Old Nov 14, 2010, 01:25 PM
jketron is offline
Find More Posts by jketron
United States, CA, Carlsbad
Joined Feb 2006
Help!
Eflite Extra 300 32e Flying issues
I have recently build a Eflite Extra 300 32e and on the first flight I have the cg set at 3.5 inches and during the first flight it was very unstable.
What CG are you folks using? I'm just looking for easy flying, the book states 3.5 for precision flying to 3.75 inches for aerobatic flying.
What are you experiences flying this plane slow? I would expect it to be VERY stable and want to float.
Thoughts???
jketron is offline Find More Posts by jketron
Old Nov 14, 2010, 01:38 PM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
did you build it with recommended hardware or go your own with customizations.
Are you using exponential on your controls and dual rates?
cryhavoc38 is offline Find More Posts by cryhavoc38
Old Nov 14, 2010, 01:44 PM
jketron is offline
Joined Feb 2006
I used the complete Eflite setup, I bought every part on the recommended parts lists. I'm using Hitec Servos HS-82MG all the way around, Turnigy 3300 4 Cell LiPo.
I take off on low rate and I do have expo set
Old Nov 14, 2010, 02:53 PM
cryhavoc38's Avatar
Joined Mar 2007
so in what way was it unstable?
While its not a 3d machine per se, its still capable of some very decent manouvers.
Whats your previous flying experience?
what sort of planes?
Is it pitch sensitive?
Old Nov 14, 2010, 03:48 PM
jketron is offline
Joined Feb 2006
I it felt a if the CG was off, I brought it home and put it back together to check the CG again with the battery exactly where it was and it checked out fine. I'm going to over the plane again and make sure I don't have something messed up. I know this should fly just fine.
I dont fly serious 3D, I have been flying the Extra 300 planes for years and always felt they fly very stable, they typically fly very well at slow speed.
I'll double check everything again and try another flight.
What are you experiences flying this plane slow, where is your CG?
Old Nov 14, 2010, 03:59 PM
Flying_Old_Man is offline
Find More Posts by Flying_Old_Man
Paso Robles, CA
Joined Jul 2010
start with the basic answer: was it nose heavy or tail heavy and was it windy or calm. Better to be nose heavy in the beginning. Are you adding up or down elevator? Rudder?
I would go back to raw basics which is your setup/throws. We don't fly expo on an initial flight, as I want to feel the plane in its rawest form for me which is high rate, no expo, no mixing...nada. Initial flight can always be a bit sketchy, many planes I have built the CG was not what was good for that plane. E-Flite is a great company...
Bob-
Flying_Old_Man is offline Find More Posts by Flying_Old_Man
Old Nov 14, 2010, 08:09 PM
jketron is offline
Joined Feb 2006
Back to basics is exactly what I'm thinking, I'm went over the CG and its perfect at 3.5, I will remove all expo and make sure that my throws are exact. I'll use low rates on take off and I only use low rates on the Aileron an Elevator.
I really do like this airplane.
Do you know where I can find some carbon fiber landing gear? I wouldnt mind add them. I love the way they look.
Old Nov 16, 2010, 06:07 PM
wrtank is offline
Find More Posts by wrtank
Go....fly!!
wrtank's Avatar
25 miles out
Joined Aug 2009
Are you CG'ing upright or inverted?
wrtank is offline Find More Posts by wrtank
Old Nov 18, 2010, 11:52 PM
jketron is offline
Joined Feb 2006
inverted
Discussion Extra 300 32e ARF by E-flite - Horizon Hobby SalamSyed Electric Plane Talk 332 Aug 15, 2014 05:45 PM
New Product E-Flite Extra 300 32e jonnyspeed Sport Planes 515 Jul 14, 2014 11:28 AM
Discussion Extra 300 32e Motor Options? Eastcoast78 Power Systems 0 Oct 23, 2010 12:07 PM
Discussion Extra 300 32e Staudacher600 3D Flying 47 Oct 02, 2010 08:27 AM
