United States, WA, Washougal
Joined Mar 2010
drivers for the ternigy
I have installed the board and have went in and down loaded the er9x, but I cannot get it to load into the transmitter because I don't have a driver where do I go from here and what do I do? Im lost at this point. appreciate some help
Walt |
Canada, BC, Central Okanagan H
Joined Jun 2010
On the product page is a link to the installation instructions. On that page is a link to the driver info.
- Steven |
Australia, VIC, Narre Warren
Joined Jun 2011
I am looking to order the board and saw it comes with the EL backlight in blue
I already have a back light installed which I bought from Hobbyking (white) when I bought the TX Is there any advantage in using the EL supplied with the board over the Hobbyking item? |
Joined Jun 2010
Depending on what you're looking for... yes. I designed it for night flying. A lot of people are disappointed with its brightness and like the HK one better. For night flying though, you don't want bright - you want a backlit glow. But if you want a pretty blue shiny thing in the middle of the day, then you want LED.
Either way, the EL circuit was added to my kit as a bonus. The price didn't change when the EL was added. So if you want to use the HK backlight, that's fine... just don't use the EL! Try both and decide what works best for your flying.It was my initial assumption that people that wanted a backlight wanted it for nightflying and people that didn't night fly didn't need a backlight. My next design is going to have an option to drive both. The current HK setup is, in my opinion, flawed. First off, its designed to operate with the main power switch. So its on all the time, drawing battery power whether you want or not. Second, it runs directly off the battery power. So it draws more with higher voltage and gets dimmer as your battery runs down. While cheap and simple, that's not really the "right" way (I use that term loosely) to drive an LED. But its cheap and easy. You can modify the HK backlight to turn on with the EL driver switch (in er9x, etc) with a FET... but its still voltage driven. My next design will include a proper LED driver chip to better manage the HK backlight. Anyway, I'm rambling. - Steven |
Joined Jun 2010
I'll answer your question more completely then you're probably looking for (for simple answer, its "yes" but you have reading to do on your own):
LED runs on DC and is (supposed to be) driven with a constant current. EL runs on AC and is driven with a constant voltage. Batteries, of course, put out DC. My SmartieParts circuit converts the DC input into an AC output specific for the EL panel provided. The HK LED kit, on the other hand, takes the straight voltage from your battery and drives the LED directly via a simple resistor. Not the best way to do it, but of course it works. The firmware outputs a signal on a specific pin that my board hooks up to, so the firmware can therefore turn on/off the EL backlight. This is not the case with LED unless you make yourself a circuit that can handle it. That means using a FET as a switch. So the firmware outputs the same signal that triggers the FET to allow battery voltage through to your LED. Again, not the most elegant solution but it works. So bottom line is you can't just plug the HK LED light into my SP board and hope it works. I'm not saying you'll end up with a small mushroom cloud, but perhaps not far off. But you CAN take advantage of the SP connection to the radio's "light switch" (for lack of a better term) pin, via a FET or a better circuit if you care to, to achieve what you want to do. Hope that helps. - Steven |
I'm a little lost
![]() I have just bought the SP board. Do I have to buy the "programer" http://www.ebay.com/itm/USB-ISP-Prog...ht_8570wt_1163 to connect my PC to the SP board installed in my TX? I was under the impression that the SP board was the programer and I only needed to connect a usb cable from my PC to the board |
| Thread Tools | |
| Download RCDeskpilot Add-on Planes In Post #1 UPDATED MARCH 7 2011 | Wilfor | Simulators | 164 | Apr 22, 2013 10:48 PM |
| Sold RealFlight G3.5 With Controller and Vol. 3 Add-On | Rob02Aggie | Aircraft - General - Miscellaneous (FS/W) | 3 | Nov 13, 2010 02:13 PM |
| Question Searching RC Car with transmitter having the pots NOT soldered directly on the board | Nase | Electric Power Cars | 0 | Nov 07, 2010 08:46 AM |
| Discussion Built-in-Balancer: Replace a 14.4 nihm pack with 5S LiFE leveraging original charger? | coreyfro | DIY Electronics | 0 | Nov 05, 2010 09:33 AM |
