Canada, BC, Central Okanagan H
Joined Jun 2010
I've posted an update relating to the current stock situation.
Well, while replacing my aileron stick assembly my friend and I looked at the backlight problem. turns out he soldered the vdd wire to the wrong pad (one that connects to pin 16!). Re-soldered it to the correct one and oh my, everything finally works as advertised. Now I could also see why the backlight never worked with the pins: the pad it was supposed to connect to was not really a pad, it looked more like a blob of solder with a wire sticking through, no way the pin was going to make proper contact with that. So Steve's board did not really have a chance of working correctly with my TX that looks to be just a bit out of specs...But as I said before, I'm just as happy with my wired version... I'm finally ready and able to use the full potential of my TX....
Is there a way to flash the 9X on a mac using Steve's board? No way I couldn't make the avrdude work on my bootcamp windows partition. AS a Mac guy I'm willing to try it on a system that I know better. Doing some research I found CroosPack for AVR, will give it a try....
I have a FRSky module here that I would like to use with the 9ER...I saw there are firmwares specially for FRSKY module but they seems to need hardware modification. Will the smartieparts board do the trick and avoid me having to do hardware modifications ? |
BUT It will not make it frsky compatible. Hardware mods are still necessary to make that module work properly. Hope that helps. Pat |
Naperville, IL
Joined Mar 2009
http://www.rcgroups.com/forums/member.php?u=340050' I know he uses a Mac. So he can probably help you out. As far as the Frsky module goes. The serial lines that are required are already used by a couple of the switches. What the mod does is move those 2 switches to some unused pins, which frees the serial port. The mod has some difficult soldering to do, but is doable. Check the wiki under hardware mods for all of the information. http://code.google.com/p/er9x -Gohst |
You need to install avrdude separately but that is fairly easy, and I have also a suggestion for that on my profile. Feel free to ask if you need any thing more. PS I had trouble using crosspack(could be my fault), but osx-avr worked fine for me. Groot |
http://www.rcgroups.com/forums/showthread.php?t=489807 or this: http://www.desert-wolfe.com/Projects...y/default.html The second one has a picture. |
Latest blog entry: Polaris Aileron Pushrods
hungary
Joined Jan 2011
http://www.hobbyking.com/hobbyking/s...2pcs_set_.html http://www.hobbyking.com/hobbyking/s...1pair_Red.html http://www.hobbyking.com/hobbyking/s...er_Black_.html http://www.hobbyking.com/hobbyking/s...a_Rocker_.html http://www.hobbyking.com/hobbyking/s...cker_Red_.html http://www.hobbyking.com/hobbyking/s...ker_Blue_.html The TurboThumbs vary a lot in price, but the only thing that seems to be different is the color. Strange... |
United States, NM, Las Cruces
Joined Oct 2011
EDIT: I just asked s_mack on another thread, that transmitter does not belong to him... |
| Thread Tools | |
| Download RCDeskpilot Add-on Planes In Post #1 UPDATED MARCH 7 2011 | Wilfor | Simulators | 164 | Apr 22, 2013 10:48 PM |
| Sold RealFlight G3.5 With Controller and Vol. 3 Add-On | Rob02Aggie | Aircraft - General - Miscellaneous (FS/W) | 3 | Nov 13, 2010 02:13 PM |
| Question Searching RC Car with transmitter having the pots NOT soldered directly on the board | Nase | Electric Power Cars | 0 | Nov 07, 2010 08:46 AM |
| Discussion Built-in-Balancer: Replace a 14.4 nihm pack with 5S LiFE leveraging original charger? | coreyfro | DIY Electronics | 0 | Nov 05, 2010 09:33 AM |
