Old Apr 16, 2012, 04:12 PM
AKA Terry Till
ex-racr's Avatar
Alexandria, VA
Joined Apr 2002
I understand Erik. I try to get the highest system efficiency I can.
ex-racr is offline Find More Posts by ex-racr
Old Apr 16, 2012, 04:37 PM
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Originally Posted by ex-racr View Post
I got this a few days ago and ran it up.
Details of the fan are here:
http://www.rcgroups.com/forums/showthread.php?t=1359237
The set up: 6S 2200 50C with Mega 16/25/2E (kv-2300, Rm .015)
Amps: 35
Watts: 760
Thrust: 48 ounces
Grams/Watt: 1.79
I suspect the mediocre G/W reading is because the ESC was losing sync with the motor at full throttle a little.
Never the less, it's in the same ball park as others.
One important thing to note is that the motor used has a higher kv than the ARC 28-47-2 used for most testing.
For my goals, this is a perfect match of motor and EDF unit, as my goal is to get about mid 30 amps static, without a thrust tube. That way I get 900-1000 watts installed.
Terry
well we just tested a mega 16/40/1.5rc motor in our TJ70 fan with the cs 10blade on 6s 4500 35c
and here is the result.......rock solid performance
Mega Snake (3 min 58 sec)
jcdfrd is offline Find More Posts by jcdfrd
Old Apr 16, 2012, 05:08 PM
AKA Terry Till
ex-racr's Avatar
Alexandria, VA
Joined Apr 2002
JC,
I've been following the CS 10 70mm thread. That's definitely a nice set up.
By the way my test was with the 4-bladed rotor; not the 10 bladed one
For those interested, I just ran up a couple installed set ups:
70mm Composite F-16
6S 2200
Cyclone 60amp ESC*
HET 2W-30 (2200KV)
RC Lander rotor in Change Sun Shroud.
Settled readings:
Volts: 21.9
Amps: 36.5
Watts:800
HET F-86
6S 2200 (same as above)
Castle Phoenix 80* with Hyperion cool SBEC
Mega 16/25/2E (2300KV)
RC Lander rotor in Change Sun Housing
Settled readings:
Volts: 21.42 (used same packs above and didn't "top off")
Amps: 42
Watts: 900
* I don't remember what timing the ESC's were on. These also include thrust tubes with an exit diameter of about 57mm.
-Though I didn't use Mini Fans, I think it's a pretty good comparison to a mini-fan, as the RC Lander rotors are similar.
Discussion LX Fan/motor 6S, LX motor mini rotor jet-ster Foamy EDFs 6 May 15, 2011 09:59 PM
Wanted 4S 3700-4000mah at least 25C CRCJA Aircraft - Electric - Batteries & Chargers (FS/W) 3 Jul 19, 2009 12:49 PM
Wanted WANTED a couple of 4s 3700-4000mah packs mechengineer03 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jan 21, 2009 11:39 PM
Sold HL F5E stock motor/70 mm fan/esc-bec/2200mah 4s 14.8 lipo blurz28 Aircraft - Electric - Jets (FS/W) 1 Jan 01, 2009 07:48 AM
Sold TP eXtreme 4S 2200mAh 25C/50C $70 & Efuel 3S2P 4000mAh $50 xwingnut Aircraft - Electric - Batteries & Chargers (FS/W) 2 Oct 13, 2008 08:55 AM
