Air 1's Avatar
McMinnville, TN
Joined May 2002
I'm also not sure why people are losing their canopies, but mine only fell off once. It was my fault because I was doing a full power dive with 8 cell 1800 mAH AA cell batteries which weighs about 2 pounds, LOL. The battery somehow unplugged the deans connector from the speed control, and I found the battery about 1 foot in the mud. My Slinger tumbled into a pond. I let my electronics dry out in the plane for a day, and it was back to normal. Tuff little outfit!
Old Jul 16, 2003, 04:21 PM
someone special is offline
Find More Posts by someone special
Atlanta
Joined Jun 2002
I am kinda confused, I am interested buying a slinger but I've heard it has several problems.
For example:
The winglets dont fit properly
The canopy doesn't fit properly that makes all the equipment to come out.
But for the value I am ready to fix these problems, any help?
Will the CA foam friendly glue work well on the winglets?
someone special is offline Find More Posts by someone special
Old Jul 16, 2003, 04:33 PM
peterv is offline
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
I had no luck with glue holding the winglets on. They extend below the wing and hit the ground on landings. The way they mount makes for very stable low speed flight though. I used fiberglass strapping tape, not pretty but does the job. Have had no problem with the canopy coming off, even in a few nose ins. Equipment mounts real easy and the canopy does not extend past the nose so is not damaged in a crash. I really like it and have had a 400x before. The plane can fly much slower, rolls are quick and inverted is excellent, a very stable wing.
Pete
Old Jul 16, 2003, 04:38 PM
Paul Penney is offline
Find More Posts by Paul Penney
Senior Member
Paul Penney's Avatar
Ancaster, Ontario, Canada
Joined Nov 2000
You can also use velcro to hold winglets on. If they come off, pop 'em back on.
Paul
Paul Penney is offline Find More Posts by Paul Penney
Old Jul 16, 2003, 05:02 PM
BIFFSTER is offline
BIFFSTER's Avatar
Tampa Bay area
Joined Jun 2003
First off,Paul, I gotta say the velcro idea sounds great!!!(lancaster???) I have put small 2" picture nails thru winglet and epoxied them aswell as the winglet, hope it holds ... I flew my sliger on her maiden last night.. perfect. right outa the box. flew it stock with a zagi 1900mah batt. my first success in r/c. my last attempt was with a mini speed wing., it was too unstable for me.. the slinger is rock solid, I put 4 batteries thru it and it uses all no prob. the other batts I used were a gws 6-cell 600mah, gws 8 cell 720mah and homemade 1...the 6 cell did'nt have the same juice as the othes but still flew just fine. big loops rolls zoom zoom here zoom zoom there......I really like this thing. only problem is winglets...both came off on a "normal" landing...
Chris.
Added a few pics of B-2 Bomber Art Newland Electric Plane Talk 8 Jul 17, 2010 03:19 PM
Wattage B-2 motors on 7 cells? Thomas B Parkflyers 6 Jul 01, 2001 06:15 AM
B-2 motor != N20 mabuchi? miker Parkflyers 4 Jun 26, 2001 07:17 PM
B-2 motors amp draw Patrick Power Systems 8 May 02, 2001 08:04 PM
Pitch speed of B-2 props David Webb Parkflyers 4 May 01, 2001 02:57 AM
