Old Nov 14, 2010, 01:45 PM
stephensetzer is offline
Find More Posts by stephensetzer
Joined Sep 2007
Hacker Motors - Poorly Engineered
I have a Hacker A30-28S. The shaft snapped while landing on the 5th flight. I called Hacker USA and they told me it would be a manufactures defect if it broke in mid air. Thatís their policy. So this German engineering has produced a motor shaft that is too brittle. Itís not a manufacturing defect just poorly designed. I paid top dollar for what I thought was a quality product. Instead I get a hard time. Do yourself a favor and buy a motor from someone who stands behind their product.
Steve
stephensetzer is offline Find More Posts by stephensetzer
Old Nov 14, 2010, 06:18 PM
FL62 is offline
Find More Posts by FL62
Average Joe 2 Semi-Pro n Back!
FL62's Avatar
United States, AZ, Queen Creek
Joined Feb 2004
Steve,
I am not sure who you spoke with at Hacker USA, but if it truly "Just snapped off", we would gladly replace the shaft in the motor. Thing is, a hardened steel shaft doesn't break off for no reason at all! I don't know if there was any kind of a prop strike, an out-of-balance prop, or if the motor was dropped, or some other cause. Had any thing happened in those five flights?
If any of these things happened, would you rather have a soft steel motor shaft that just bends, and then the prop hits the cowling and chews up the front of your plane?
Hacker USA is very understanding of situations like this. Chances are that if you called up with a reasonable demeanor, we would fix it no matter the cause - warranty or not.
Give me a call tommorrow at the office, and we can get you taken care of.
PS - congratulations on your first post on this forum after joining 3 years ago!
FL62 is offline Find More Posts by FL62
Old May 23, 2011, 07:13 PM
dksoba is offline
Find More Posts by dksoba
Joined Dec 2010
So... Was this taken care of?
dksoba is offline Find More Posts by dksoba
Old Jul 16, 2011, 08:26 PM
r0sewhite is offline
Find More Posts by r0sewhite
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
Mike,
can you tell me if the A20-26M EVO comes with a soft steel shaft? I run these motors on a quadrocopter for wild aerobatics and crashes are not unusual. Though I've had many quads with different motors, I've never had motors with such soft shafts. They bend as easy as no other motor shaft.
Is this a wanted feature to maybe save the bearings? I am a bit confused whether this is a bug or a feature.
Cheers,
Tilman
r0sewhite is offline Find More Posts by r0sewhite
Old Dec 24, 2011, 07:27 AM
dr.pip is offline
Find More Posts by dr.pip
London UK
Joined Oct 2007
I know this is a little dated now, but 5mm motor shafts donít just break without a cause whatever make it is, especially with such a large shaft on a very small motor as 30-28s with reduced prop size (loading) and considering the same shaft is used for props up to 14x7 on their larger 30 size motors.
If there really is an eventless issue then it would be an absolute material fault and not a design problem as suggested. Hackers repeatedly last for years and years and are used in some of the most vigorous competition environments. How long do you imagine the company would survive with a 5 flight failure rate and I doubt you could engineer that kind of problem into any motor even if you tried.
In Europe Hacker back their products to the hilt and will replace any faulty product without issue, providing there is a genuine product fault. It also looks like the same in the US as from these posts.
On 20 size Hackers the shaft used is just 3mm and (like all others) will bend if you give it a reason to. Whilst I understand some crash resistance is desired, to date I donít know of any manufacturer that actually tryís to build crash proof motors, I think they focus on performance which includes consideration for weight, its really impossible to cater for both.
Hardened shafts can bring about their own problems wherever they may exist as although they might offer better initial resistance they could snap and part company more readily then a soft shaft which is not a great attribute with a spinning prop in a people environment. Of course soft shafts will also snap with enough fatigue. I have worked on many many motors, but none so far in the sub 40 group with hardened shafts either cheap or expensive, not that they dont exsist.
dr.pip is offline Find More Posts by dr.pip
Old Dec 25, 2011, 07:51 PM
RayPB is offline
Find More Posts by RayPB
F3P and Sailplanes-Great!
RayPB's Avatar
S.E. Minnesota
Joined Jun 2007
my Hacker A10-15s is of excellent quality
I am very pleased with the quality of my Hacker A10-15s. I have used it on 6 different airframes as I have learned F3P flying over the last 3 years. I have close to 75 hours of flying time on it and have had innumerable direct hits with floors, walls and ceilings. Did I mention floors? My A10-15s still works like new.
Ray
RayPB is offline Find More Posts by RayPB
Old Jan 29, 2012, 02:59 PM
serpentking is offline
Find More Posts by serpentking
Joined Jun 2010
Hacker shaft snapped !
I also have a hacker c50 l motor that i recently purchased and after two quick runs on 4 cell 2200mah lipo, the shaft just snapped and i almost lost my pinion as of a results of it. I hear that i could use any l motor 5mm shaft but i am not sure of what to do at this point.Any advise would be highly taken into consideration. Thank you.
serpentking is offline Find More Posts by serpentking
Old Feb 03, 2012, 01:03 PM
FL62 is offline
FL62's Avatar
Joined Feb 2004
@serpentking
Please give us a call at Aero-Model at (480) 726-7519 - we can discuss some options for you.
For Sale esc, motors, castle creations, hacker,ultrfly, jetti. etc.. ED3 Aircraft - Electric - Power Systems (FS/W) 5 Oct 27, 2010 08:11 PM
Wanted Hacker B20 & Razor motors mlehman Aircraft - Electric - Power Systems (FS/W) 16 Oct 22, 2010 07:26 AM
Sold Neu & hobby people motors , Jeti/Hacker speed control Dennis Everett Aircraft - Electric - Power Systems (FS/W) 0 Oct 12, 2010 12:44 PM
Sold 2 Hacker motors imsofaman Aircraft - Electric - Power Systems (FS/W) 2 Oct 05, 2010 06:12 AM
For Sale Align, Hacker, and JGF brushless motors MTDV Aircraft - Electric - Power Systems (FS/W) 0 Sep 17, 2010 01:20 PM
