Old Jan 05, 2011, 02:26 AM
erazz's Avatar
United States, NJ
Joined Jun 2004
I just remembered that there is one more *very important* difference between the Safety Switches and the "Replace -100%" method. The Safety Switches disregard limits. They set the output to a set position and that's all. The "R" function does that within the limits.
So if you have a servo in the throttle channel it's best to use the "Replace -100%" method since then you're assured it won't max out and bind.
For electrics using the Safety switches makes more sense.
erazz is offline Find More Posts by erazz
Old Jan 05, 2011, 02:30 AM
erazz's Avatar
United States, NJ
Joined Jun 2004
Originally Posted by phantom1500 View Post
question for the gurus......
in the mix section for helis what is the purpose of the CYC1/2/3 mixes and why does it create a CYC mix on CH11 as aposed to building
Mixers
CH01 left side swash servo
+60%ELE
-60%AIL
+70%THR Switch(ID0) Curve(c5)
+70%THR Switch(ID1) Curve(c6)
+70%THR Switch(ID2) Curve(c7)
CH02 right side swash servo
+60%ELE
+60%AIL
CH03 throttle
+100%THR Switch(ID0) Curve(c1)
+100%THR Switch(ID1) Curve(c2)
+100%THR Switch(ID2) Curve(c3)
R +100%THR Switch(THR) Curve(c4)
CH04 rudder
+100%RUD
CH05 gyro rate/heading hold switch with trim pot P2 to fine adjust gyro gain on the fly
+50%P2 Switch(RUD) Offset(100%)
-50%P2 Switch(!RUD) Offset(100%)
CH06 pitch servo, rear swash plate 120 deg servo
-60%ELE
CH07 fligt mode trigger for helo v2 controller
+100%MAX Switch(ID0)
+0%MAX Switch(ID1)
-100%MAX Switch(ID2)
CH08 gov on/off
+100%FULL Switch(AIL)
-100%FULL Switch(!AIL)
when I use the heli template CH1 moves 100% +/- but CH2&3 only move 86.5% with aile input and less for CH2&3 on elev input....why is that?
the above mix setup moves as I need it to to control the swash etc, is this a workable mix as it looks promising so far in the simulate screen?
I need to think about the mix and see if there is a real reason for letting the servos move only 0.86% (Sqrt(3)). As far as pitch is concerned that is correct but for aileron use... Need to think
The reason I use CH11 for building the cyclic mix is because it takes less room in the EEPROM and is easier to edit. Your way is just as correct but may take more computing time (latency) to achieve.
Old Jan 05, 2011, 03:22 AM
Melbourne, Australia
Joined May 2006
phantom - this thread is about the add-on board. Please post general questions about the firmware in its thread: http://www.rcgroups.com/forums/showt...9#post17010497
kgfly is online now Find More Posts by kgfly
Old Jan 05, 2011, 04:27 AM
Australia, New South Wales, Hobartville
Joined Jan 2011
Fair enough, my mistake.
phantom1500 is offline Find More Posts by phantom1500
Old Jan 05, 2011, 05:55 AM
Naperville, IL
Joined Mar 2009
Originally Posted by luilly3d View Post
hi guys, today I ordered a Eurgle radio, it is 3rd generation and my question is.. will this mod ( add on board programmer & EL ) work for me?
I have an Eurgle '2nd Gen' and it is the same as V1. Eurgle just seems to use a different naming. I would expect the '3rd Gen' to be the V2. So it should work just fine.
gohsthb is offline Find More Posts by gohsthb
Old Jan 05, 2011, 09:50 AM
radiocloclo's Avatar
Belgique, Région Wallonne, Sivry
Joined Mar 2009
hello,
Can you explain me the following mixing: to have a progressive reduction of 5% on the elevator when the Throttle are full.
Thank you for the information.
greetings.
Claude
radiocloclo is offline Find More Posts by radiocloclo
Old Jan 05, 2011, 11:30 AM
Registered Loser
Canada, BC, Central Okanagan H
Joined Jun 2010
ps...can I get bigger receivers for this radio? 9 or more channels?
No such thing, no.
Lol... like we've EVER stayed on topic before!
s_mack is offline Find More Posts by s_mack
Old Jan 05, 2011, 11:41 AM
59 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
No. The module uses standard PPM, which is limited to 8 channels.
Daedalus66 is offline Find More Posts by Daedalus66
Latest blog entry: Polaris Aileron Pushrods
Old Jan 05, 2011, 11:52 AM
Joined Jan 2011
little off topic....BUT, just unpacked the new 9x and it works fine but in it's stock form the extra channels are useless as you can't assign them to do squat?
waiting now for my order of the 9x board and EL back light kit........and.....still not here yet, I know the web site said shipping after the 10th of Jan! lol
Old Jan 05, 2011, 06:02 PM
Joined Jan 2011
What code is used for writing the firmware?
Is it just the old C code, not C++ or later?
Old Jan 05, 2011, 08:52 PM
wheelspinner20's Avatar
S.E.Michigan
Joined Jul 2010
hello,
Radiocloclo
Have you read page 23.... in the following link.?
http://er9x.googlecode.com/svn/trunk...rs%20Guide.pdf
I will try a couple and see if I can help.
Pat
wheelspinner20 is offline Find More Posts by wheelspinner20
Old Jan 05, 2011, 10:39 PM
S.E.Michigan
Joined Jul 2010
Radiocloclo
On page 29 of the er9x manual, you will find directions for setting up a custom switch.
Are you using a 9x radio with the ER9x custom firmware?? If so I will send you a pm with a mix I tried and I think works.
Pat
Old Jan 05, 2011, 11:10 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
You can assign them to do several things. Is there something specific you can't get them to do?
Old Jan 06, 2011, 12:37 AM
erazz's Avatar
United States, NJ
Joined Jun 2004
It's an odd mix of C, C++, ANSI C and ruby. Weird, I know but it works. You can generally treat the code as C++.
Old Jan 06, 2011, 01:12 AM
Joined Mar 2009
Pat
Yes, I use the last version firmware of er9x with eePe? but I have difficult has to assimilate the mixing, perhaps that if I had an example I would include/understand better.
In advance thank you.
Claude
Download RCDeskpilot Add-on Planes In Post #1 UPDATED MARCH 7 2011 Wilfor Simulators 164 Apr 22, 2013 10:48 PM
Sold RealFlight G3.5 With Controller and Vol. 3 Add-On Rob02Aggie Aircraft - General - Miscellaneous (FS/W) 3 Nov 13, 2010 02:13 PM
Question Searching RC Car with transmitter having the pots NOT soldered directly on the board Nase Electric Power Cars 0 Nov 07, 2010 08:46 AM
Discussion Built-in-Balancer: Replace a 14.4 nihm pack with 5S LiFE leveraging original charger? coreyfro DIY Electronics 0 Nov 05, 2010 09:33 AM
