I cannot remember asking you to judge my understanding of things... I do not necessarily think it is software, I merely said it worked correctly before, and no longer after, installing a software revision (a newer version of the Open 9X version )without any change whatsoever to the hardware( I analyse problems for a living, and I'm rather good at it , hehe...). Maybe something went wrong with the hardware coincidentally, I have no clue as to what it could be, hence my question. Anyway, I have been trough all of your suggested solutions dozens of times, none of them, or even the ones made by helpful forum members, worked in MY case (Incidentally, I never suggested backlight and programming functions are dependent, I merely said I could not get both of them to function at the same time).But we've had that discussion already, I found a solution that worked for ME(until recently...) so, please, let's leave it at that. I would like a diagram so I can get my programming connection working again and see if another version (newer yet) of the open 9X software restores my backlight function. If not, I'll look for a hardware cause.... |
Canada, BC, Central Okanagan H
Joined Jun 2010
Ok well, I really hope someone can provide whatever it is you're looking for and you get things working how you want it to. I obviously don't understand what that is (I thought it was your backlight that wasn't working and now you're asking about programming - so I'm really not sure what diagram you'rer looking for) and it sounds like my attempts are just frustrating you further. Good luck and feel free to contact me if there's something specific I can assist with.
- Steven |
If you look at the pictures in the instructions you can see how it works at the board end of the cable. http://www.smartieparts.com/shop/ind...page=page&id=9 At the other end, on my v.2.1 board, the connections are clearly marked: red is +5v, black (or grey) is ground, green is D+ and white is D-. In case it isn't marked, the pins on the mini USB are, from left to right, blank, blank, D+, D-, +5, with the ground going to the shell I assume. This is with the connector to the top, looking from the connector side of the board. Hope this helps. |
Latest blog entry: Polaris Aileron Pushrods
Hello all I just pulled the trigger on this for my 9x I was just wanted to know if it is as easy as they say
Thanks |
Latest blog entry: Win a frame
Then follow the instructions carefully. |
Thank you for your reply. One more ? Where is the best place to find the firmware thanks again
Joined Jun 2010
That's a loaded question
I'd recommend starting here and reading for the next few days. Or skip to the Wiki as its at least somewhat condensed.
I think I'll go with the er9x
| Thread Tools | |
| Download RCDeskpilot Add-on Planes In Post #1 UPDATED MARCH 7 2011 | Wilfor | Simulators | 164 | Apr 22, 2013 10:48 PM |
| Sold RealFlight G3.5 With Controller and Vol. 3 Add-On | Rob02Aggie | Aircraft - General - Miscellaneous (FS/W) | 3 | Nov 13, 2010 02:13 PM |
| Question Searching RC Car with transmitter having the pots NOT soldered directly on the board | Nase | Electric Power Cars | 0 | Nov 07, 2010 08:46 AM |
| Discussion Built-in-Balancer: Replace a 14.4 nihm pack with 5S LiFE leveraging original charger? | coreyfro | DIY Electronics | 0 | Nov 05, 2010 09:33 AM |
